For Sale Brake caliper pistons Ceramic Coated and more
Got_All_4
You might say I leaped before I jumped but I purchased these and had them ceramic coated before I checked to see what type of brakes were on my 69 TR6. Someone had swapped out the calipers for a later set and of course these won't fit. The ceramic coating is for lubricity and corrosion protection. If you look at one of the pics there is a minor chip out of the rim and won't effect performance at all.
Won't split them to sell. $40 includes shipping to the continental US only.
I was going to list them on ebay but thought they should be listed here first.
Larry
PS
I have a lot of TR6 parts so no trannys maybe some tranny parts, fenders, straight bumpers that need chromed, oil pan
K TR2/3/3A Installing Brake Caliper pistons into the bore? Triumph 21
prb51 TR2/3/3A FYI TR3 Brake Caliper Seals/Pistons Triumph 0
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
K TR2/3/3A Further to brake caliper rebuild.... Triumph 2
K TR2/3/3A Brake caliper piston install? Triumph 18
K TR2/3/3A Brake caliper brake pad retaining plate bolt hole? Triumph 16
K TR2/3/3A The grease gun brake caliper piston removal trick..... Triumph 6
B TR2/3/3A Caliper brake line Triumph 10
M TR6 Front Brake Caliper Bracket Part Identification Triumph 0
M Wanted WTB Late model TR6 Front Brake Caliper Brackets Triumph Classifieds 0
K TR2/3/3A Front brake caliper mounting torque? Triumph 1
K TR2/3/3A Front Brake Caliper Shims Triumph 3
K TR2/3/3A Brake caliper hold bolts? Triumph 1
K TR2/3/3A 62 TR4 Brake caliper? Triumph 5
I TR6 Brake caliper question Triumph 7
C TR6 Leaky brake caliper Triumph 6
Jim_Stevens TR2/3/3A Brake caliper corrosion Triumph 5
Popeye TR4/4A TR4A front brake caliper rebuild - grease on rubber seals? Triumph 5
tr3guy TR2/3/3A Brake caliper with ?ball bearing? Triumph 5
R Correct Brake Caliper colour Austin Healey 9
T General Tech Brake caliper - piston stuck Triumph 4
HealeyRick Brake Caliper Upgrade Austin Healey 120
M_Pied_Lourd TR2/3/3A Brake Caliper Piping Triumph 2
T TR2/3/3A Wanted: Tr3a lft frnt brake caliper Triumph 3
Michael Oritt GT6 GT- 6 Brake Caliper/Mounting plate information needed Triumph 4
T TR6 Brake caliper lock after some driving Triumph 3
JFeher TR2/3/3A TR3 Type "A" front brake caliper rebuilding Triumph 17
M TR2/3/3A "59" tr-3a brake caliper Triumph 3
K TR2/3/3A TR3A Brake caliper thread chaser? Triumph 2
K Is there more than one type of 16P brake caliper? Triumph 14
K TR4/4A TR4A Girling Brake Caliper Taken Apart? Triumph 3
Jeepster New BJ8 - brake caliper fouls on wheel spokes Austin Healey 3
Darrell_Walker Wilwood brake caliper bleeders Triumph 12
B brake caliper color Triumph 5
doughairfield TR4/4A TR4 Brake Caliper Re-Assembly Triumph 9
S MGB-GT mgb gt brake caliper rebuild kit? MG 2
M Dunlop Brake Caliper correct color? MG 2
Phil73 Brake caliper issues Triumph 5
PatGalvin TR6 Need TR6 Brake Caliper Brackets Triumph 15
B brake caliper shims Triumph 16
M_Pied_Lourd TR2/3/3A TR3A Front Brake Caliper Choice Triumph 5
I TR6 TR6 - how many brake caliper shims? Triumph 26
TR6oldtimer TR6 TR6 Brake caliper part. Triumph 6
jjbunn Wanted: 16P LH Brake Caliper Triumph 21
T TR2/3/3A TR3b brake caliper options Triumph 4
S TR6 tr6 brake caliper rebuild Triumph 3
F Brake Caliper Rebuild Problems... Triumph 12
SCguy Braided Steel Brake Lines with Toyota Caliper Triumph 19
G Brake caliper cylinders MG 9
