Moss Motors 5-speed install in a Bugeye Sprite
SNClocks
Member
It's amazing how that first drive makes all the work worth it. Installing the new T9 (well, new to our bugeye) from Moss Motors had it's challenges, not the least because the instructions that come with it are pretty vague at times. I figured I'd post a few pictures in the hopes that someone down the road will have an easier time.
The first big-gulp moment is when one has to cut out the original cross member/trans support. What would we do without the oscillating multitools? After marking where I thought the cuts should be the carbide blade made pretty short work of the sheet metal and cross member. Here is a really poor shot of the tunnel after removing the cross member.
And a shot of the piece that was cut out:
With that done it was no big deal to slide the two box-sections provided in the kit into the cut-off cross members. I powder coated the two box-sections, and then sealed them into the cross member with RTV to keep water out. Here are two shots of the final install with the new trans in place. You can see the inserted box-section on the right side, along with the sealant.
The speedometer cable comes out the passenger side of the T9, down fairly low, and close to the tranny tunnel. Here is a shot of the cable after I routed it through the tunnel wall:
I spent a bit of time scratching my head on where to route the cable - finally concluded the best was to send it right back into the tunnel, a bit farther back, so I could then find someplace to get it up under the dash.
You can see two of the bolts holding new transmission mount plate just in front of the speedo cable loop.
I was able to route the cable above the throttle pedal and the steering column by drilling up near the driver-side heat vent flap. Hopefully this shot makes some sense:
Worked slick.
Next I focused on cutting the tunnel up around the gear-shift opening so as to move the opening back about an inch. Probably the most challenging part of the install. But, it's done. Next I shortened the gear-shift lever that came with the box by 1 1/4 inch. Here is a shot of the shorter lever in place:
I'm now reinstalling carpet. Sort of neat - if I install the painted shifter cover over the carpet, instead of having the carpet cover the flange on the cover, it will just cover the opening!
Hopefully this will help someone in the future. I have to admit, I love the final result, but it is a bit of work.
BobHaskell
manual threading operation on the lathe, or powered? :smile:
Looks nice.
SNClocks
SNClocks
Member
Let's say the fat end of the gear shift lever did not exactly fit perfectly in the 3-jaw chuck. So, just used the lathe to hold the lever steady and manually cut threads. Would have been a lot easier if I could have used the lathe to cut the threads. But, flip side, it worked.
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
shadowfever Moss Motors MG Midget seat covers Spridgets 6
BoyRacer Moss Motors Center Consoles Austin Healey 0
vette Latest Moss Motors Magazine Austin Healey 1
Basil MGB Moss Motors MGB - Jay Leno's Garage MG 3
BJ8Healeys For Sale Midget/Sprite nose section - used [Moss Motors P/N 455-145] Spridgets Classified 0
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
3798j General TR Moss Motors acquires Victoria British Triumph 10
Michael Oritt Moss Motors rear brake "set" Austin Healey 11
LarryK Moss Motors buys XKs Unlimited parts house. Jaguar 6
P Moss Motors front brake calipers [BJ7 to early BJ8] Austin Healey 8
5 David Townsends Art At Moss Motors Spridgets 0
M TR2/3/3A Does anybody use the oils and lubes from the moss motors site? Triumph 3
doc50 TR2/3/3A Terminally Underwhelmed at Moss Motors Triumph 28
R General TR Shout Out & Kudos to Moss Motors Triumph 1
drooartz Off Topic Got to say, I'm thankful for Moss Motors MG 5
PAUL161 T-Series Shawn @ Moss Motors MG 0
PAUL161 Moss Motors T Series Parts - Bad Gaskets! MG 5
S Over arched Moss Motors leaf springs for Sprite MkIII Spridgets 33
Brinkerhoff T-Series Moss Motors and my 48 MG TC. MG 0
JimTR4 Moss Motors carpet sets Triumph 3
drambuie New Texas cooler fan by Moss Motors Austin Healey 0
PAUL161 Moss Motors Site Down? MG 3
ShawnC_at_Moss TR2/3/3A Win a Triumph TR2-4 Tourist Trophy Exhaust for Christmas from Moss Motors Triumph 1
T Moss Motors magazine Triumph 26
fogliner Moss Motors YouTube Channel MG 3
Reh Moss motors question Spridgets 4
P Moss Motors Flywheel Bolts Triumph 18
BobbyD Moss Motors TV Triumph 2
Tabcon No more Moss Motors! Triumph 4
angelfj1 Personal Contact at Moss Motors Triumph 6
TexasSprite BE Door Pockets from Moss Motors Spridgets 25
V Moss Motors Pub Not an April Fool Triumph 0
ronzet Chrome Schtuff from Moss Motors MG 20
ronzet Bumpers from Moss Motors Austin Healey 29
B Paint Stripped..now Moss Motors or Victoria Brit? Spridgets 7
Brosky Excellent customer service - Moss Motors Triumph 8
jlaird Moss Motors in their annual mag Spridgets 5
Bill Redd TR6 TR6 wiring - Moss Motors Triumph 10
Bret MGB Moss Motors EFI for the MGB! MG 3
C Expereince with Moss motors replacement body panels MG 13
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
Celtic 77 MOSS response issues Restoration & Tools 11
T TR2/3/3A Moss uprated water pump Triumph 6
C Alternative to Moss's BMC Green Engine Paint Austin Healey 10
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
D MGB 3 Main bearing 1800 & Moss Supercharger MG 1
K TR2/3/3A Moss Improved performance camshaft 851-051...... Triumph 0
J TR6 Moss HS6 SU conversion kit question Triumph 4
