Wedge Using TR7 Main Bearing Studs on a TR6: how to note
atgordon
This was a topic that started on the 6-Pack list, and in the hope that what I have learned might benefit others on the Britcar forum, I am posting the info here as well.
Put briefly, I was interested in using studs for retaining the main bearings in the rebuild of my TR6 engine. After a lot of discussion on the 6Pack list, it appeared that others had managed to use the ARP main bearing stud kit designed for the TR& on the TR6. But after a lot of asking, I was unable to find out what they had done.
I was intrigued since the front main bearing is covered by the aluminium sealing bar, and they're ain't a lot of room to fit studs, so I went ahead and did all the measurements and calculations, and low and behold, it is a very simple process, and I have written it up in the hope that others will find it useful.
The PDF can be downloaded from here TR7 Studs TR6
DNK
The reason you didn't get a response is
You didn't know the Secret Handshake
DNK
tdskip said:
Thanks.
What is the advantage of doing this?
Studs are stronger than bolts,Tom
Clarification
The clamping power is greater
A
atgordon
vettedog72 said:
With out being way too technical, how/why are studs stronger than bolts?
I did put a couple of references in the article that gave a further information on the topic. Here is a very brief summary (it refers to cylinder head bolts, but the same concepts apply to main bearings too):
<span style="font-style: italic">"During engine assembly or maintenance, a bolt must be installed by torqueing it into place. Due to the head bolt’s design, it has to be rotated into its slot in order to engage the threads and secure it into place. This process creates both twisting force and a vertical clamping force, which means that when the cylinders within the engine’s combustion chamber begin accumulating load, the bolt will both stretch and twist. Because the bolt has to react to two different forces simultaneously, its capacity to secure the head is slightly reduced and it forms a less reliable seal in high-powered engines.
By contrast, a head stud can be tightened into place without any direct clamping force applied through the tightening. A stud can be threaded into a slot up to “finger tightness,” or the degree to which it would be tightened by hand. Afterward, the cylinder head is installed and a nut is torqued into place against the stud. The nut torque provides the clamping force, rather than the torque of the fastener itself, and the rotational force is avoided entirely. Because the stud is torqued from a relaxed state, the pressure from the nut will make it stretch only along the vertical axis without a concurrent twisting load. The result is a more evenly distributed and accurate torque load compared to that of the head bolt. This ultimately translates into higher reliability and a lower chance of head gasket failure."</span> (from https://www.thomasnet.com/articles/hardware/head-stud-bolts).
Darrell_Walker
That would also imply that regular bolt/nut combinations should be tightened by turning the nut, rather than the bolt, if possible. Of course, most fasteners don't have to deal with the same loads a head, rod and main bearing fasteners do.
A
atgordon
Agreed! It is much better practice to tighten a nut (particularly when tightening to a torque setting). But we then get into the whole issue of wet or dry torque tightening ... (if a fastener is lubricated, the required torque to tension it is greatly reduced!).
Incidentally, the reason studs are not more commonplace is largely to do with the ease of automated assembly of bolted components. Plus, separating of multiple stud-fastened items (such as the cylinder head on a TR6) can be a royal PIA.
K TR2/3/3A Centering the brake rotors(disk)s in the front brake calipers using the shims? Triumph 5
T Looking for recommendations re using a Seacan for vehicle storage Spridgets 7
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
Oldi.Tec Spare Part Re-Manufacturing using 3D-Printing Restoration & Tools 5
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
L TR2/3/3A Who's using what to treat rusty stuff TR3 Triumph 21
Patrick67BJ8 Special Tuning using AF Equipment by Innovative Motorsports Austin Healey 27
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
CJD General Tech Boeing using Lucas parts? Triumph 7
TRMark General Tech Anybody Using Star Tron Triumph 2
Martinld123 Problem Using LED lights with Existing Brake Lamps Austin Healey 20
G TR4/4A Using existing fuel line Triumph 5
D Wanted How to locate my father's past Austin Healey1963 3000 Mark III using its Vin # Austin Healey Classifieds 5
B TR6 Timing using a vacuum gauge Triumph 13
Gerald_Gordon TR4/4A Attaching badges without using a badge bar Triumph 5
M TR2/3/3A What Lead Substitute + Octane Boosters is everyone using in there gas tanks? Triumph 14
Basil Admin Note Using FREE BCF Classifieds Triumph Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Spridgets Classified 0
Basil Admin Note Using FREE BCF Classifieds MG Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Jaguar Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Other British Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Austin Healey Classifieds 0
Basil Admn Note Using Prefixes to filter threads of interest Triumph 5
KVH TR4/4A Using Drill to Spin Oil Pump Shaft Triumph 10
J Bypassing battery cutoff switch, using is as anti-theft only? Austin Healey 20
KVH TR4/4A Using the Engine Stand Triumph 3
K TR2/3/3A Clutch bleed using"gravity bleed" method? Triumph 4
KVH General TR Using an Old Fuel Pump Triumph 3
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
aseriesspares What Gearbox are you using. Midget 1500 Spridgets 5
J BJ8 carb sync using a Uni-Syn, can you actually use it? Austin Healey 42
Rut 5 speed conversion using the Datsun clutch assembly Spridgets 10
bthompson Using the brakes kills the engine! Any ideas why? Spridgets 17
K TR2/3/3A Using Moss front end alignment gauge? Triumph 6
M Healey Overdrive Accumulator Piston using O-Ring Seal Up-date Feedback Austin Healey 4
J Does a texas cooler make a real difference ? I now am using an a moss flex fan ! Austin Healey 24
drambuie Anyone using flame thrower Electronic distributor Austin Healey 6
Q TR2/3/3A Using DOT 5 Brake Fluid On TR3A Triumph 34
F Using 12 point ARP style rod and main bolts Spridgets 9
Nelson Using timing light Spridgets 17
M Anyone using a MaxJax on a BN2 ? Austin Healey 9
58Custom A14/A15 engine users: What yall using for headers? Spridgets 11
S TR2/3/3A Using a timing light for setting TR3 Timing Triumph 4
justin_mercier TR6 "new" steering rack for TR6 ? Anyone using one ? Triumph 5
T Using Midget Suspension parts on Nash Metropolitan MG 10
K Paging Martx-5...What valve gap are you using? Triumph 0
T using UNI-SYN tool Triumph 46
B Using an MG properly MG 7
T Anyone using an LED light like this Triumph 39
