Disc Brake Shimming
fishyboy
Hi all,
I’ve been trying to fit a pair off BCC Pembury upgraded 4-pot aluminium callipers (> Austin Healey 3000 (Mk1 BN7 & BT7) Front Brake Caliper Upgrade Kit <) to my 1961 BT7 and I am experiencing some fitting issues.
Having removed the original Girling 14 callipers, which were perfectly centered on the disc (photo 1), the new callipers are offset to the right by 5-6mm and require 2.8mm of shims (2x0.9, plus 2x0.5mm) to bring the callipers close to being centered (photos 2 &3).
I am slightly concerned about needing 2.8mm of shims to center the discs. Is this acceptable?
Phil
gonzo
Since the pads will essentially "float" with the small mm gap taken up by the caliper piston(s), would that small distance be a significant concern? Check fitment with pads loaded and calipers working.
Rob Glasgow
Phil, I am interested in your project as I am considering converting to those calipers for my BT7. I have the stock set up and while it's served me well for over 60 years, I have always thought an improvement in the braking would add some comfort. I don't have a servo but I did install EBC Greenstuff brake pads that seemed to help.
I would be interested in your review of these calipers once you're done. Did you start with a stock non-servo system? Any other brake upgrades beyond the new calipers? Please let me know.
F
fishyboy
Hi Rob,
My setup was all original - standard Girling 14 calipers, standard pads and no servo. I did put on the braided flexi-hoses about 8 years ago, which seem to firm up the pedal but I have now reverted back to the standard rubber flexi-hoses. Apart from the flexi-hoses the only upgrade is the calipers so it should be a fair test.
Phil
Rob Glasgow
I went with braided lines about 5 years ago also. Was there a reason you went back to rubber lines with this upgrade? I’ll be interested to hear your thoughts on the new calipers. How long do you expect it will take you to finish the conversion?
BobHaskell
One advantage of the rubber lines is that you can temporarily squeeze them shut. Closing off the one that attaches to the rear axle can isolate a problem to the front or rear brakes.
O-T, a little: I recently stumbled across these at Harbor Freight, something I hadn't seen before (NFI):
They're a little fiddly to use, but I like the way they apply pressure evenly. I used the big one to clamp a 2" return line for a high pressure hydraulic pump on a tractor, which would otherwise require draining 5 gallons of fluid to not dump it on the floor. They also have a Vise-grip-like clamp, but it's a bit ungainly.
BoyRacer
Yes, you can safely use shims (spacers) to center your calipers.
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
kodpkd Disc Brake Pad Installation Austin Healey 11
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
K TR2/3/3A Securing new brake disc to the front hub? Triumph 4
K Disc Brake Conversation to MK1 Midget Spridgets 2
I Bug eye front disc brake conversion. Spridgets 5
A Disc Brake pictures Austin Healey 1
A AH 3000 rear disc brake conversion Austin Healey 28
BJ8Healeys Disc brake piston seals Spridgets 2
Ohiobugeye Front brakes won't release after disc brake conversion Spridgets 10
K TR2/3/3A Brake disc? Triumph 19
NutmegCT Disc brake fun Other Cars 33
B Another disc brake question Spridgets 10
B Disc brake conversion Spridgets 12
K TR2/3/3A Front disc brake squeal.... Triumph 4
Jim_Gruber Steering Arms for BE Disc Brake Conversion Spridgets 1
T Disc brake conversion questions Spridgets 5
R BJ7 Front Brake disc hitting Austin Healey 12
bugedd Disc brake conversion Spridgets 7
jaegzie Disc brake upgrade was fine now major alignment issue. Spridgets 6
DanLewis Disc brake setup on eBay for $79+shipping [NFI] Spridgets 2
Lynn Kirkpatrick MGB Disc brake pads MG 4
tahoe healey disc brake anti squel pads Austin Healey 5
AHS TR2/3/3A Disc brake line routing Triumph 0
maxwedge5281 front disc brake hubs for steel wheels Austin Healey 24
C 100 Drum Brake Keep or upgrade to disc? Austin Healey 9
steveg First drive - Toyota 4-piston Disc Brake conversion Austin Healey 5
S Rear Disc Brake Conversion Austin Healey 9
J Disc Brake Conversion on Sprite Austin Healey 1
S rear disc brake conversions brackets Triumph 9
M BJ7 Rear Disc Brake Setup Austin Healey 7
I Disc brake question Austin Healey 1
drooartz My writeup on disc brake conversion Spridgets 14
D Disc brake rotors Austin Healey 10
K disc brake conversion Spridgets 11
M MGA MGA Disc Brake Axles? MG 2
K Disc brake conversion Spridgets 2
E Bugeye Disc Brake Conversion Spridgets 2
livinginthepast Disc brake conversion - soft pedal Spridgets 8
J How to install disc brake seals. Austin Healey 1
19_again GT6 disc brake piston removal GT6+ Triumph 8
B TR6 TR6 Disc Brake rattle Triumph 2
Trevor Jessie Front brake line locating brackets [disc]. Spridgets 6
B Disc Brake Parts List Spridgets 13
M BN4 prob with disc brake conversion[front] Austin Healey 2
Fortius Dennis Welch Rear Disc Brake Conversion Kit Austin Healey 2
drooartz Brake hard lines, drum vs disc Spridgets 2
BIBBER Disc Brake Conversion Restoration & Tools 7
G Disc brake rotor removal Spridgets 17
Thomas591 Disc Brake conversion to BN2 Austin Healey 5
