TR2/3/3A Brand new fuel pumps
TomMull
I agree also. The TR3 fuel pump is very simple old school technology, two valves and a diaphragm; easily rebuildable but a couple of caviats. If the seal for the shaft is bad (it usually is not) it requires the $60 plus kit. In addition, the shaft on the new diaphragm on the last one I bought was a stamped part with very sharp edges. unlike the original. It took a little hand work to smooth enough so as not to cut the new seal.
Tom
mctriumph
mctriumph
This "new " pump broke at the point where the diaphragm rod attached to the actuator arm. This stamped steel
arm just broke at .8 miles. The replacement has several mods to make what was bullet proof to trouble prone.
Sucks unless you like pushing more than driving.....
Mad dog
CJD
Bummer. New parts bite again. The only problem with rebuilding is they never include the oil seal in the kits. As long as the old one is reusable, you're good, but I have not found a supplier?!?
TomMull
I think the actuator in all the kits is stamped also and integral with the diaphragm. Seems to be the Achilles heel.
I'm not sure that seal is actually necessary. It might keep some oil splash out of the pump casting but no oil in the gas or vice versa, as long as the diaphragm is intact. I'm sure someone will correct me if I'm wrong. I've rebuilt several pumps leaving the old seal in place with no ill effects.
That seal does come in the expensive kits, TRF has them and others I suppose.
Tom
Popeye
Bronze
Not sure about the -2 or TR3, however I bought the “expensive” pump from TRF for my 4A. Made in Italy, and seems robust. (And yes, it was expensive; $200 vs. 40!)
mctriumph
mctriumph
Mama MIA ! Italian pumps? Heck It is by Michialiti after all. I have a sack of old OE pumps and will get some kits
to freshen them up .
Mad Dog
Popeye
Bronze
Mad Dog
The aluminum casting in mine had boogered inlet threads… I have kept the original pump, but it requires surgery before use
Popeye
Bronze
FWIW, TRF fuel pumps are on sale; I just got an email.
NFI, etc. I’m just a satisfied customer. They are expensive - so saving 50 quid is real money.
H QH brand fuel pumps MG 2
L TRW-Lucas Brand Master Cylinders Austin Healey 2
S Steering Wheel Brand Austin Healey 5
TAS525 TR2/3/3A Brand New Generator Low Voltage Triumph 25
K TR2/3/3A Who owns the "Lucas " brand name? Triumph 7
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
Got_All_4 General TR Payen brand head gasket sets what's the difference Triumph 10
FredApplerot For Sale Pace Setter muffler for 1964-74 Spridget - Brand New Spridgets Classified 5
rr64 Wanted Reproduction of the Shelley brand lift jack decal shown Other British Classifieds 19
Rut 5 Speed clutch brand preference Spridgets 9
T TR4/4A clutch problem on brand new TR4a Triumph 6
exfed12825 For Sale Brand New Convertible Top MG Classifieds 0
Zitch For Sale FS- Brand new Black TR4 Deluxe Carpet Kit Triumph Classifieds 2
B Rear Seats - Do I have to drill screw holes through the brand new leather upholstery? Austin Healey 13
KVH General Tech Direction of Pistons for new County Brand Pistons from Moss Triumph 5
HealeyRick Want a Brand New Bugeye? Spridgets 7
C Has Jaguar regained your trust of the brand?? Jaguar 1
P TR6 Timing Chains-which Brand Triumph 4
aeronca65t Brand new E-types for sale! Jaguar 2
B TR6 Brand New Speedometer Cable breaks Triumph 5
Jer Brand New LBC'r Spridgets 13
I General TR Help on quality paint brand for steering wheel? Triumph 2
C Inner Sill Assembly Should i spend extra money on kilmartin brand??? Austin Healey 4
D Body filler brand??? Spridgets 26
bighealeysource Anyone use a EZ Car Lift brand on your Healey ? Austin Healey 6
rkep01 Brand new repro Sebring Sprite photos Spridgets 5
S Jaguar roars ahead with brand new app Jaguar 0
71TR6 No center cap retention in brand new Minilites Triumph 2
JPSmit anyone know about this brand? exhaust Spridgets 6
V What brand of antifreeze do you use? Spridgets 10
Michael Oritt Gasket brand Austin Healey 4
1 What type/brand of electric buffer or polisher... Spridgets 6
1 What type/brand of buffer/polisher... Triumph 30
healeyboz preferred clutch brand Spridgets 3
K Brand new Distributor Question Triumph 8
kindofblue Brand "New" Old Parts Triumph 2
Morris A brand new Cam post... Really Spridgets 18
G TR6 What is a brand new TR6 worth? Triumph 20
YankeeTR Incredible Stash of Brand New Triumphs For Sale!!! Triumph 2
KLUTZ "Tesh" brand mufflers MG 2
DNK Brand New 62 Hearald [NOT] Triumph 2
71tr Sway Bars - which brand? Triumph 6
M Moss Brand Head Studs for 1500 Spridgets 4
Sherlock Lola T70... Brand new again... Other British Cars 7
U Brand New '80 LE for sale on eBay [48 miles on it] MG 11
N MGB NEED YOUR ADVICE ON MY BRAND NEW [OLD] MGB MG 52
Johnny A brand new Mini British Motor Corp 8
AndreL TR6 Conversion to electric fuel pump Triumph 14
