Lucas Flasher Unit
twas_brillig
The flasher unit recently failed on our BJ7, and I ordered a replacement from AH Spares. It wasn't an exact match but buddy Jeff installed it and everything worked. However, looking at the original (maybe from 1962; maybe later, but it had Lucas stamped on the exterior which the replacement did not), it appeared that we could maybe swap the internals around.
And Jeff successfully made the transplant this afternoon, such that we now have the flashing internals (about half the size of the original) installed inside the original casing. Relatively simple, as the retention of the internals is strictly mechanical and you spend a bit of time prying the metal contacts holding the 'base' in, and swap the bits.
A minor touch, but worthwhile, we think.
Doug
PS: don't be lazy/stupid like I have been for years: adjust your mixture. Jeff did so a month back (after years of running rich) and she sure runs a lot better.
Timely post. My flasher failed recently failed--blinkers, both sides, would only flash for a second or two then stop--and I have the 'Lucas' replacement sitting on the shelf. I'm considering doing the transplant, and this offers encouragement. I think, without bothering to measure, that the new flasher can is smaller than the OEM, no?
IIRC, there's three pinch crimps on the edge of the can. Did Jeff just flatten them with, say, pliers? How did he redo the crimps? I can see using a hammer, anvil and suitable drifts to both flatten the crimps and redo them.
I've had to replace a couple voltage regulators on my BJ8, and the repops come with a smooth, generic case with no 'character' whatsoever compared to the OEM Lucas. Fortunately, for once the repops have their fasteners correctly positioned and it's an easy swap.
T
twas_brillig
Dang! we tossed the after market 'can', so I can't measure, but visually they were identical external dimensions - the 'bases' were exact matches, so the barrel diameter has to be the same. I was doing other stuff whilst (this is for a British automobile!) Jeff did the transplant, but I'll ask him this afternoon regards which weapons of minor destruction that he used. Doug
T
twas_brillig
Chatted with Jeff this evening, and (hopefully I can remember his comments correctly):
- pried the two 'cans' apart with pliers and screwdriver
- no problem removing the phenolic base and attached circuitry from each 'can'
- he slipped an appropriate sized socket inside the original Lucas 'can' and used it to ensure that the 'can' was round
- when he installed the new internals in the old can, he was able to rotate it around to ensure that the contacts lined up properly
- he used a small ball pein hammer and an old anvil to keep the original 'can' round, and to tap the open end down to hold the replacement internals
Hopefully this makes sense!
Doug
T
twas_brillig
I dropped a note to AH Spares, and they may put this in their newsletter. Bob - add to this thread if you do try it. Thanks, Doug
J For Sale Lucas 75150A Wiper Motor Other British Classifieds 0
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
L TRW-Lucas Brand Master Cylinders Austin Healey 2
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
MGTF1250Dave T-Series Lucas Generator MG 1
D Lucas Low-Tension Leads Austin Healey 1
Popeye General TR Connecting to Lucas switch grub screws? Triumph 5
Rob Glasgow Wanted Headlight Lucas Austin Healey Classifieds 4
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
B Wanted Lucas wing mirror Other British Classifieds 1
B TR6 Swapped Lucas to GM alternator Triumph 9
AngliaGT For Sale Lucas Headlight - used MG Classifieds 0
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
M Looking for Lucas parts catalogue British Motor Corp 13
AUSMHLY Lucas Generator C42 End Caps Austin Healey 3
B Delayed charging Lucas alternator Triumph 1
S Stag Lucas 18ACR alternator conversion Triumph 5
Lin Lucas coil question Austin Healey 8
red57 Lucas 1748 horns Austin Healey 19
B TR2/3/3A Lucas, SU, and the rest Triumph 3
K TR2/3/3A Who owns the "Lucas " brand name? Triumph 7
K TR2/3/3A Do Lucas distributor points still have the" Lucas logo" on them.... Triumph 4
K TR2/3/3A What vehicle is this Lucas voltage stabilizer from? Triumph 8
F How do I get rid of "Lucas"? FORUM Navigation Questions 2
T Which Lucas dynamo does a BJ7 have? A C45?? Austin Healey 6
F T-Series Lucas m133 headlamp? MG 2
S BJ8 Ignition Switch - Lucas Part Number? Austin Healey 4
S Intermotor or Lucas Sport Coil ? Austin Healey 14
C General Tech Lucas Fog Lamps Triumph 2
K TR2/3/3A What is the little white fiber thing for that comes in the Lucas points box? Triumph 2
R LUCAS 17L Batteries for Healey 100s Austin Healey 3
C TR6 More fun with Lucas Triumph 5
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
AUSMHLY Led headlight conversion kit with Lucas headlight bucket Austin Healey 37
Michael Oritt Lucas 576 lights Austin Healey 4
J MGC Lucas alternator/regulator MG 3
Rob Glasgow Weird Lucas Headlight Austin Healey 7
CJD General Tech Boeing using Lucas parts? Triumph 7
D Wanted lucas wt618 Triumph Classifieds 0
Basil SOLD!! Lucas Spot and Fog lamps Jaguar Classifieds 1
H Lucas Prince of darkness Austin Healey 4
NutmegCT Lucas 432 bulb Restoration & Tools 6
T Lucas HF 1748 horn parts Austin Healey 5
T TR5/TR250 Question on Lucas Hazard relay Triumph 14
T Installing a Lucas 16 ACR alternator on Bugeye Spridgets 10
Patrick67BJ8 Lucas SLR Driving Lights installation Austin Healey 26
M TR2/3/3A Moss Lucas elektrik alternator install? Triumph 5
A TR4/4A Lucas parts Triumph 7
TulsaFred Moss Lucas Control Box/voltage regulator Spridgets 4
