TR2/3/3A Securing new brake disc to the front hub?
bobhustead
Torque specifications and torque wrenches serve two purposes and answer two questions. In the application you ask about, the question is "is THIS bolt tight enough to hold what it is supposed to without overstressing the bolt or the items being bolted?" You can find ASTM charts of torque values for various grades, diameters, lubricity and thread pitches of bolts on Google. The second question, applicable to head gaskets and the like is "are THESE bolts tight enough to hold what is supposed to be held and are the pressures applied by the bolts the same throughout the field?"
So, for your application, just look at the charts for the grades marked on the bolt heads.
Bob.
bobhustead
When you use the torque charts, by the way, it is the bolt diameter, not head size, that counts. I do not know which you used in your post and do not recall the size of the subject bolts.
Bob
CJD
Those are screws, and are actually redundant. Once the wheel lugs are tightened the rotor isn't going anywhere. As long as you snug them you're good.
T Some info on front Brake Drum Securing Screws Spridgets 5
nevets Condenser Securing Screw Austin Healey 14
drooartz MGB Securing MGB to a trailer MG 6
S Securing the jack with strap in BJ8 boot Austin Healey 11
RAC68 Source - Metal Clips for securing Convertible Top and/or Seat Covers Austin Healey 11
T Securing the Tonneau on a 3000 MkII Austin Healey 4
D BJ 8 Float Bowl securing bolt loose Austin Healey 6
GTP1960 TR2/3/3A Securing Door handle shaft Triumph 3
Bob_Spidell Securing Front Hub Bolts Austin Healey 8
R TR2/3/3A Securing the front fender beads Triumph 11
Editor_Reid Securing Bugeye Fiberglass Bonnet Spridgets 15
R securing heat shields Austin Healey 11
sjuengst Securing the top of the windshield frame Austin Healey 17
J Securing Springs For Convertible Top MK II Austin Healey 5
P Air filter securing mod Austin Healey 11
ekamm Securing the cockpit side fuel tank closeout Triumph 2
S TR2/3/3A tr3 glove box securing bracket Triumph 4
timbn2 engine securing points to engine stand??? Austin Healey 18
I Sourcing Core plugs in UK & securing windscreen Austin Healey 11
B MGA Axle Brake line MG 0
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
