front disc brake hubs for steel wheels
maxwedge5281
i have a 63 bj7 with the minilite look wheels with knockoffs. where would i find a set of front disc brake hubs that will work with steel wheels. my favorite healey of years past was a 1960 bn6 with steel wheels and front disc brakes. still like that look as well as the opportunity to use other wheels. thanks,
You might get lucky and find you a set, but they're fairly rare. Years ago, I gave up looking and had a few sets made; none of these are available now, but a crafty machinist could reproduce them...
4140 solid steel blanks:
These took about 1-1/2 years from the time the steel was dropped off (I'm sure I spent a year measuring & remeasuring an NOS BJ8 hub before that__compensating for the earlier/larger outer bearing dimension) since this was a "backdoor" project at a machine shop that I did work for back in the 80s-90s (date stamp reflects conversion from prints to digital files). I can't imagine what these would represent__cost-wise__if done at face value.
Point is, if you want something bad enough, you'll find a way to get it! :cheers:
vette
You could try Dennis Welsh Motor Sports, UK. I know he makes rear bearing carrier hubs but I don't know about the front.
maxwedge5281
maxwedge5281
is there a way to adapt a set of earlier bn6/7/bt7 or whatever to the bj7 front end?
BoyRacer
I have a set for sale. Send me a private message. Also, there is no way to convert 100-6 drum brake front hubs to disc brake front hubs.
The 3000 disc brake front hubs will fit every front spindle from the BN1 through the BJ7. The BJ8 spindles have a different bearing size so the disc (non wire) wheel front hubs for the BJ8 are super rare...I also have a set of these for sale if anyone is interested. Send me a private message if interested in either set.
Richard
maxwedge5281
maxwedge5281
i sent you a private message this morning...wednesday. thanks
The rear drums may present some issues since they would be dished for the splined hubs.
There are workarounds; I'm pretty sure I have a pair of DW/rear drums up in the garage's attic, if Larry needs them.
I did this before I found the drums:
maxwedge5281
maxwedge5281
rhanks to the forum i have the necessary parts for the conversion. thanks to richard and randy for their expertise and pulling out the necessary parts. i will have to come up with longer wheel studs for the rear drums. thanks again!!!
Moroso part no. 46150 for the individual stud(s) 7/16" x 20 x 2-7/8" with .480" knurl. Packs of five (5) with lugnuts are #46450
Summit: https://www.summitracing.com/parts/mor-46150/overview/
Jeg's: https://www.jegs.com/i/Moroso/710/46150/10002/-1?parentProductId=748727
ARP: https://www.jegs.com/i/ARP/070/100-7701/10002/-1 (has slightly larger knurl @ .486")
Moser (10 in pkg/best value): https://www.jegs.com/i/Moser-Engineering/718/8050/10002/-1
In other words, you won't have any trouble finding the studs; might even be able to pick them up local...
Edit: Interestingly, these Milodon stud sets are the only ones that say for use with wheel spacers (the others not). Technically, the disc wheel rear drums are in effect, spacers...
Milodon: https://www.jegs.com/i/Milodon/697/86050/10002/-1
Hangtown Healey
I took a stock BJ8 wire wheel front hub, cut off the splines and bolted on an adapter. Been fine since 1976.
Ken Freese
Ken Freese
I looked into doing that before embarking on machining my own hubs, but the disc bolt-circle pattern didn't match any commercially available adapters__seems like it was a little under, or over, 4-1/2 on 5. Did you redrill the hub/rotors to match the adapter?
Where did your front track wind up, but I'm thinking it must've grown a bit, stacking the adapter outboard of where the splined hub used to be?
