Vacuum line routing for brake booster
Chris_Masucci
Hi Folks,
Does anyone have a picture of the vacuum line routing for the remote brake booster on a BJ8? I can't seem to find a picture in Nock's set or my many books.
Cheers,
Chris
Patrick67BJ8
Let me knoiw if these work for you?
dougie
Here's another...
C
Chris_Masucci
Huh, just draped across the valve cover like that. Now I can see what that rubber thing for holding the two hoses together does! Thanks for the pictures folks.
C vacuum line routing Triumph 12
J Dizzy vacuum line, manifold drain lines routing? Austin Healey 7
M 1990 XJS Vacuum Line Routing Jaguar 1
M Vacuum Line on a 948 Spridgets 4
G TR4/4A Distributor Vacuum Manifold Hard Line Triumph 11
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
BJ8Healeys '72 Midget Vacuum Advance Line Spridgets 2
W BE vacuum advance line and fittings Spridgets 2
GTP1960 TR2/3/3A SU, H6 carb vacuum line connector? Triumph 2
Tinkerman TR2/3/3A 1960 TR 3A vacuum advance line installation Triumph 7
M New vacuum line Triumph 16
Tinkerman I Having A bad vacuum advance line day Triumph 5
Tinkerman TR2/3/3A TR3A Vacuum Advance Line Triumph 2
mrv8q TR2/3/3A TR3 Vacuum line Q Triumph 4
drooartz Vacuum line? Spridgets 5
angelfj1 petrol and vacuum line support Triumph 11
tony barnhill '63 Midget Hard Vacuum Line Spridgets 16
Bret Vacuum line fittings? MG 10
1 Novice question about vacuum advance line. Austin Healey 26
RobSelina vacuum and vent line diagram Spridgets 5
Sopwith_Camel MGA booster Vacuum MG 8
S TR2/3/3A Distributor vacuum advance hook up to the inner plate Triumph 9
S TR2/3/3A Vacuum Advance Union Size Triumph 1
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
drooartz MGB Question on timing and vacuum MG 11
B Vacuum at Idle Austin Healey 9
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
B Vacuum Source Austin Healey 4
WHT Vacuum Advance Pipe Austin Healey 7
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
JPSmit Today's question - vacuum advance Spridgets 2
Gliderman8 TR6 Vacuum Gauge Hookup Triumph 11
B Vacuum Advance Pipe Austin Healey 2
Twit TR4/4A TR4 AUC878 vacuum connections Triumph 7
J TR6 Vacuum Retard question Triumph 1
R TR6 Thermostatic vacuum switch Triumph 3
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
S TR6 TR6 Vacuum Issue... some help please... Triumph 8
S TR2/3/3A Vacuum leak Triumph 19
B Vacuum Servo Austin Healey 19
D TR2/3/3A Vacuum connection at Carb Triumph 23
6TTR3A TR2/3/3A Vacuum advance questions Triumph 2
E TR4/4A Vacuum connection on SU-H6 carbs Triumph 4
D TR2/3/3A Vacuum advance tube Triumph 6
C Distributer with no vacuum advance Spridgets 15
Griz Testing Vacuum Advance Austin Healey 5
J BJ8 Vacuum Advance - disconnected -RIGHT - when setting total advance?? Austin Healey 6
B TR6 Timing using a vacuum gauge Triumph 13
T MGB Vacuum advance and Electronic ignition conversion MG 5
SherpaPilot TR6 Vacuum Gauge Timing Triumph 5
