General Tech More Technical Questions—TR4
KVH
I saved up a few:
1) my new choke cable which is vinyl coated, and which has the “turn lock“ mechanism, appears to be a full foot too long. I’m reluctant to create a circular hoop just to take up the additional space, but I don’t think that there’s a way to adjust or shorten this cable. Does anyone have an idea why they made it so long?
2) when you test the oil pressure in a rebuilt engine, by cranking it with no spark plugs, what should the oil pressure be? I’m only getting about 40 psi doing that. Scares me. I got considerably more when I ran a test by spinning the oil pump shaft with a drill.
3) is there a new kind of jet needle being used in SU carburetors, one that moves laterally a bit on a spring to assure that it is always centered?
Thanks all
charlie74
Not sure about 1 & 3 but if you’re getting 40 psi o/p off the starter then you have nothing to worry about. When the engine is at idle speed, it will be much higher.
bobhustead
When I worked at a BMC dealership, as I recall, we would remove the inner cable and trim the inner and outer cables, then put them back together. Or maybe we would pull the inner cable out by the amount of protrusion we needed and cut them both together.
Don't see how spring mounted needles would work, but keep looking.
Bob
bammons
Recent.y installed a new choke cable and mine seemed too long as well. I left as much as I could under the dash and I made the loop that I hope is not going to hit the bonnet. I just turned my motor over for oil pressure using the new gear reduction starter and got 40psi as well. I asked on the forum about it and was told it was good. Bruce
Popeye
Bronze
Choke cable: yes, cut it. I assume it is always too long to make it a “generic” application for many uses - plus so many of our cars have been tweaked over the years. Cut carefully; best to separate the inner and outer. When cutting the inner cable it is best to sweat some solder at the cut, this will result in a clean end without frayed wires (and be easy to push through the outer housing.)
Bayless More Prefect Progress Other British Cars 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
C MGB More Weber help needed MG 27
DrEntropy More lessons in Japanese engineering Other Cars 7
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
KVH General Tech More Engine Rebuild Questions Triumph 15
AngliaGT A Few More Spotted 6
AngliaGT Saw a Few More Spotted 0
Bob Claffie More Village pics Other British Cars 0
Bob Claffie More Village pics Other Cars 3
M TR6 More noob questions… Triumph 14
Bayless More Paint Other British Cars 3
AngliaGT A Few More Local Vehicles Spotted 5
Basil More BMW Z4 trials Other Cars 21
AngliaGT A Few More I saw Yesterday Spotted 10
SteveTheBrewer Spitfire More rust repair Triumph 1
AngliaGT A Few More along Highway 220 Spotted 3
Bob Claffie More pics from Falls Village Festival Other British Cars 3
Sherlock Another cruise night, more interesting British iron Spotted 2
Y MGB More things that seem odd.... MG 2
D TR2/3/3A More Fuel pump questions. Triumph 10
jlaird MGB More on Bee's status MG 6
AngliaGT A Couple More Spotted 0
tr6nitjulius TR6 TR6 meeting my Demands & Giving Back more! Triumph 2
tr6web TR6 More leg room needed Triumph 5
Got_All_4 For Sale Brake caliper pistons Ceramic Coated and more Triumph Classifieds 0
Nelson No more MG Midgets Spridgets 3
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
K TR2/3/3A Auxillary Carb Return Spring in More BS about TR's. Triumph 0
K TR2/3/3A More pics of Kast Cam Triumph 4
K TR2/3/3A TR3A SU's More Pics Triumph 0
Ripper01 For Sale more TR-6 Used Parts Oct 2019 Triumph Classifieds 0
lbcspinners A- H Frog E: no more Bugeye oil leaks! Austin Healey 4
7 No more Bosch tools for me Restoration & Tools 4
D TR2/3/3A More small nuts [ and studs!] Triumph 2
C TR6 More fun with Lucas Triumph 5
Bayless More Sprite progress finally Spridgets 23
Bayless Even more progress - the Prefect Other British Cars 5
maxwedge5281 one more time.....mirrors! Austin Healey 14
Bob Claffie T-Series More or less TD action MG 0
R More Shroud to Scuttle install Austin Healey 4
Y MGB Answer to a question creates more new questions.... MG 12
K TR2/3/3A Auxillary carb return spring in "More BS about TR,s" Triumph 9
S TR2/3/3A little more door gap Triumph 14
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
D BT-7 tri-carb Two more questions Austin Healey 18
R TR2/3/3A One more crank pulley question Triumph 7
K TR2/3/3A More electrical....the Starter? Triumph 8
T TR2/3/3A Is there a timing cover seal that will last more than a couple of year? Triumph 23