Just curious, as I'm already set to run either disc or wires, at will.
drambuie
Wow....you are VERY lucky that two of the members here have what your looking for! Most larger machine shops would not bother to run these parts because they would be a one off and not worth there time for set ups. However, there are plenty of small machine shops that would take the job. Most likely they would give the job to one of the Manual machinist for rough and finish turning and boring operations, then on to the Bridgeport vertical mill for drilling the bolt hole circles, counter bores and contouring milling around the bolt hole face. I machined many parts on a routine basis such as these on manual and CNC machines and quoted many jobs as well. Shop rates are at least $150 to $250 per hour depending on what part of the country your from. And I can promise you, you would forget about those hubs very quickly if you ever got a quote from a good machine shop. Not to mention the cost of material which by the way is not cheap! Notice how there are five blanks instead of four! That is factored in on all machining quotes as well. Any good machinist can work off a existing part you drop off to them without a drawing. It's called per part as opposed to per print. In any case your very very, fortunate to have a couple of really great guys offer you those parts my friend! Good luck with your Healey.
maxwedge5281
maxwedge5281
again, thanks for the help and yes i suppose that i was fortunate to find these parts on the forum and at a reasonable cost. randy, the Milidon swheels studs have a .480 knurl which is larger???? than the healey knurl. is there a drill bit size that you recommend to accomodate the larger knurl? thanks in advance..
... Notice how there are five blanks instead of four! That is factored in on all machining quotes as well...
Actually, there were six (6) blanks for six (6) finished hubs. No mistakes! I had probably already removed one (1) of the 45Lb blanks before I thought to get a picture ;)
Think about that too; 45Lbs to wind up with a part that just weighs a couple pounds when finished.
That was 15 - 20 years ago that I drilled out the rear hubs, and I've slept since then. Just measure the root diameter of the knurl, and pick the closest drill bit >>under<< that size. It couldn't have been anything special, because I had one on hand. Too small and you might crack the hub, too big and the stud may spin out. You'll figure it out ;)
drambuie
Yes Randy, starting with 45lbs of material and ending up with a part that weighs a few pounds...but think of the nice looking part you ended up with! Lol. One large machine shop I worked for had maintance crews just for shoveling all the large blue hot chips out of the bed of my Engine lathe for me as I keep cranking out parts, another crew would do the oiling and add coolent. Later on I opened a machine shop with my brother catering to the Printing industry, however we would never turn down a job such as the hubs you machined. Nice Job by the way!
Hangtown Healey
Perhaps there was more selection 30 years ago on off the shelf adapters. Did you try Advance Adapters? I think they are still in business and maybe they will make an undrilled one for you. My wheel off set is close enough to stock that it looks just right. Just lucky on the front I guess. I use a spacer on the back.
I think one of the patterns is the same as a Volvo.
maxwedge5281
maxwedge5281
randy, i just opened the box with the rear brake drums. they look great!!! thank you so much for the very good deal.. awaiting the front hubs which are enroute!
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
K TR2/3/3A Securing new brake disc to the front hub? Triumph 4
I Bug eye front disc brake conversion. Spridgets 5
Ohiobugeye Front brakes won't release after disc brake conversion Spridgets 10
K TR2/3/3A Front disc brake squeal.... Triumph 4
R BJ7 Front Brake disc hitting Austin Healey 12
Trevor Jessie Front brake line locating brackets [disc]. Spridgets 6
M BN4 prob with disc brake conversion[front] Austin Healey 2
L Denis Welch Front Disc Conversion Kit 100/6 Austin Healey 6
KVH TR4/4A Front Wire Wheel Hubs Differ from Disc Hubs?? Triumph 5
C Wanted 3000 Front Disc Brakes Austin Healey Classifieds 4
croz TR2/3/3A Moss Replacement front disc pads Triumph 3
steveg Front Toyota disc conversion now complete - photo essay Austin Healey 0
C Bugeye Disc Front Brakes FORUM Navigation Questions 0
C Bugeye Disc Front Brakes Spridgets 4
pkmh Dismantling BJ8 Front Hub From Caliper Disc Austin Healey 20
bighealeysource front disc brakes conversion for 100-4 Austin Healey 21
R TR4/4A Disc wheel studs front and rear TR4a irs Triumph 4
B front disc brakes- 66 sprite Spridgets 8
T Check list to convert to front disc brakes Spridgets 9
T Front disc brakes make a big difference? Spridgets 5
O Front disc's from a 63 Midget Spridgets 0
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
bighealeysource Front Brake Adjusters Austin Healey 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
G Rebuilding Front Seats Austin Healey 4
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
