100 Engine Timing Chain Tensioner
Healeysince59
When I tore my engine down, it did not have the "Rubber Band" chain tensioner installed. I'm building it back up now and would like the group wisdom on the need for the tensioner. The cam sprocket I'm using is groove for the tensioner so I could use one. I ask because I am really lazy and it's going to be a real pita to install. I know some replacement sprockets are not grooved so at least some engines are built without them.
Marv J
mjobrien
I would install it, the chain if new will stretch a little and you will want that band in place to help take up slack. If the chain is old well better to have this in place.....
I did mine and with a little tugging and some rebuild oil it went on OK.
Michael.
R For Sale 100 engine block w/head Austin Healey Classifieds 3
boxofparts 100-4 Engine Options Austin Healey 12
BoyRacer 6 cylinder flywheel on a 100 engine? Austin Healey 0
BoyRacer Nissan/Datsun engine swap into a 100/4? Austin Healey 30
Dandare 100/6 Engine Backplate Austin Healey 4
W Looking for engine rebuilding 100-6 Austin Healey 12
B For Sale 1956 Austin Healey 100-4 SCCA big bore race car plus parts lot engine trans etc Austin Healey Classifieds 0
E For Sale Austin healy 100/4 complete engine Austin Healey Classifieds 4
L First 100 Engine Serial Number Plate Austin Healey 13
T Austin Healey 100 engine color Austin Healey 10
D Engine 100/4 Austin Healey 10
simon1966 A few shots from the 100 engine rebuild Austin Healey 18
A 1954 100/4 Engine specs Austin Healey 2
B 100-6 galley head engine - Do I feel lucky? Austin Healey 23
E How much should i pay for a complete 100/4 engine ? Austin Healey 4
C Help!!! Austin Healey 100-6 engine problem Austin Healey 2
A 100 engine main bearing cap nut question Austin Healey 0
5 How not to start a freshly rebuilt 100/6 engine Austin Healey 30
simon1966 The 100 engine Austin Healey 9
H 100/4 engine block Austin Healey 0
T 100 Engine Lifting Device Austin Healey 25
OZ_BN1 100/4 Engine Austin Healey 12
W Replacement frame engine mounts for a 100-6 Austin Healey 4
J 100-4 engine hardware Austin Healey 17
Z 100 engine/gearbox adaptor plate Austin Healey 3
andrea AH 100/6 Longbrige 1957 engine comp,Wiring Harness Austin Healey 9
G Early 100/6 engine, automatic transmission Austin Healey 2
H Need Healey 100 engine parts Austin Healey 4
HEALEYJAG 100-M engine on EBAY Austin Healey 2
T 1955 100-4 Engine Paint Austin Healey 8
AngliaGT TR6 TR6 Engine - $100 Triumph 5
mbrooks 100 oil leak from front of engine Austin Healey 3
mjobrien AH 100 - Chassis and Engine Numbers Austin Healey 8
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
A 100/6 BN4 Restoration Austin Healey 8
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
A 100/6 BN4 Door Lock Austin Healey 15
R 100-4 Transmission Austin Healey 1
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
R Healey 100 Dipstick Stuck Austin Healey 12
T 100 BN2 Possible Ignition Issue Austin Healey 10
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R Big Healey 100 Head Austin Healey 4
G For Sale 100 Year Grille Badges Other British Classifieds 3
Guido36 Webers on a Healey 100 Austin Healey 6
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
A SOLD!! 1959 100-6 Austin Healey Classifieds 0
