TR5/TR250 New Hazard Relays Does Anyone know How to Hook Up
Got_All_4
The Hazard flashers didn't work since I've restored it. Recently got a good switch that works and hooked up everything and they still didn't work. I figured it was the relay and I was placing an order anyway and got this. Moss part # 171-320. There are no instructions as to what wires go where. Anyone know how to set one up? I didn't open the bag in case I needed to return it.
Gliderman8
Look on the side or top of the relay; there should be a schematic showing the connections. Usually there two connections for the coil labeled 85 & 86.
The common connection is #30 NC (normally closed) is 87a and NO (normally open) is 87.
Gliderman8
Thanks for the link Elliot. That should help and there is no schematic on the side.
The schematic of the pin out is usually on the side or maybe the top. In any case, you have them now.
Got_All_4
Got_All_4
OK got my new relay in and with the addition of rebuilt steering column and LED upgrade on dash lights I finally got it all together. Tried the refurbished hazard switch first and nothing happened. No hazard lights. I can hear and feel the relay kicking in and it gets warm after a while. Noticed that the trafficator light doesn't work if turning on the left turn signal. Wonder if there is some relationship there. Looking at the wiring diagrams I see a hazard flasher unit. Never remember seeing one on my car. The turn signal one on the right side is the only one I know of. Don't even see where one can be mounted. I would think that with out it that the hazard lights would come on just not blink?
Got_All_4
Got_All_4
Daha! Found it. Was looking under the dash most of the time. Decide to take the relay out of my 69 Tr6 I'm restoring and saw the relay next to it. Took it out and installed it in the 250 and wahla I've got flashers.
SherpaPilot TR6 Hazard Switch Problem Triumph 8
T TR5/TR250 Question on Lucas Hazard relay Triumph 14
Got_All_4 Wedge Hazard siginals don't work!! Triumph 4
J TR6 Test 75 TR6 Hazard Switch? Triumph 12
tinman58 TR5/TR250 Hazard switch $189.00? Triumph 10
B MGB 79B hazard line fuse MG 1
T TR2/3/3A Hazard::TR3 bonnet stayrod assembly crack Triumph 1
JFS Wedge TR8 Hazard Flasher Triumph 15
F TR6 76 TR6 Hazard Switch Triumph 1
A Wedge TR7 Hazard Light Switch Triumph 1
R TR5/TR250 TR250 Hazard Switch Triumph 8
Jim_Newman Hazard warning lights Austin Healey 1
Woodie TR6 tr6 76 hazard flasher...not Triumph 8
L TR2/3/3A Hazard Flashers for TR3A Triumph 4
Mickey Richaud T-Series Hazard/Rear Window Defogger Switch MG 7
hondo402000 TR6 hazard flasher unit for 69 70 71 TR6 model Triumph 22
hondo402000 Hazard relay and hazard flasher question Triumph 9
M Leaking oil and fire hazard Triumph 11
RickB Hazard a guess? Sparky Carb Spridgets 12
T Voltage stabilizer, turn signal flasher, hazard Spridgets 2
QuickSilver MGB 77 MGB - Turn Signal, Brake Lamp and Hazard Issues MG 22
Woodie HAZARD LIGHTS Help please Spridgets 3
C TR6 TR6 Hazard Switches Triumph 2
dklawson Spitfire Spitfire - Hazard Switch Removal Triumph 3
John_Mc Hazard wiring dilemma Triumph 3
walshja me again, Hazard light switch Spridgets 11
Got_All_4 Any one purchased a 4 way hazard switch from VB Triumph 6
B Hazard Relay Pic Triumph 3
D hazard switch wiring ? Spridgets 1
MadRiver Lucas Hazard Switches Triumph 6
Steve1970 TR6 TR6 - Should turn signal work if hazard is gone? Triumph 8
MadRiver T-Series '68 Hazard Switch Question MG 4
A Hazard switch Triumph 11
H TR6 Where is the Hazard Flasher located on a '71 TR6? Triumph 8
I TR6 TR6 Brake line, hazard warning light not working. Triumph 3
M Spitfire hazard circuit diagram for 69 Spitfire Triumph 9
ecurie_ecosse Hazard Warning lights. Spridgets 4
M 87 XJ6 Turn Signal/Hazard Flasher Switch Problem Jaguar 16
H Esprit hazard switch needed Lotus 1
kyreb1862 T-Series Hazard Switch MG 2
RSMTR8 Wedge TR8 Hazard Lights Triumph 2
B T-Series bypass hazard switch MG 17
B T-Series pic of hazard switch MG 2
R6MGS TR6 TR6 Hazard lights Triumph 17
J Spitfire Hazard flasher on 78 Spitfire Triumph 1
R6MGS Hazard lights relay Triumph 4
RSMTR8 Wedge TR8 Hazard Lights Triumph 7
MrPandy TR6 Hazard switch wiring - '71 TR6 Triumph 7
S Turn signals and hazard lights... MG 5
Mark_Gibson TR6 TR-6 Hazard Switch Dress Up Ideas Triumph 3
