KVH
I have several questions with regard to the reassembly of my engine, etc.
1) the new timing chain tensioner pin that I bought would require a lock washer behind it in order for the rear face to be flush with the engine block--and the threading seems to demand a washer. None of the manuals or parts catalogs appear to show a lockwasher there, however, despite that, I feel I must use one and also some Loctite. Any feeling in that regard?
2) I have a new aluminum front engine plate. My old steel one has some “hole distortion” where the generator pedestal fitting goes. So, I intend to use the aluminum plate absent reports they are problematic?
3) I intend to install the front damper extension and torque it to spec while the engine is still on the stand. If I do that am I creating any problem when I drop the completed engine and transmission into the engine compartment?
4) I am once again curious about opinions for the front engine plate gasket sealer. I can use Permatex Aviation, Permatex High Tack, or Permatex Ultra Black. Any of those seem acceptable to me.
5) Same question for sealing the engine oil pan. I’m inclined to go with High Tack.
6) Finally, is there any thought as to how high off the garage floor my car frame should be when I’m reinstalling the engine and transmission. I’m about 12 inches off the floor and a transmission jack will slide under. Does that sound about right? I seem to recall pushing the tail of the transmission up by hand last time I did this, then shoving that rear support piece into place.
Thank you all.
(Sorry for the tome)
Thank you all.
