TR2/3/3A Centering the brake rotors(disk)s in the front brake calipers using the shims?
karls59tr
Bronze
How critical is getting the rotor to be dead center? Does it matter if one side of the rotor is a little closer to the caliper on one side? Someone said they tried the shims and it did not makes any difference? However I did read on this forum a suggestion to use "dental floss" to hold the shims in place when attaching the caliper hold down bolts, so I will do that if I do have to get the rotor completely dead center.
charleyf
IMHO. As these types of brakes are referred to as self adjusting, close should be good enough.
Charley
CJD
As long as either side pistons are not bottomed out, I don't think you need to worry. I do check for runout using a dial indicator to make sure the rotor runs true. The side runout is what can introduce air into the system and also push fluid back into the MC, so you get a longer pedal travel on the initial push.
bobhustead
These calipers have two pistons, each of which retracts a scosh when you let off the pedal. You could have a pad 5/8 thick on one side of the rotor and 1/4 thick pad on the other side and it would work just fine. I have never understood the "dogbone" shims and leave them out. What can be a problem with new pads is that some of them are just too thick for the gap between the piston and rotor and drag even when hydraulic pressure is not applied.
Bob
bobhustead
My first choice would be a brake shop. You could try a belt sander or a wood planer. Planer would keep the lining and metal parallel, which is important.
Bob
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
steveg HD series Jet Centering - a Caution Austin Healey 19
F TR2/3/3A Centering The Jet Triumph 14
M SU Jet Centering Tool - A Worthwhile Investment? Spridgets 2
KVH General Tech Centering Real Main Seal Triumph 4
K SU's again...Jet centering? Triumph 7
Nelson SU jet centering Spridgets 11
H HS6 Fixed needle centering tips Triumph 1
T Is the PDWA selt-centering? Triumph 6
Steve1970 Centering the Steering Triumph 4
Woodie centering the steering wheel Spridgets 7
D Jet centering tool Triumph 3
SilentUnicorn SU centering tool Restoration & Tools 2
W Centering The Needles MG 5
B MGA Axle Brake line MG 0
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
KVH General TR Rear Brake Shoe Orientation Triumph 12
R TR6 Help: Brake Part Source or …. ? Triumph 1
mezy vauxhll brake pipes Other British Cars 0
KVH General Tech TR4A Brake Bleeding Triumph 5
R Brake Adjustment Spridgets 2
