GT6 Diff Help Please
Darwin
Darwin
Bronze
I need to replace the pinion seal on my diff. It is a 3:27 out of a GT6 in a mk3 spit. The diff as far as I can figure out is a type D with the number on the bottom being KC71082. It has a castle nut on the Pinion shaft. As I understand it, there is no need to count threads when removing this type of nut. Correct?
What is the procedure for re-torqueing the nut?
How many foot-pounds of torque is needed?
Do I need to worry about pre-load? If so, how much is it and how do I check/set it?
That should do it for now. More questions will ensue I am sure. I know almost nil about diffs.
Darwin
Trevor Triumph
According to my Haynes book, the torque is 85 lbs ft, or is it ft. lbs.? Anyway the number is 85. As I read the entry it seems more or less, undo the bolt. take out the seal install and replace. I didn't notice anything about pre-load. Some members may have more accurate information.
Sarastro
Replacing the seal should not affect preload significantly, and even if it did, resetting it is a big job. Just torque the nut properly. I don't have the data, but the 85 ft-lb value sounds right to me. Just replace the seal, and as long as the diff was working correctly previously, it should work when you've finished.
The only problem you might encounter is locking the diff when you tighten the nut. I just got a piece of angle iron, drilled two holes in it, and bolted it to the flange so it prevented the flange from turning.
Willie_P rear diff crownwheel help Triumph 3
T Help with Diff Triumph 2
M Help to the newbie - Diff Whine Austin Healey 16
JPSmit Help #3 - diff + half shafts now Spridgets 2
B TR6 Help! TR6 Diff Mounts - poly or rubber? Triumph 12
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
skystryd Trans and Diff Spridgets 7
M TR4/4A Diff comparisons Triumph 2
N TR6 Triumph Diff which model??? Triumph 1
pbraun Wanted 3.9 diff for sprite Spridgets Classified 5
steve00136 MGB Diff refurbish MG 6
Tr3aguy TR2/3/3A Been a while Diff question? Triumph 4
D For Sale Detroit Locker Diff, Servo and Springs BN4 100/6 Austin Healey Classifieds 0
M TR4/4A Diff Conversion Triumph 3
T Diff Ratio BJ7 Austin Healey 5
Zitch TR4/4A Diff Fluid - GL4 Triumph 7
Sarastro General TR How is the axle tube attached to the diff housing? Triumph 16
K TR2/3/3A 3.45 Diff ratio? Triumph 7
B best diff British Motor Corp 5
wangdango '67 XKE rear diff? Jaguar 2
Jim_Gruber Bugsy IV decided to leaked out almost a quart of diff fluid Spridgets 6
B diff ratio British Motor Corp 3
B TR6 Should the poly diff mounts be snug to the studs? Triumph 2
Jim_Gruber Speedi Sleeve Install and New Diff Gasket Spridgets 5
69MGC MGC Diff Oil MG 1
69MGC MGC Rear Diff Cover Bolts Torque? MG 5
drooartz Diff pinion nut Spridgets 10
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
R TR2/3/3A Lockheed diff setup Triumph 6
Boink 3.9 diff and pinion seal Spridgets 2
Boink 5 speed vs. 3.9 diff - either or both? Spridgets 165
Michael Oritt 3.54 diff for sale Austin Healey 1
drooartz Diff pinion seal Spridgets 8
Rut Diff plug tool Spridgets 7
Geo Hahn General TR Diff Pinion Seal Triumph 5
Geo Hahn TR2/3/3A Paint Dab on Diff Cover Triumph 6
A TR4/4A Changing rear diff seals Triumph 15
K TR2/3/3A Lockheed Diff...why is it considered 'weak"... Triumph 3
Gordon_Dedrick TR2/3/3A Drippy Rear diff cover Triumph 6
JFS Wedge Diff Cover Gasket Adhesive Triumph 10
G Diff and trans oil Spridgets 8
C TR4/4A Diff gear wear Triumph 10
mgedit TR2/3/3A Lockheed Diff Oil Seal Replacement Triumph 10
K TR2/3/3A 4:1 Diff in a TR3? Triumph 3
steveg Limited Slip GM Healey Diff Austin Healey 4
DerekJ 11:39 Diff for sale. Austin Healey 0
H Noisy diff in BJ7 Austin Healey 2
K TR2/3/3A TR3 4:11 gears in rear Diff Triumph 6
zedvictor1 Spitfire different diff for Spit 1500 with overdrive? Triumph 1
