TR2/3/3A Brake Line Flares
Joel M
I just read that the Automec brake line kits come with universal flares. Has anyone had issues with these lines? I connected and removed the brake restrictor and caliper bridge pipes fittings and don't like the look of the witness marks. It seems like a regular bubble flare would work much better in these locations.
CJD
The main difference in Triumph lines are the longer flare nuts. Do those lines have long nuts? Some of the lines sold by the big 3 suppliers had nuts that were too short, so the nut bottomed before the flares made contact.
J
Joel M
The Automec set I have has the long nuts so no problem with it bottoming out. The other issue is a few of the lines are too long. I would like to cut and then put a double or bubble flare as needed. Is there any concern with this?
DavidApp
In the kit I got the line from the 5 way block to the rear axle was too long. I did a larger loop by the jacking point to use up the extra line.
David
J
Joel M
I made up a bubble flare on a scrap line to test on the restrictor valve. I believe the witness mark indicates a proper match between line flare and fitting. You can also see from the picture that the valve port is not the same as those on the brake and clutch cylinders which would accept a double flare. I am going to give this a try and can replace the line if I have any issues.
sp53
I think 1 or 2 of the lines on the restrictor take a copper washer also and that looks like one. The stock British stuff is longer. Many auto stores have brake lines with the long ends that fit the old British stuff. Locally we have a large hydraulic shop that makes lines to match with a double flare. Those guys freak out on British stuff that only have a copper washer like the slave cylinder. I started making my own with a kinda cheap flare making tool.
Steve
J
Joel M
My restrictor is setup like the picture below. The two copper washers are on the fitting that goes between the main valve body and the 5-way.
K brake line flares Spridgets 9
Nelson Leaking brake line flares Spridgets 15
G brake line flares Triumph 16
S TR6 tr6 brake line flares Triumph 1
B MGA Axle Brake line MG 0
S TR2/3/3A brass fitting from a steel brake line Triumph 2
D Fuel Line Clip vs Brake Line Clip Austin Healey 2
B Brake Line Pictures Austin Healey 1
KVH General Tech Brake Failure--The Line Split Triumph 19
Lin Brake hard line question Austin Healey 4
M TR2/3/3A Brake Line Removal From the Left Frame Rail Triumph 14
R TR2/3/3A Brake Line Triumph 4
B TR2/3/3A Caliper brake line Triumph 10
Lin Brake line fittings Austin Healey 2
John Turney TR6 Brake Line to Front Calipers Triumph 4
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
FlyingCat Spitfire Brake line Triumph 8
RAC68 Hard Brake Line Compound Opinion/Recomendation Austin Healey 8
Vineyarder Austin Healey 100-4 brake line fittings Austin Healey 10
R Help with BJ7 front brake line routing Austin Healey 6
Rut Brake line routing Spridgets 21
AngliaGT '74 Midget - Best way to Replace Brake Line? Spridgets 1
M TR4/4A 67 TR4A, need brake line fitting specs Triumph 6
M Brake Line Lengths Austin Healey 1
J TR2/3/3A Spring loaded valve in the top of the 4 way brake line fitting? Triumph 3
Rut MGB Need some brake line clips? MG 9
J Brake line material Austin Healey 24
J Brake line pipe Other British Cars 5
DornTRoriginal TR2/3/3A Installation of Brake Line Clamps on Real Axel Triumph 1
PatGalvin TR2/3/3A Hard Brake Line Flaring Question Triumph 11
AHS TR2/3/3A Disc brake line routing Triumph 0
T TR2/3/3A brake line replacement Triumph 11
DornTRoriginal TR2/3/3A Hydraulic Brake Line Clips Installation Triumph 2
C Vacuum line routing for brake booster Austin Healey 5
M Brake line kits Spridgets 28
D TR6 76 TR6 Rear Right Brake Line Triumph 8
mgedit TR2/3/3A Brake Line Master to Banjo Connection LHD 56 TR3 Triumph 4
R Brake line nipple size Triumph 4
Tugboat TR2/3/3A TR3A Brake Line Triumph 2
J TR2/3/3A Brake line advice for my TR3 Triumph 5
luke44 Clip - Brake Line to Firewall Triumph 3
M TR6 Where does this TR6 brake line go?[pic] Triumph 3
W Off to the local shop... brake line bleeding Spridgets 2
W Problems!! Brake line bleeding and leaks Spridgets 5
D Brake line flush Austin Healey 13
T Wiring Harnress and Brake Line Routes Austin Healey 11
E BE Dual Brake Line Switch Assembly Spridgets 0
E BE w/dual line brake master....90 degree fitting? Spridgets 12
letemglow Brake line layout with dual master cylinder MG 6
