New MOSS Tapered Front Wheel Bearings - WTH are the instructions
Jim_Gruber
So in the mail today are a pair of Tapered Front Wheel Bearings from MOSS for $69.95. They no longer stock the old style of ball bearings. Included in hte kit are 2 sets of fron wheel bearings, new nut, cotter pin, grease, and a whole bunch of shims. And NO Instructions on how to fit the shims. Anyone get a "primer" on HTH to fit these puppies. There ae what we've been asking for but they do not feel substantial and heavy duty enough for our little cars. I hope I am wrong. And since I only trashed the DS accidentally trying to remove it to refit wheel studs any issue with only installing the Tapered Bearing on one side right now? Waiting on 1.5" Wheel Studs, it's Wednesday, super busy at work . and I need ot put this back together for thwe Dayton Show on Saturday AM. New Wheels and Tires will need to wait. Back is all done but it's a choice make the show or not. Bugsy will go on OEM Rims and AH Hubcaps. The new 8 Spoke Wheels and 175/70/13 tires will need to wait.
Jim_Gruber
Jim_Gruber
Oh and the MOSS Website has an Info Link on heir Web Site which I presume might take you to an How To Install Page. Link Goes nowhere. #$%#!$!.
Jim_Gruber
Jim_Gruber
Fairly Detailed instructions including how to modify the wheel Bearing Spacer to fit. Installing bearings used to be so much simpler. However the instructions keep referring prefitting and checking End Play needeing to be between .000 and .004. But they neglect to tell you how to check End Play. I'm guessing you need to measure between the Stock Keyed Washer and the new Castle Nut. Another Picture needed as part of the 6 pages of instructions. The bearing I trashed may go back in well lubed to go < 20 miles to the Car Show and Back.
Joe Schlosser
The tapered bearing setup was developed 20 plus years ago form an outfit called WE RACE. Similar kit that you are describing with the Moss stuff.
It is much stronger than the ball setup that came with the car. Tightening the spacer between the two inner races essentially strengthens the whole assy.
To do play you need a dial indicator placed against the disc, however you can do it by feel
With the right shims and the nut tightened all the way the endplay on the disc should be 0-4 thousand.
You do not have to be crazy with this, essentially with the right shims the hub will turn freely, not enough shims and it will lock up.
Too many and the hub will wobble.
It is very easy. On older American cars you would tighten the nut to X ft pounds and then backoff a little depending on the manufacture(maybe 1/4 - 1/2 turn.
Joe Schlosser
Jim
Forgot this
Adding and subtracting shims is easy. After installing hub and checking, Just remove nut and washer. just shake the hub a little and the outer bearing will come loose.
You just add/remove any shims on the spindle and put bearing back, tighten and check.
Whole operation should be about 5-10 min per side.
nomad
As BlueMax mentioned, the only way to do it right is with a dial indicator. Maybe able to borrow one since you are not likely to need it again. Fit too many shims and measure the end play. Figure how many shims needing removal to give the right spec. Job is done. Done it more than once on MGB's.
Kurt.
Jim_Gruber
Jim_Gruber
Define measuring end play. I know it is a simple concept but what exactly are you measuring and where are you measuring it?
Jim_Gruber
Jim_Gruber
Cool Thanks.
nomad
Yeah, I used to stick the indicator holder to the brake disc and measure off the end of the axle. That is after I put what I was sure were too many shim's in and torgued the axle nut.
Kurt.
Bayless
John must know more about MGs than even the factory did.
Jim, did you make it to Dayton British Car show? I skipped it and went to StreetRod Nationals in Louisville. They had a Streetkhana course that you could run as many times as you want and the line to run was only about a five minute wait. It was basically set up so that if your car hooked up well and braked well you could get a good time. Needless to say I was a bit off the pace in the bugeye. I could hit 45 seconds but the fastest cars were all the way down to 39 seconds. If I'd had a LSD I could have been more competitive. The organizers were amazed that the car was all stock suspension except for the front sway bar.
Jim_Gruber
Jim_Gruber
Trevor, I indeed did make it. 5 BE's in attendance including Don B from Ft Wayne with his Dark Green BE that was at the Fairfield Show, and Steve C from Indy who is a lurker on this list, a nice Medium Blue BE, Mark Masquelier, Bill M's brother from Dayton, and a nice Red w a White Hardtop BE that I never got a chance to introduce myself to. Steve C from Indy, and I didn't catch his last name. Bugsy definitely was the Ugly Duckling in the Crowd but a note I taped to the windshield garnered a lot of interest about his one owner interest. Lots of friendly people all interested in the BE's.
