TR2/3/3A Auxillary carb return spring in "More BS about TR,s"
karls59tr
Bronze
Does anyone have a better picture, or maybe a sketch of this setup? It's on pg 16 of Bob Shaller's pamphlet on Triumphs. I can't quite make out what's been done to the connection at the throttle shaft in the picture. Looks like maybe some kind of vertical rod attached to the shaft?
Geo Hahn
Looks like the extra arm is brazed to the throttle shaft.
Are you looking at an original paper copy or an online scan or such (i.e. would a better pic help?
K
karls59tr
Bronze
I'm looking at an online version of the picture in the paper copy. So I need to braze say a 1&1/2" rod on to the shaft,drill a hole for the spring and fabricate a bracket that bolts to the air cleaner,correct? I've never done any brazing but I will give it a shot. The reason that I'm interested in this mod is that I'm having issues getting the idle to return to normal. I've read the posts on the various causes of this in a recent thread and I've done the required fixes with no luck. What worked for awhile was attaching a spring from the front of the throttle shaft to the horn bracket but still having issues of return to idle. I should mention that I have a fast road cam installed so I'm not sure the stock idle of 850 is appropriate? I get a steady idle at 1000 rpm but after a drive the idle wants to stay at 1500 rpm which seems a little too high. The 3 runs well enough and plug checks show tan colored plugs so I thought I'd try the center return spring set up. Any thoughts?
TR3driver
Great Pumpkin - R.I.P
Strange, p16 of my copy if "More BS" deems to be all cylinder head stuff. I don't see anything about an extra throttle return spring.
I question the wisdom of adding tension to that shaft anyway. It will put even more force on the front bushing, increasing wear and making the problem even worse.
CJD
It’s been a while since I read that book, but ISTR the aux spring going vertically from the linkage. The result was reduced load on the shaft while ensuring a consistent idle. The stock link puts a side load every time you open the throttle. A well positioned linear spring would counter and reduce that load.
K
karls59tr
Bronze
My mistake. Page 22...Fig.16
K
karls59tr
Bronze
I wonder if I could just hook a spring from the shaft "coupling" to the heat shield I have put on?
TR3driver
OK, I found it. It does look to be brazed to the shaft, but I think a copy of the front clamp-on lever would also work.
I've fought problems with returning to the set idle myself, found issues all the way from the nylon bushings in the firewall binding when they get hot, to wear in the bellcrank pivot allowing it to drag on the bolt head, to wear in the linkage pivot balls causing them to bind only at idle.
But the most common, for me anyway, is wear in the front shaft bearing/bushing allowing the throttle plate to drag on the bottom of the bore. That has been my main motivation for rebushing carb bodies twice now, and both times it made the problem disappear.
charleyf
The part that will suit your needs is called a Throttle Linkage Arm. You can buy these at several sources such as SPEEDWAY MOTORS. Part number 910-18400 std. ( $10) or 910-18410 Lite. This unit clamps onto the rod with set screws so no brazing is involved. You can cut off any excess length that you don't want. In your case you can vary the tension of the spring by the length of the arm or the size of the spring. As for a bracket to hold the other end of the spring you only need a small hole for the end of the spring to fit into. Like maybe the edge of the air cleaner.
Be sure to check the diameter of your rod and get the appropriate size arm to fit that.
K
karls59tr
Bronze
Thanks for the info.:encouragement:
K TR2/3/3A Auxillary Carb Return Spring in More BS about TR's. Triumph 0
K TR2/3/3A Auxillary carb linkage return spring? Triumph 2
K TR2/3/3A Auxillary dash switch pictures? Triumph 14
T TR2/3/3A Adding an auxillary fuse box to TR3 Triumph 5
tahoe healey Auxillary lights Austin Healey 15
H auxillary rear view mirrors Austin Healey 4
K Rockershaft Auxillary Oil Feed..Is it necessary ? Triumph 23
J TR 4 Auxillary Fuse Box Triumph 4
C LCB header with 1500 single carb inlet manifold Spridgets 1
Southwarks TR2/3/3A Carb balance woes Triumph 6
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
S Weber carb set Other British Cars 7
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
S Leaking HD6 Rear Carb Austin Healey 10
wangdango Carb Rebuild Necessity Austin Healey 3
M New Member with an HD8 Carb Question Austin Healey 1
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
G HD8 Carb Leak Austin Healey 7
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
G HD8 Carb Banjo Bolts Austin Healey 2
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
P MGB Zenith 175 cd carb damper oil MG 2
P MGB 1980 MGB carb and oil questions MG 3
K TR2/3/3A TR-3B carb question Triumph 13
E MGB MGB ZS Carb 175CD MG 4
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
D Carb Choke Cable Austin Healey 9
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
G TR6 Carb Spacer Triumph 4
S Carb Float Levers Austin Healey 9
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
D TR2/3/3A Another Carb question. Triumph 22
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
M TR2/3/3A Paltech SU Carb Rebuild--Problem Triumph 3
RGK TR5/TR250 SU carb ID help Triumph 6
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
jlaird MGB V6 carb help MG 14
71TR6 TR2/3/3A TR3A SU Carb rebuild opinions requested Triumph 12
E MGB SU CARB OIL 1965 mgb MG 3
Michael Oritt SU H6 carb for Le Mans--order of assembly of fuel bowl lid Austin Healey 2
D Tri carb: order of installation question. Austin Healey 5
Lotuswins Wanted TR4 H6 rear carb body Triumph Classifieds 4
E MGB SU carb air cleaners MG 10
Healey Nut Tri-Carb Project Austin Healey 213
doc50 For Sale Zenith carb, fits many cars. Other British Classifieds 0
tahoe healey Dumb carb question Austin Healey 23
