General MG Does odometer record when flat towing.
Brian1951
I will be flat towing my 77 Midget to Arizona. A 1000 mile trip. If the gearbox is in neutral will the odometer record miles while it is being towed? I don't want to disconnect the cable if it's not necessary.
NutmegCT
Brian - I think the odometer records the turns of the driveshaft. If the driveshaft is turning (forward), the mechanical odometer turns too.
If you've converted to an electronic odometer system, all bets are off!
YakkoWarner
I know with a lot of vehicles, flat towing even in neutral can be problematic because the transmission may not be lubricated when the engine is not running. Disconnecting the driveshaft is usually recommended for that long a distance but I confess I do not know the exact specifics for those transmissions. Disconnecting the driveshaft will also stop the odometer from rolling.
LarryK
Best to disconnect driveshaft at diff. Most European manuals reccommend it.
Sarastro
Bob's right on. If you tow it flat, disconnect the drive shaft at the differential, and all your problems are gone.
L What does this column switch do? Spridgets 4
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
J MGB HELP, my horn does not work! MG 8
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
S TR2/3/3A overdrive does not function Triumph 45
Bayless How does '67 Sprite top attach to body? Spridgets 3
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
Fanch00 Does it make sense to just paint the panels? Austin Healey 3
T Does a car lift exist that could be placed against a wall, and the car rolled sideways onto it? Spridgets 16
TomMull TR2/3/3A rear mount does not line up Triumph 10
K TR2/3/3A Cleaning the Solenoid contacts? Does pressing the small chrome "button" release the bake light fixture to access the contacts for cleaning? Triumph 7
JPSmit Fuel tank sender - how does it work? Spridgets 4
Got_All_4 TR5/TR250 New Hazard Relays Does Anyone know How to Hook Up Triumph 7
steveg TR6 Metal Dash - does anyone make one? Triumph 13
NutmegCT Does this ad seem a bit peculiar? Other Cars 8
S TR2/3/3A What does a condenser do? Triumph 21
pbraun How much does a BJ7 or 8 transmission weigh? Austin Healey 3
D Does this count as British car? Spotted 18
BN6_2197 How does the flasher unit work Austin Healey 4
J TR6 Does this sound ok to you? Triumph 5
BN6_2197 Analyzing Problem of Flasher Unit [warning lamp does not work] Austin Healey 10
B Does anyone still make or sell a quality condenser? Austin Healey 14
T Which Lucas dynamo does a BJ7 have? A C45?? Austin Healey 6
T TR2/3/3A Does this sound like fuel pump problem? Triumph 15
S TR2/3/3A The big brass drain plug on the OD does not thread in easily Triumph 9
F How does overdrive Annulus effect speedometer Austin Healey 10
T General Tech Transmission Countershaft - What Car Does This Fit? Triumph 1
D Does a BJ 8 need a vented fuel cap? Austin Healey 4
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
B MGA What does this founder mark mean? MG 4
D TR2/3/3A Gas tank does not fit! Triumph 4
Got_All_4 TR6 How does this steering lock come off Triumph 9
Gerry M TR6 Overdrive does not engage Triumph 13
HighAltitudeTR3 TR2/3/3A How does this sound?! [Video] Triumph 8
C TR6 ZS 175 What does this screw do? Triumph 2
HealeyRick Who Knew Martin Jansen Does Bikes? Austin Healey 0
Rut How much does a 1275 weigh? Spridgets 8
JPSmit Fuek Tank Sender - does this seem right to you? Spridgets 3
HighAltitudeTR3 TR2/3/3A How does this sound?? Triumph 6
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
simon1966 Does taking a stock BN1 and adding M bits increase its value? Austin Healey 10
D TR4/4A how hot does the timimg chain cover get? Triumph 15
D TR4/4A Does a bolt legend exist? Triumph 3
Rut How does this happen? Spridgets 9
Michael Oritt Does anyone drive with bias-ply tires? Austin Healey 40
simon1966 Does anyone use 48 spoke wheels on a 100? Austin Healey 21
T TR2/3/3A Does your rotor wiggle Triumph 15
M TR2/3/3A Engine does not shut off right away. Why? Triumph 8
B Does a 100 Six with no heater have demister vents? Austin Healey 5
