Lucas Generator C42 End Caps
I've wondered myself. I'm gonna guess pot metal--similar to the shock/damper bodies--because I've never seen any dissimilar metals corrosion, like you sometimes see at shroud/wing joints.
PAUL161
Stay away from the brand name "Dynamator"! They're made in China and as equipment goes, their junk! I have a new one under the bench that doesn't work! Buy one of the British-made ones. They're expensive, but they look the same as the original dynamos and work as they should. Just an honest tip. PJ
pkmh Lucas 22900J-C42 Generator Austin Healey 2
MGTF1250Dave T-Series Lucas Generator MG 1
F TR2/3/3A C39 Lucas Generator Triumph 4
ArcticOne GT6 WANTED - LUCAS C40L DYNAMO / GENERATOR [1968 GT6] Triumph 4
T Lucas Generator Triumph 22
MGTF1250Dave Lucas 12V Dynamo / Generator Specifications Triumph 2
J For Sale Lucas 75150A Wiper Motor Other British Classifieds 0
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
L TRW-Lucas Brand Master Cylinders Austin Healey 2
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
T Lucas Flasher Unit Austin Healey 5
D Lucas Low-Tension Leads Austin Healey 1
Popeye General TR Connecting to Lucas switch grub screws? Triumph 5
Rob Glasgow Wanted Headlight Lucas Austin Healey Classifieds 4
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
B Wanted Lucas wing mirror Other British Classifieds 1
B TR6 Swapped Lucas to GM alternator Triumph 9
AngliaGT For Sale Lucas Headlight - used MG Classifieds 0
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
M Looking for Lucas parts catalogue British Motor Corp 13
B Delayed charging Lucas alternator Triumph 1
S Stag Lucas 18ACR alternator conversion Triumph 5
Lin Lucas coil question Austin Healey 8
red57 Lucas 1748 horns Austin Healey 19
B TR2/3/3A Lucas, SU, and the rest Triumph 3
K TR2/3/3A Who owns the "Lucas " brand name? Triumph 7
K TR2/3/3A Do Lucas distributor points still have the" Lucas logo" on them.... Triumph 4
K TR2/3/3A What vehicle is this Lucas voltage stabilizer from? Triumph 8
F How do I get rid of "Lucas"? FORUM Navigation Questions 2
T Which Lucas dynamo does a BJ7 have? A C45?? Austin Healey 6
F T-Series Lucas m133 headlamp? MG 2
S BJ8 Ignition Switch - Lucas Part Number? Austin Healey 4
S Intermotor or Lucas Sport Coil ? Austin Healey 14
C General Tech Lucas Fog Lamps Triumph 2
K TR2/3/3A What is the little white fiber thing for that comes in the Lucas points box? Triumph 2
R LUCAS 17L Batteries for Healey 100s Austin Healey 3
C TR6 More fun with Lucas Triumph 5
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
AUSMHLY Led headlight conversion kit with Lucas headlight bucket Austin Healey 37
Michael Oritt Lucas 576 lights Austin Healey 4
J MGC Lucas alternator/regulator MG 3
Rob Glasgow Weird Lucas Headlight Austin Healey 7
CJD General Tech Boeing using Lucas parts? Triumph 7
D Wanted lucas wt618 Triumph Classifieds 0
Basil SOLD!! Lucas Spot and Fog lamps Jaguar Classifieds 1
H Lucas Prince of darkness Austin Healey 4
NutmegCT Lucas 432 bulb Restoration & Tools 6
T Lucas HF 1748 horn parts Austin Healey 5
T TR5/TR250 Question on Lucas Hazard relay Triumph 14