Bought myself a birth day present today a 20 ton press from HF. On sale this month for $179, got it for $144 by joining the HF Club. A pretty nice piece of kit that will be used on Wednesday to install new wheel studs up front on Bugsy.
Jim_Gruber
Jim_Gruber
An important safety note to the Team. I had Bugsy pretty high up in the air with axle stands under each side of the axle when I let the floor jack under the front way too quickly by accident. The sudden downward movement along with the scissors jack moving cause Bugsy to move forward and tip him up and off of the axle stands in the rear and to have Bugsy end up on top of the rear jack stands. When changing directions either up or down remember to go slow. On stand almost trashed my SU Fuel pump. Work smart. Quit when you get tired. Fortunately all was ok and thankful I had put the eBrake on tight before I started letting Bugsy down.
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
shadowfever Moss Motors MG Midget seat covers Spridgets 6
Celtic 77 MOSS response issues Restoration & Tools 11
BoyRacer Moss Motors Center Consoles Austin Healey 0
T TR2/3/3A Moss uprated water pump Triumph 6
C Alternative to Moss's BMC Green Engine Paint Austin Healey 10
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
vette Latest Moss Motors Magazine Austin Healey 1
D MGB 3 Main bearing 1800 & Moss Supercharger MG 1
Basil MGB Moss Motors MGB - Jay Leno's Garage MG 3
K TR2/3/3A Moss Improved performance camshaft 851-051...... Triumph 0
BJ8Healeys For Sale Midget/Sprite nose section - used [Moss Motors P/N 455-145] Spridgets Classified 0
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
3798j General TR Moss Motors acquires Victoria British Triumph 10
J TR6 Moss HS6 SU conversion kit question Triumph 4
steveg TR6 Moss advance kit maximum advance question Triumph 13
K TR2/3/3A Coil nuts? The SW and CB nuts on a Moss gold coil? Triumph 3
Upland Moss build-a-paper car contest Spridgets 1
K For Sale Front cockpit dash rail...N/A at Moss Triumph Classifieds 0
BLong63AH Moss Supplemental Heat Shield Austin Healey 2
Jim_Gruber In need of 2 Fulcrum Pin Bolts - MOSS Has them on Back Order Spridgets 3
Carlos TR4/4A Moss rear spring distance piece 674-560 Triumph 16
JPSmit Stirling Moss - Sebring Sprite Spridgets 3
KVH TR4/4A Door Seals: Moss Part 249-607 Triumph 0
Simmo TR6 Moss Seats Triumph 0
K TR2/3/3A Installing Moss wheel spacers? Triumph 5
E Moss stainless exhaust offering. Austin Healey 28
R TR2/3/3A New Control head wiring - Moss purchase Triumph 1
Michael Oritt Moss Motors rear brake "set" Austin Healey 11
K TR2/3/3A Moss Europe has restored the Jabbeke TR2 Triumph 0
Jim_Stevens For Sale Pair of chrome tail lamp bases, NIB, Moss 159300 Triumph Classifieds 0
LarryK Moss Motors buys XKs Unlimited parts house. Jaguar 6
P Moss Motors front brake calipers [BJ7 to early BJ8] Austin Healey 8
K TR2/3/3A The "compensator bar" on the Handbrake...#53 in Moss diagram Triumph 5
GTP1960 TR2/3/3A Moss Crankshaft pulley failure Triumph 23
L 100/ Moss Heat Shield Austin Healey 2
mt10flyer TR2/3/3A Moss Steering Rack Conversion Triumph 26
Jim_Stevens TR2/3/3A Goodridge SS brakelines from Moss Triumph 3
R Moss permanently lubricated U-Joints Austin Healey 1
S For Sale TR6 New Moss 73-76 Seat Foam Kit Triumph Classifieds 0
M TR2/3/3A Fitting on Moss Brake/Clutch Masters Triumph 16
D TR2/3/3A Moss alternator kit Triumph 8
croz TR2/3/3A Moss Replacement front disc pads Triumph 3
CessnaTPA Moss Bumpers Austin Healey 21
jfarris TR2/3/3A Moss LED Tailight Kit Triumph 4
T TR2/3/3A Moss ClassicGold mastrer Cylinder Triumph 18
histerical Moss king pin reamer Spridgets 13
