TR2/3/3A Who owns the "Lucas " brand name?
karls59tr
Bronze
Is it still the original owner from Britain or is it owned by a foreign enterprise. Should actual Lucas brand parts ie.points have the Lucas logo engraved on the base? If not are they actually Lucas brand or are they an aftermarket look alike brand? I received a set of points in a Lucas box but they were inferior in a number of ways?
Frank Canale
The roadster factory had a clearance sale and I bought 2 sets of points for the future. Just took a look at them. No lucas logo just have made in England stamped on them. I should have taken my time and checked to make sure what I was getting. They may work But I will probably source the real thing. Frank
Jim_Stevens
TRW had owned it, then sold to Elta Lighting Ltd. Elta is now trading under “Lucas Electrical”. So says Wikipedia. So I guess Lucas Electrical owns the rights to the Lucas name!
Jim
TS 44743L”O”
poolboy
Good or bad...nothing you find today will be the same "LUCAS" as in days of yore.
Nowadays you'll find "LUCAS" on all kinds of car parts. I recently bought "LUCAS" tie rod ends.
CJD
Wow, I never thought I’d see the day we look for Lucas over aftermarket. Repro’s have really gone down.
Rod-H
Bronze
Prior to my engine swap, I regularly used aftermarket points and condensers and they worked adequately. That said I always had a spare set in the tool kit. I'm sad that the aftermarket has gotten worse than Lucas.
Lucas Factory Motto - Home Before Dark
Rod
2long
There was a time (up to the mid to late 50s) when Lucas made very high quality components. You can almost tell by the style of box whether it’s the “good stuff” - the early red boxes with the stylized lion (?), then the plainer box, and then the green boxes. To me, green became a red flag!
Dan
theleisure Old News? Hubble Astronaut Owns Sprite [Vid Link] Spridgets 4
toysrrus Who owns an "AUSTIN AMERICA" out there? Other British Cars 31
J BMW still owns the Trumph nameplate..the question is? Triumph 1
J For Sale Lucas 75150A Wiper Motor Other British Classifieds 0
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
L TRW-Lucas Brand Master Cylinders Austin Healey 2
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
MGTF1250Dave T-Series Lucas Generator MG 1
T Lucas Flasher Unit Austin Healey 5
D Lucas Low-Tension Leads Austin Healey 1
Popeye General TR Connecting to Lucas switch grub screws? Triumph 5
Rob Glasgow Wanted Headlight Lucas Austin Healey Classifieds 4
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
B Wanted Lucas wing mirror Other British Classifieds 1
B TR6 Swapped Lucas to GM alternator Triumph 9
AngliaGT For Sale Lucas Headlight - used MG Classifieds 0
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
M Looking for Lucas parts catalogue British Motor Corp 13
AUSMHLY Lucas Generator C42 End Caps Austin Healey 3
B Delayed charging Lucas alternator Triumph 1
S Stag Lucas 18ACR alternator conversion Triumph 5
Lin Lucas coil question Austin Healey 8
red57 Lucas 1748 horns Austin Healey 19
B TR2/3/3A Lucas, SU, and the rest Triumph 3
K TR2/3/3A Do Lucas distributor points still have the" Lucas logo" on them.... Triumph 4
K TR2/3/3A What vehicle is this Lucas voltage stabilizer from? Triumph 8
F How do I get rid of "Lucas"? FORUM Navigation Questions 2
T Which Lucas dynamo does a BJ7 have? A C45?? Austin Healey 6
F T-Series Lucas m133 headlamp? MG 2
S BJ8 Ignition Switch - Lucas Part Number? Austin Healey 4
S Intermotor or Lucas Sport Coil ? Austin Healey 14
C General Tech Lucas Fog Lamps Triumph 2
K TR2/3/3A What is the little white fiber thing for that comes in the Lucas points box? Triumph 2
R LUCAS 17L Batteries for Healey 100s Austin Healey 3
C TR6 More fun with Lucas Triumph 5
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
AUSMHLY Led headlight conversion kit with Lucas headlight bucket Austin Healey 37
Michael Oritt Lucas 576 lights Austin Healey 4
J MGC Lucas alternator/regulator MG 3
Rob Glasgow Weird Lucas Headlight Austin Healey 7
CJD General Tech Boeing using Lucas parts? Triumph 7
D Wanted lucas wt618 Triumph Classifieds 0
Basil SOLD!! Lucas Spot and Fog lamps Jaguar Classifieds 1
H Lucas Prince of darkness Austin Healey 4
NutmegCT Lucas 432 bulb Restoration & Tools 6
T Lucas HF 1748 horn parts Austin Healey 5
T TR5/TR250 Question on Lucas Hazard relay Triumph 14
T Installing a Lucas 16 ACR alternator on Bugeye Spridgets 10
Patrick67BJ8 Lucas SLR Driving Lights installation Austin Healey 26
