Chad Donner
Ok, I had my head rebuilt with new guides and valves and ever since I have been having oil coming out the exhaust when the engine gets hot (the exhaust flex hose smokes like it is getting saturated in oil). Below are a couple symptoms...
-I thought it could have been flooding the guides with oil so I rebuilt the rocker shaft which did have signs of wear. Problem still exists after the rocker shaft rebuild.
-I fitted valve guide seals, and still no help
-oil is coming from the rear exhaust only, rake of the engine?
-once the engine is hot and shut down, when I restart the engine there is a lot of white smoke for a while.
-I noticed some oil at the rear of the engine coming from around the head gasket, I verified it was not coming from the rocker cover.
-I am using 10w-30 break in oil after rebuilding the engine, is this too thin and possibly causing my issue?
I am very frustrated with this issue and don't know what else to try...
Thanks,
Chad
Thanks,
Chad
