TR2/3/3A Brand new brake caliper question...
karls59tr
Bronze
Installed the caliper...bled the brakes....good pedal...stops OK....it appears that one piston retracts fully but the outer piston does not return in completely like the inner one? Is this an issue? I'm using new pads and the rotor does not spin as freely as I would like but this just might be because the pads have not worn in yet. Was there a post describing the best way to break in new pads gradually?
mezy
brake calliper pistons should not retrsct when taking your foot off the pedal, there should be no gap between piston and pedal,
When you fitted the pads were they a nice slip fit into the caliper, did you use copperslip on the edges and back of the pad,
best way to brake in pads is to travel in second gear, dont take your foot off the gas pedal and left foot brake gently on and off,
K
karls59tr
Bronze
If the brake caliper pistons do not retract when you take your foot off the brake pedal then you are not going anywhere because your brakes would be locked up.
LarryK
As Nutmeg says, disks have a continuous contact on rotor. Sometimes rotor is harder to turn, but there is always contact. Car can still be pushed and roll down hill, but stops as soon as brake pressure is applied.
CJD
They do not retract...they relieve pressure on the disc when you take your foot off the pedal. If they visibly move back from the rotor, then the rotor has excessive runout (wobble). Technically they would be "pushed" back, instead of retracted.
Hamish Racing
There has been issues in the uk with the “rubber” dust protector “bellows” being to hard and pulling the piston back. Could this be it ?
As said above they shouldn’t “retract” but the pressure just relaxes. Excess play can appear with stub axle flex and we call that pad knock back after extreme driving.
in this instance I’d suspect the dust covers.
Try keeping the brake on hard - stick on the peddle for 24+hrs and see if that resets the rubber.
mctriumph
The tiny valve at the union where the lines split is supposed to hold fluid in the caliper lines so the pistons dont "relax" too much
perhaps you have an issue.
Also ,to beat a dead horse again, replace the old calipers with Wilwood units .Safety is not a thing you want to laugh off
for a couple of hundred clams. Just think of the luxury of getting ANY compound brake pad you wish! From high performance
to quiet street pads. Put your old bits under the bench for the day when the car goes off to a museum and is no longer driven.
Mad dog
K
karls59tr
Bronze
If I recall, disk brake pads should remain lightly in contact with the disk even when pedal is released.
Yes the caliper piston must pull back slightly to allow the rotor to spin.
Mad dog
I put a used brake pad that still had a lot of meat on it on one side of the disc.....works great.
L TRW-Lucas Brand Master Cylinders Austin Healey 2
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
S Steering Wheel Brand Austin Healey 5
TAS525 TR2/3/3A Brand New Generator Low Voltage Triumph 25
K TR2/3/3A Who owns the "Lucas " brand name? Triumph 7
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
Got_All_4 General TR Payen brand head gasket sets what's the difference Triumph 10
FredApplerot For Sale Pace Setter muffler for 1964-74 Spridget - Brand New Spridgets Classified 5
rr64 Wanted Reproduction of the Shelley brand lift jack decal shown Other British Classifieds 19
Rut 5 Speed clutch brand preference Spridgets 9
T TR4/4A clutch problem on brand new TR4a Triumph 6
exfed12825 For Sale Brand New Convertible Top MG Classifieds 0
Zitch For Sale FS- Brand new Black TR4 Deluxe Carpet Kit Triumph Classifieds 2
B Rear Seats - Do I have to drill screw holes through the brand new leather upholstery? Austin Healey 13
KVH General Tech Direction of Pistons for new County Brand Pistons from Moss Triumph 5
HealeyRick Want a Brand New Bugeye? Spridgets 7
C Has Jaguar regained your trust of the brand?? Jaguar 1
P TR6 Timing Chains-which Brand Triumph 4
aeronca65t Brand new E-types for sale! Jaguar 2
B TR6 Brand New Speedometer Cable breaks Triumph 5
Jer Brand New LBC'r Spridgets 13
I General TR Help on quality paint brand for steering wheel? Triumph 2
C Inner Sill Assembly Should i spend extra money on kilmartin brand??? Austin Healey 4
D Body filler brand??? Spridgets 26
bighealeysource Anyone use a EZ Car Lift brand on your Healey ? Austin Healey 6
rkep01 Brand new repro Sebring Sprite photos Spridgets 5
H QH brand fuel pumps MG 2
S Jaguar roars ahead with brand new app Jaguar 0
71TR6 No center cap retention in brand new Minilites Triumph 2
JPSmit anyone know about this brand? exhaust Spridgets 6
V What brand of antifreeze do you use? Spridgets 10
Michael Oritt Gasket brand Austin Healey 4
1 What type/brand of electric buffer or polisher... Spridgets 6
1 What type/brand of buffer/polisher... Triumph 30
healeyboz preferred clutch brand Spridgets 3
K Brand new Distributor Question Triumph 8
kindofblue Brand "New" Old Parts Triumph 2
Morris A brand new Cam post... Really Spridgets 18
G TR6 What is a brand new TR6 worth? Triumph 20
YankeeTR Incredible Stash of Brand New Triumphs For Sale!!! Triumph 2
KLUTZ "Tesh" brand mufflers MG 2
DNK Brand New 62 Hearald [NOT] Triumph 2
71tr Sway Bars - which brand? Triumph 6
M Moss Brand Head Studs for 1500 Spridgets 4
Sherlock Lola T70... Brand new again... Other British Cars 7
U Brand New '80 LE for sale on eBay [48 miles on it] MG 11
N MGB NEED YOUR ADVICE ON MY BRAND NEW [OLD] MGB MG 52
Johnny A brand new Mini British Motor Corp 8
B MGA Axle Brake line MG 0
