TR2/3/3A 2 questions on diff front pinion seal replace-TR3A
TuffTR250
I am replacing the front differential pinion shaft oil seal on my TR3A. I have two questions I hope someone can help me with:
1) How do I go about removing the old seal?
(I don't have a puller that will fit inside the seal to pull it out.)
2) I have put a Speedi-sleeve over the pinion driving flange. Can I leave the flange piece on the Speedi-sleeve that is used to drive the Speedi-sleeve on?, or should I remove the Speedi-sleeve flange?
Thanks for the help!
Regards,
Bob
TR3driver
Great Pumpkin - R.I.P
I initially bought a seal puller from HF
but it broke immediately so I wound up just prying it out with a screwdriver. You have to be a bit careful not to gouge the bore in the housing, but it will work.
I've left the Speedi-sleeve flange in place, doesn't seem to hurt anything at all as long as the seal isn't riding on the break line between the flange and body of the sleeve.
Geo Hahn
I used that Harbor Freight seal puller to good advantage (as the Brits say) -- have used it 3 times in fact (2 TRs & a Healey).
But I am not as strong as Randall so I didn't break it.
TR4nut
If you have a Harbor Freight handy, I suggest buying this puller from them. It worked great for pulling the pinion seal on my TR4. Just enough room to snag the lip of the seal, and a couple of hammer raps and it was off.
T
TuffTR250
Thanks for the good ideas on pullers for the seal! Randall, from what I can tell the break line of the Speedi-sleeve is inside the outer sealing ring and outside the inner sealing ring. The inner sealing ring appears to be the one that actually does the sealing. I'll double check tomorrow to see if I can more definitely tell where the break line is in relation to the seal.
Regards,
Bob
PatGalvin
Hi Bob
If you are careful, you can simply drill a small hole on each side of the metal seal casing and thread a sheet metal screw into the casing. Then, pull on the screws and out comes the seal. It worked for me and saved me a trip to HF.
Pack some grease around the seal before you drill so you don't get shavings inside the diff.
Also, I did remove the flange on the Speedi-sleeve on my diff pinion shaft. I believe the flange is made to separate from the sleeve.
T
TuffTR250
I forgot that I had a seal removal tool stashed away like the one that Randall posted a picture. So I sorta used that. It would not pull the seal out and completely bent the tool out of shape. However, with that tool I was able to bend the seal enough to pry it out with screwdrivers, but what a job it was getting it out! The new seal went in good. I used several real large washers (same size as seal) and used the nut to push the washers and the seal went in easy and real straight. And no leak this morning!!!
Regards,
Bob
TR4eh
Just finished this job on my TR4A. The original leather seal was still on the diff and it wouldn't move when using the seal puller. Its quite a bit thicker than the replacement modern seal. I drilled 3/16" holes on opposite sides and threaded sheet metal screws through a steering wheel puller and out the seal came, easy peasy. I started the new seal using an old lay gear, then drove it the rest of the way with the pinion flange and a rubber faced mallet. I left the flange on the Speedi-sleeve.
T Setting up the diff carrier's gears questions?? Triumph 3
pjsmetana Spitfire Rear Diff, Spitfire Questions Triumph 16
Gliderman8 TR6 TR6 Diff questions Triumph 19
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
K General MG 1968 Midget Questions MG 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W General Tech 2500S starter motor and fuse box questions Triumph 3
KVH General Tech More Engine Rebuild Questions Triumph 15
P MGB 1980 MGB carb and oil questions MG 3
C My 2500M progress/questions thread TVR 5
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
K TR2/3/3A A couple of small distributor tech questions..... Triumph 10
B TR4/4A Dumb Bumper questions Triumph 4
B Two questions about Bugeye floor panel weld drilling Spridgets 15
C TR2/3/3A So many newbie questions any help is appreciated! Triumph 6
R TR6 Questions on emission tank-to-canister pipe Triumph 0
AngliaGT MGB-GT Couple of Dumb Questions - '67 GT MG 11
C TR2/3/3A Three completely different questions from a TR3B newbie - thanks for any input! Triumph 6
D TR2/3/3A More Fuel pump questions. Triumph 10
K TR2/3/3A Hard start questions.... Triumph 4
F TR2/3/3A back half to chassis questions Triumph 105
D Carpet Questions Austin Healey 2
J TR6 73 TR6 Static Timing Questions Triumph 6
glemon Spitfire Spitfire Questions Triumph 7
B TR4/4A General exhaust questions Triumph 17
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
Pythias Springs and ride height... Questions. Spridgets 2
L TR2/3/3A Engine removal questions Triumph 8
I Brake rod questions Spridgets 7
J TR6 2 Brake Questions Triumph 3
WJKB-TR6 TR6 '73 Ignition [IGN] Red Light questions. Triumph 6
K TR2/3/3A Couple of choke questions Triumph 1
T TR2/3/3A Questions on TR3A steering control head refresh Triumph 34
T TR2/3/3A Questions on fuel pump installation Triumph 7
C Non-Adjustable steering column questions Austin Healey 14
I Bugeye electrical questions Spridgets 17
Bayless Master cylinders questions Spridgets 7
B Seat Slide Installation Questions Austin Healey 14
Rut TR4/4A Rear end questions Triumph 8
P TR2/3/3A Chassis paint questions Triumph 8
R Jensen-Healey Fuel Tank Questions Other British Cars 17
doc50 1958 Nash metro door questions... Other British Cars 6
P TR2/3/3A TR2 color questions Triumph 23
steveg Holley fuel regulator questions Austin Healey 17
R Dash Install questions Austin Healey 31
T Tri-carb questions. Austin Healey 10
KVH General TR Type A Laycock Overdrive Questions Triumph 8
P BJ7 Carpet Install Questions Austin Healey 29
Talon TR2/3/3A Throttle rod link to carburetor; basic questions Triumph 4
