Wanted 3.9 diff for sprite
pbraun
My bugeye would be much happier on the 55 mph roads with a 3.9 diff. Anyone have one for sale?
Thanks!
Michael Oritt
Dunno if you found your diff but if not I have a 3.9 I would be willing to swap for an open 4.2.
Scargo
Michael,
If Peter doesn't take you up on this offer, I certainly will.
PM me if interested.
Boink
Bronze
Boy, I'm of the opinion that the 3.9 diff makes every bit as much a difference as the 5th gear (overdrive) with the Datsun tranny.
I've seen them, occasionally, on Craigslist for maybe $300 (?). No current leads.
Gearhead
I‘ve got one I’am in S Jersey
pbraun
pbraun
so, I am all set for now. Good luck!
bighly WTB 3.9 diff for Midget / Sprite Spridgets 13
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
Darwin GT6 Diff Help Please Triumph 2
skystryd Trans and Diff Spridgets 7
M TR4/4A Diff comparisons Triumph 2
N TR6 Triumph Diff which model??? Triumph 1
steve00136 MGB Diff refurbish MG 6
Tr3aguy TR2/3/3A Been a while Diff question? Triumph 4
D For Sale Detroit Locker Diff, Servo and Springs BN4 100/6 Austin Healey Classifieds 0
M TR4/4A Diff Conversion Triumph 3
T Diff Ratio BJ7 Austin Healey 5
Zitch TR4/4A Diff Fluid - GL4 Triumph 7
Sarastro General TR How is the axle tube attached to the diff housing? Triumph 16
K TR2/3/3A 3.45 Diff ratio? Triumph 7
B best diff British Motor Corp 5
wangdango '67 XKE rear diff? Jaguar 2
Jim_Gruber Bugsy IV decided to leaked out almost a quart of diff fluid Spridgets 6
B diff ratio British Motor Corp 3
B TR6 Should the poly diff mounts be snug to the studs? Triumph 2
Jim_Gruber Speedi Sleeve Install and New Diff Gasket Spridgets 5
69MGC MGC Diff Oil MG 1
69MGC MGC Rear Diff Cover Bolts Torque? MG 5
drooartz Diff pinion nut Spridgets 10
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
R TR2/3/3A Lockheed diff setup Triumph 6
Boink 3.9 diff and pinion seal Spridgets 2
Boink 5 speed vs. 3.9 diff - either or both? Spridgets 165
Michael Oritt 3.54 diff for sale Austin Healey 1
drooartz Diff pinion seal Spridgets 8
Rut Diff plug tool Spridgets 7
Geo Hahn General TR Diff Pinion Seal Triumph 5
Geo Hahn TR2/3/3A Paint Dab on Diff Cover Triumph 6
A TR4/4A Changing rear diff seals Triumph 15
K TR2/3/3A Lockheed Diff...why is it considered 'weak"... Triumph 3
Gordon_Dedrick TR2/3/3A Drippy Rear diff cover Triumph 6
JFS Wedge Diff Cover Gasket Adhesive Triumph 10
G Diff and trans oil Spridgets 8
C TR4/4A Diff gear wear Triumph 10
mgedit TR2/3/3A Lockheed Diff Oil Seal Replacement Triumph 10
K TR2/3/3A 4:1 Diff in a TR3? Triumph 3
steveg Limited Slip GM Healey Diff Austin Healey 4
DerekJ 11:39 Diff for sale. Austin Healey 0
H Noisy diff in BJ7 Austin Healey 2
K TR2/3/3A TR3 4:11 gears in rear Diff Triumph 6
zedvictor1 Spitfire different diff for Spit 1500 with overdrive? Triumph 1
T TR2/3/3A 2 questions on diff front pinion seal replace-TR3A Triumph 7
Willie_P Quick question: rear diff TR 3/4 Triumph 6
K TR2/3/3A Randall.....4:35 Diff in a TR3? Triumph 4
TRclassic3 TR2/3/3A diff free play tr3 Triumph 7
