Moss Lucas Control Box/voltage regulator
TulsaFred
I bought the expensive pre cleaned and pre adjusted Lucas control box for my bugeye. There is a write up on their site describing how and why they offer these at twice the price of the regular units. They specifically state that they adjust the regulator to limit voltage to 13-14 volts and that they know this is not the recommended setting as original (lucas control box tests state 15-16 volts).
Well, i did register charge when i installed the new unit (previously wasn't charging at all). However, I took for a drive last night (headlights on) and the battery drained and would not start the car. Got back home after pushing the car and popping the clutch to start.
I tested the generator and it puts out increasing voltage with increasing speed, registering 7.85 volts at idle but quickly up to 18 volts at about 2000 rpm or so. I stopped there, but surely would have kept going higher with rpm.
I hooked all back up and tested charging voltage at the battery with regulator in place. Shows 13.5 volts (in line with the 13-14 volts Moss specifies).
SO... what gives. It seems to me that limiting the voltage to 13.5 is insufficient to handle the load of the headlights, other lights, etc.
Thoughts ?
markberry
Hi Fred,
How old is your battery? you might need to take it to a battery shop and have it thoroughly tested. It might have a dead cell or two. 13.5 V from your charging system should be fine. that service MOSS provides in adjusting those voltage regulators is WELL WORTH THE MONEY btw :smile:!
nomad
I have a whole pile of RB 106 regulators that are probably good but would like someone to go through them and clean and adjust them. Be nice to know who could do that. I'll bet the old ones are more reliable than the new. I tried to adjust one that a PO had been fooling with and burned up a generator with. I fared no better and cooked a generator as well so now I'm a little gun shy.
Kurt.
smaceng
There used to be a guy who would convert your mechanical regulator to electronic....and it looked just like a std. control unit from the outside......was wilton electric. this is what 60 Frog has in it. Unfortunately the owner has passed in 2013. When I had my first BE, I went through numerous control boxes and generators! Anyone else ready to take up the slack!
Scott in CA
TulsaFred
TulsaFred
I called Moss technical support and spoke with Blaine (I prefer Moss for most parts due to the availability of tech support on 50 year old cars!).
He didn't think the control box was the problem and wants me to check the voltage while driving with headlights on, and also to check voltage while cranking, then report back. I'll check these things. Excellent resource.
However, I'm still thinking that setting the voltage at 13.5 may be the issue. Since current is directly related to voltage, the batter charge current at 13.5 volts is low relative to the charge current at 15+ volts as per the factory setting. The lower charge current may not be able to keep up with the drain from the headlights and fuel pump?Seems to charge fine as long as load is minimal.
M TR2/3/3A Moss Lucas elektrik alternator install? Triumph 5
angelfj1 C39 Lucas Dynamo rebuild - Moss armature does not fit Triumph 9
J Moss / Lucas Alternator Conversion..... Spridgets 17
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
shadowfever Moss Motors MG Midget seat covers Spridgets 6
Celtic 77 MOSS response issues Restoration & Tools 11
BoyRacer Moss Motors Center Consoles Austin Healey 0
T TR2/3/3A Moss uprated water pump Triumph 6
C Alternative to Moss's BMC Green Engine Paint Austin Healey 10
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
vette Latest Moss Motors Magazine Austin Healey 1
D MGB 3 Main bearing 1800 & Moss Supercharger MG 1
Basil MGB Moss Motors MGB - Jay Leno's Garage MG 3
K TR2/3/3A Moss Improved performance camshaft 851-051...... Triumph 0
BJ8Healeys For Sale Midget/Sprite nose section - used [Moss Motors P/N 455-145] Spridgets Classified 0
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
3798j General TR Moss Motors acquires Victoria British Triumph 10
J TR6 Moss HS6 SU conversion kit question Triumph 4
steveg TR6 Moss advance kit maximum advance question Triumph 13
K TR2/3/3A Coil nuts? The SW and CB nuts on a Moss gold coil? Triumph 3
Upland Moss build-a-paper car contest Spridgets 1
K For Sale Front cockpit dash rail...N/A at Moss Triumph Classifieds 0
BLong63AH Moss Supplemental Heat Shield Austin Healey 2
Jim_Gruber In need of 2 Fulcrum Pin Bolts - MOSS Has them on Back Order Spridgets 3
Carlos TR4/4A Moss rear spring distance piece 674-560 Triumph 16
JPSmit Stirling Moss - Sebring Sprite Spridgets 3
KVH TR4/4A Door Seals: Moss Part 249-607 Triumph 0
Simmo TR6 Moss Seats Triumph 0
K TR2/3/3A Installing Moss wheel spacers? Triumph 5
E Moss stainless exhaust offering. Austin Healey 28
R TR2/3/3A New Control head wiring - Moss purchase Triumph 1
Michael Oritt Moss Motors rear brake "set" Austin Healey 11
K TR2/3/3A Moss Europe has restored the Jabbeke TR2 Triumph 0
Jim_Stevens For Sale Pair of chrome tail lamp bases, NIB, Moss 159300 Triumph Classifieds 0
LarryK Moss Motors buys XKs Unlimited parts house. Jaguar 6
P Moss Motors front brake calipers [BJ7 to early BJ8] Austin Healey 8
K TR2/3/3A The "compensator bar" on the Handbrake...#53 in Moss diagram Triumph 5
Jim_Gruber New MOSS Tapered Front Wheel Bearings - WTH are the instructions Spridgets 16
GTP1960 TR2/3/3A Moss Crankshaft pulley failure Triumph 23
L 100/ Moss Heat Shield Austin Healey 2
mt10flyer TR2/3/3A Moss Steering Rack Conversion Triumph 26
Jim_Stevens TR2/3/3A Goodridge SS brakelines from Moss Triumph 3
R Moss permanently lubricated U-Joints Austin Healey 1
S For Sale TR6 New Moss 73-76 Seat Foam Kit Triumph Classifieds 0
M TR2/3/3A Fitting on Moss Brake/Clutch Masters Triumph 16
D TR2/3/3A Moss alternator kit Triumph 8
croz TR2/3/3A Moss Replacement front disc pads Triumph 3
