100-4 Timing and Vacuum
56HealeyDan
I am timing my 100-4 after servicing my distributor and adding a Pertronix unit. I've got several questions that have come up while doing the final tuning.
What would cause some air/fuel mixture to come out (mist visible) of the carb when I rev the motor?
What is the initial timing and max timing at higher RPM's for this engine?
And, should a healthy-lunged person be able to move the vacuum plunger with lung power alone?
Thanks in Advance
Dan Whitney
Olathe, KS
'56 100-4
glemon
I don't think I have ever been able to create enough vacuum to advance the spark. Timing should be in the factory manual. If you don't have one I can dig it out and look it up.
Michael Oritt
Dan--
I can't answer your first and last questions but as concerns ignition advance, assuming your vacuum and centrifugal advances are working correctly I suggest you follow normal procedures in setting timing and simply concern yourself with total advance. I shoot for 34 or so degrees at 3000 rpm's and clamp down your distributor, then take your car out for a run to check WT at speed and assuming no overheating carry on.
56HealeyDan
56HealeyDan
A severely belated Thank You to both of you. I have owned my car for a long time and I have never been able to use a timing light to set the timing because I can't get the light in the tight quarters. The car is running great, no over heating, etc. and it hasn't bothered me. But simply because my inquiring mind wants to know, how do you use a timing light on the 100-4?
Thank you and my appreciation will be shown much sooner in the future!
603000
The mist exiting the carburetor sometimes referred to as "spit back" occurs when the mixture is too lean. You can test for the proper mixture setting with the engine running. Lift up on the small vertical pin at the base near the front of each carb below the suction chamber. This pin raises the needle a small amount. With the pin pushed, in the RPM of the engine should remain even. If the RPM drops, the mixture is too lean. If the RPM raises and continues to climb, the mixture is too rich. Adjust mixture by raising or lowering the jet bushing.
Danny
56HealeyDan
56HealeyDan
Thank you Danny for your reply. I should have closed the loop on that 2022 post regarding mist coming out of the carbs. After making additional adjustments and ruling out some issues, I checked the compression and it was very low on 3 and 4. Took the head off and found the gasket failure between 3 and 4. My compression ratio is higher than stock.
Fast forward, solid copper gasket, a valve job to correct some shoddy Paeco work to make the ratios the same on all cylinders and it runs better than ever!
M 100-4 Timing Pointer Austin Healey 5
L 100 timing chain worn? Austin Healey 7
J 100/4 timing mark relocation Austin Healey 2
H 100 Engine Timing Chain Tensioner Austin Healey 3
mjobrien Timing Chain Tension for 100/4 Austin Healey 1
mbrooks 100 timing cover wanted Austin Healey 0
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
A 100/6 BN4 Restoration Austin Healey 7
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
A 100/6 BN4 Door Lock Austin Healey 15
R 100-4 Transmission Austin Healey 1
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
R Healey 100 Dipstick Stuck Austin Healey 12
T 100 BN2 Possible Ignition Issue Austin Healey 10
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R Big Healey 100 Head Austin Healey 4
G For Sale 100 Year Grille Badges Other British Classifieds 3
Guido36 Webers on a Healey 100 Austin Healey 6
R For Sale 100 engine block w/head Austin Healey Classifieds 3
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
A SOLD!! 1959 100-6 Austin Healey Classifieds 0
dougie '56 100-4 Racer For Sale Austin Healey 12
longbridgehealey SOLD!! 1957 100-6 BN-4 Austin Healey Classifieds 0
longbridgehealey Letting the 100-6 Go Austin Healey 26
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
C What to do with my late father's Healey 100 Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
andrea 100-Six Photo Album Links Austin Healey 1
prb51 Wanted Wanted...hardtop for 100-6 BN 6 2 seater Austin Healey Classifieds 1
prb51 100-6 Drum Brakes Austin Healey 9
S 1958 100/6 Bumper Brackets Color Austin Healey 2
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
Michael Oritt 100 Flywheel Weight Austin Healey 16
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
boxofparts 100-4 Engine Options Austin Healey 12
BoyRacer 6 cylinder flywheel on a 100 engine? Austin Healey 0
K 100-6 Interior Austin Healey 4
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
C Wanted Austin Healey BN2 100-4 Austin Healey Classifieds 2
R 100 Motor and Gearbox Available Austin Healey 2
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
