TR2/3/3A Need help with a value for this TR3 please
Jerry
A friend is asking for a value for this TR3 he wants to sell. This one is a little different since it has a Pinto motor and transmission.
He has the front sheet metal, fender, hood, trunk, door to spare tire compartment, windshield, and other parts for it. The only serious rust that I know of is the area behind the doors and in-front of the rear fenders which is rather a normal place to rust out and easy to fix (they have the metal for that area). I’m sure you know all of that. I looked on line and the Pinto 2.0 engine has two horsepowers depending on the year. I do not know the year of the engine but I would imagine it would be easy to find out with the number on it. 1971 had 100 hp and 1972-1974 had 86. The front brakes are frozen so it does not move freely. I need to figure out how to unfreeze them so I can get it onto my trailer to transport it. From what you see how much do you think is a reasonable price for it?? I appreciate anything you can do to help me sell this and get one in better shape.
CJD
Total guess...I'd say $2k on the high side. I don't think there is a market for pinto Triumphs, so the money is in the Body and frame.
J
Jerry
1961 according to the owner. I just saw an engine for sale on ebay for $750.
bammons
Obviously needs lots of work and correspondingly money thrown at it. Then you have a Pinto powered TR. Looks like not too much other modifications done so a new owner might be able to source a used motor/transmission and go that route. But as John said $2000 would be reasonable because of all the unknowns and other money that will have to be put into it. At that price though it may be worth more in parts. Bruce
DavidApp
My one is a 1960 according to the Heritage trace and it has the straight shelf behind the seats. This one has the earlier style so that may mean it is earlier than 1961. Does it have a commission tag?
The floor looks odd in that area. A home brew floor replacement.
2K seems OK if the frame is in good shape.
David
malbaby
Assuming the chassis is in good condition, and although the car requires a complete restoration, I would think that $2k is too low.
D 68 Sprite value - need help Austin Healey 9
eschneider TR2/3/3A need help - value of TR2/3/4 engine & trans cores Triumph 8
5 T-Series Value of MGTC... need help MG 4
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
J MGB Need help identifying these parts MG 6
B MGB-GT Need help with MGB GT rattle MG 0
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
T Wedge TR7 engine, need help identifying part. Triumph 5
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
Bayless Login problem need help FORUM Navigation Questions 7
N Electrical Issues Need Help Austin Healey 8
vette Renewing Subscription, need help. FORUM Navigation Questions 1
F Help need reinstating my heater - BT7 Austin Healey 7
55modified Need photoshop help for side vent options on my BN1 Austin Healey 6
N TR6 Need a little wiring help with a 74 Tr6 Triumph 6
5 Need help to id Midget year Spridgets 2
J TR2/3/3A Need Help with 62 TR3A Triumph 6
C TR6 Need help with a 1969 triumph tr6 Triumph 21
55modified need help with custom air deflector for BN1 Austin Healey 12
S TR4/4A Help. I need the glove box latch part Triumph 3
K TR4/4A Need help with clutch issue... Triumph 2
L TR6 need help on long dead TR6 Triumph 16
Jim_Gruber Need help to figure out an easy solution for this one. Spridgets 13
GBRandy MGB 1971 MGB return to the road - need some help. MG 10
G Need Help: Oil leak/crankcase pressure Spridgets 18
B TR4/4A Need Help Finding Triumph 3
S Wedge Need help with TR8 no spark Triumph 7
P TR2/3/3A Need Help Identifying These Seats Triumph 6
M MGB MGB Special Tuning 4 Cyl Carbs - Need Help w ID and Replacement Needles MG 1
M TR2/3/3A Need Help With Carb ID On My TR3B Triumph 8
Zimmycobra TR4/4A Need timing help - please! Triumph 15
A Need help wiring my tach Spridgets 11
MKIII_Joey BJ8..need help.. Austin Healey 17
G Need some help identifying some E-Type parts please -- Jaguar 4
J MGB Need help identifying pistons for 18V motor! MG 0
B TR2/3/3A Need help with tr3 project Triumph 9
V General TR Need help with installing glass and new seal into my surrey top. Triumph 2
2wrench TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest. Triumph 9
Steve P. Need help with oil filters Spridgets 1
RickPA Need help installing steering idler oil seal Austin Healey 6
M TR4/4A Need help with TR4A brakes Triumph 10
Willie_P TR4/4A Alloy Valve cover: STUD SPECIFICATION - need help!!! Triumph 5
Rut MGB Need turn signal help MG 15
