TR2/3/3A Does anybody use the oils and lubes from the moss motors site?
Momikey
Does anybody use the Collector's Choice Engine Oil - 20W-50 and dash pot oil from the Moss Motors web site? Is it any good?
I thought if I just buy the oils , lubes and grease from there site and use them they should be good stuff for the car.
What do you guys think?
Also what about Lucas products are they any good? Oils etc?
Vila
I have never used any of the products you mention.
For the engine oil in both my 1962 TR4 and 1933 Chevrolet I am using Valvoline VR1 Synthetic 20W50 since it is a synthetic oil and has a high zinc level. I buy this on Amazon.
For my dash pots I use Penrite SU damper carb oil that I buy from Restoration Supply Company. It is my understanding that 3 in 1 Multi-Purpose oil also works fine in the dash pots, but I have never used it. The 3 in 1 is cheaper and I may buy it the next time I need some dash pot oil.
mrv8q
I bought MOSS's Pentrite steering column grease, because the bottle dispenser works well, and their SU damper fluid. This was probably 10 years ago, and I have plenty left...
Vaark01
I have used their Collector's Choice oil for 11 years and am very pleased with it. 20W-50 in summer and 10w-40 in winter.
Gerard Does anybody have a busted crank? Spridgets 3
longbridgehealey Does anybody know this car?? Spridgets 0
weewillie does anybody know British Motor Corp 4
BritCarFan Does anybody have .......? British Motor Corp 1
Morris Does anybody know.... Spridgets 5
G What is this and does anybody want it......free Triumph 6
G Does anybody have............. MG 20
L What does this column switch do? Spridgets 4
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
J MGB HELP, my horn does not work! MG 8
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
S TR2/3/3A overdrive does not function Triumph 45
Bayless How does '67 Sprite top attach to body? Spridgets 3
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
B General MG Does odometer record when flat towing. MG 5
Fanch00 Does it make sense to just paint the panels? Austin Healey 3
T Does a car lift exist that could be placed against a wall, and the car rolled sideways onto it? Spridgets 16
TomMull TR2/3/3A rear mount does not line up Triumph 10
K TR2/3/3A Cleaning the Solenoid contacts? Does pressing the small chrome "button" release the bake light fixture to access the contacts for cleaning? Triumph 7
JPSmit Fuel tank sender - how does it work? Spridgets 4
Got_All_4 TR5/TR250 New Hazard Relays Does Anyone know How to Hook Up Triumph 7
steveg TR6 Metal Dash - does anyone make one? Triumph 13
NutmegCT Does this ad seem a bit peculiar? Other Cars 8
S TR2/3/3A What does a condenser do? Triumph 21
pbraun How much does a BJ7 or 8 transmission weigh? Austin Healey 3
D Does this count as British car? Spotted 18
BN6_2197 How does the flasher unit work Austin Healey 4
J TR6 Does this sound ok to you? Triumph 5
BN6_2197 Analyzing Problem of Flasher Unit [warning lamp does not work] Austin Healey 10
B Does anyone still make or sell a quality condenser? Austin Healey 14
T Which Lucas dynamo does a BJ7 have? A C45?? Austin Healey 6
T TR2/3/3A Does this sound like fuel pump problem? Triumph 15
S TR2/3/3A The big brass drain plug on the OD does not thread in easily Triumph 9
F How does overdrive Annulus effect speedometer Austin Healey 10
T General Tech Transmission Countershaft - What Car Does This Fit? Triumph 1
D Does a BJ 8 need a vented fuel cap? Austin Healey 4
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
B MGA What does this founder mark mean? MG 4
D TR2/3/3A Gas tank does not fit! Triumph 4
Got_All_4 TR6 How does this steering lock come off Triumph 9
Gerry M TR6 Overdrive does not engage Triumph 13
HighAltitudeTR3 TR2/3/3A How does this sound?! [Video] Triumph 8
C TR6 ZS 175 What does this screw do? Triumph 2
HealeyRick Who Knew Martin Jansen Does Bikes? Austin Healey 0
Rut How much does a 1275 weigh? Spridgets 8
JPSmit Fuek Tank Sender - does this seem right to you? Spridgets 3
HighAltitudeTR3 TR2/3/3A How does this sound?? Triumph 6
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
simon1966 Does taking a stock BN1 and adding M bits increase its value? Austin Healey 10
