Need help removing the pinion assembly from a late 1275 steering rack
M
MGNoir
My '74 Midget has been without steering rack gaiters for quite some time. I'm in the process of doing a front-suspension rebuild, and have completely removed the steering rack to rebuild, paint, and refurbish (including gaiters). I'm sure with the lack of gaiters there is a lot of crud in there.
My problem at the moment is that I can't get the pinion assembly out. I've completed all the dismantling steps in the Bentley manual (section J.10) and am at #23 - "Withdraw the pinion assembly and dowel". However it will not budge in the slightest.
Is it supposed to just slide out? I've soaked an inordinate amount of PB Plaster down into there, and I've put a set of vice grips around the splined section (with heavy leather to protect) and can't get anything to shift at all.
I also have tried using a punch from the opposite end to see if I could drive it out via the end plug opposite the splines. I get a tiny bit of movement and the pinion will lock up, but I'm afraid to keep doing that and destroy something.
I'm theorizing that the pinion shaft bushing is just stuck. If that bushing is actually press fit, I don't quite see how one could just "withdraw the pinion assembly and dowel" without some real force.
Any suggestions?
Jim_Gruber
You've got the later Triumph Rack I believe. The earlier racks come apart and that pinion gear is easily replaced. I did so on my '68 and it really tightened up the rack. Might be easier at this point just to replace the rack. Alan Fisher might have a used rack. frogeye@cox.net. NFI.
M
MGNoir
I'd considered the replacement approach, but kind of want to know if it's necessary or not.
Also, visually it is almost the same as the one in the Bentley Midget manual as shown below. Same rack layout, same brackets, etc. One difference is the shape of the rack housing just where the "1" line points. The illustration has a rounded end, mine has more of a "D" shaped end. Also mine has a hole in that end, whereas the Moss replacement (as an example) has that same shape, but no hole.
That said, if you look at the photos of this "late model midget rack" on eBay, you see both types: round and D shaped ends. > MG Midget, Midget 1500, Sprite, Steering Rack, LHD, Late Style, Original, !! | eBay <
Platinum
Soak that #5 dowel and area with 50/50 acetone/ATF. AKA: "Weasel Pi$$" for a day or two with frequent reapplication.
Platinum
Not trying to be pedantic about it, but the ATF/acetone mix has been proven a far superior penetrant to any of the "loose juice" commercially available.
M
MGNoir
I imagine it is. I'd rather let the commercial stuff soak a week before I go out and buy a quantity of two things I have zero use for beyond creating a tablespoon or so of mix.
Platinum
Understandable.
2wrench TR6 Need help removing glass from '74 TR6 windscreen. Triumph 13
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
J MGB Need help identifying these parts MG 6
B MGB-GT Need help with MGB GT rattle MG 0
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
T Wedge TR7 engine, need help identifying part. Triumph 5
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
Bayless Login problem need help FORUM Navigation Questions 7
N Electrical Issues Need Help Austin Healey 8
vette Renewing Subscription, need help. FORUM Navigation Questions 1
F Help need reinstating my heater - BT7 Austin Healey 7
55modified Need photoshop help for side vent options on my BN1 Austin Healey 6
N TR6 Need a little wiring help with a 74 Tr6 Triumph 6
5 Need help to id Midget year Spridgets 2
J TR2/3/3A Need Help with 62 TR3A Triumph 6
C TR6 Need help with a 1969 triumph tr6 Triumph 21
55modified need help with custom air deflector for BN1 Austin Healey 12
S TR4/4A Help. I need the glove box latch part Triumph 3
K TR4/4A Need help with clutch issue... Triumph 2
L TR6 need help on long dead TR6 Triumph 16
Jim_Gruber Need help to figure out an easy solution for this one. Spridgets 13
GBRandy MGB 1971 MGB return to the road - need some help. MG 10
G Need Help: Oil leak/crankcase pressure Spridgets 18
B TR4/4A Need Help Finding Triumph 3
S Wedge Need help with TR8 no spark Triumph 7
P TR2/3/3A Need Help Identifying These Seats Triumph 6
M MGB MGB Special Tuning 4 Cyl Carbs - Need Help w ID and Replacement Needles MG 1
M TR2/3/3A Need Help With Carb ID On My TR3B Triumph 8
Zimmycobra TR4/4A Need timing help - please! Triumph 15
D 68 Sprite value - need help Austin Healey 9
A Need help wiring my tach Spridgets 11
MKIII_Joey BJ8..need help.. Austin Healey 17
G Need some help identifying some E-Type parts please -- Jaguar 4
J MGB Need help identifying pistons for 18V motor! MG 0
B TR2/3/3A Need help with tr3 project Triumph 9
V General TR Need help with installing glass and new seal into my surrey top. Triumph 2
2wrench TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest. Triumph 9
Steve P. Need help with oil filters Spridgets 1
RickPA Need help installing steering idler oil seal Austin Healey 6
M TR4/4A Need help with TR4A brakes Triumph 10
Willie_P TR4/4A Alloy Valve cover: STUD SPECIFICATION - need help!!! Triumph 5
Rut MGB Need turn signal help MG 15
D Need help please Spridgets 4
