Weber carb set
Steyn
Member
This isn't another "What should I ask for..." post, more of a "Is this a bad deal..." (for me, that is). I have a pair of 40 DCOE 31 carbs (real, not Chinese) surplus to requirements, for which someone is offering to trade me an engine worth no more than US$440. That seems a bit low for a pair of genuine Webers listed as OE for an Escort Twin Cam. Anyone care to share an opinion?
Platinum
If I still had my Lotus Cortina Mk-I, I'd likely offer you $400 APIECE for those carbs, no questions asked! Troll some marque-specific sites to get a realistic evaluation.
waltesefalcon
That's a terrible deal. Walk away.
S
Steyn
Member
I'm sure if someone were to invest in some tuning parts, the same carbs would be applicable to a number of cars in the 2-liter range. These were originally part of a triple set that the PO assembled to use on a Volvo. Changed his plans and kept the odd one out for another car, and I picked up the rest of it some years ago, part of a package deal to get the manifold.
S
Steyn
Member
Just to follow up, I've had very little response outside of this forum, but did get some advice from people in the U.K. Why the eBay uk listings never showed up in my google searches, I have no idea, but they've been quite helpful. I'm so glad I took the time to ask before proceeding (before losing my shirt!) with his offer.
There are a number of twin Weber sets for sale on eBay uk, but very little in the way of 40 DCOE 31's. Everything I've seen so far has been thoroughly ultrasonically-cleaned, chemically-dipped, and/or soda-blasted, and the steel parts wire brushed, but the close-ups still show considerable fine pitting, so they were significantly corroded to begin with. (One pair actually had the exact model numbers "cleaned" off, possibly just over-zealous refinishing, but...) The prices are firmly in the £500-700 range for a pair, which is right in line with the US$400 apiece DrEntropy suggested, and mine are as-removed, original and unmolested, which is what I'd prefer myself if I were buying used carbs. I think I'm going to put them up at that range and just use the cash to fund my engine project.
Thanks to all who clocked in to prevent me making a costly mistake!
Platinum
S For Sale Triumph Weber DGV dual Carb Set Up - $325 Triumph Classifieds 0
pbraun For Sale Weber downdraft Carb & manifold Spridgets Classified 3
P For Sale Weber carb/intake, header Spridgets Classified 2
M_Pied_Lourd TR2/3/3A Weber Carb Installation Question Triumph 13
T Single Weber Redline carb for stock Midget 1275 Spridgets 12
L Best electric fuel pump for Weber DGV carb Spridgets 10
L Electric fuel pump for Weber DGV carb Austin Healey 3
E 1977 Midget Weber carb FORUM Navigation Questions 0
E 1977 Midget Weber carb Spridgets 1
R Weber carb hang-up at high rpm MG 0
M Weber Carb trick Spridgets 1
M weber carb rebuild HELP! Spridgets 50
P Help with choking weber carb! Spridgets 2
T MGB 1979 MGB with Weber carb MG 7
M Fuel pump rating for Weber DGV Carb? Spridgets 6
M Carb Conv Kit, Weber Single Downdraft conversion Spridgets 15
B Weber Carb tunibg MG 2
pjsmetana Weber 32/36 DGEV Carb Triumph 6
DarwinT Adjusting a Weber carb Spridgets 3
DarwinT Weber carb and possible vacuum hose Spridgets 10
M Weber DGV Carb Conversion for 78 MG Midget 1500 MG 0
M Weber DGV Carb Conversion for 78 MG Midget 1500 Spridgets 26
H Alfa Weber Carb Porn Other Cars 2
58Custom Seek opinions/experiences w/ Weber 32/36 DGV carb Spridgets 4
R weber 32/36 dgv carb -- holley equivalent? Spridgets 2
PAUL161 Weber Carb Diagrams & Parts Lists. MG 0
DanNagy TR6 TR6 Weber Carb Conversion Triumph 11
R 1500 mg midget, weber dgv carb & affect on timing Spridgets 9
T Weber DG carb jetting question Spridgets 16
G Vacuum advance with Weber carb, some tuning issues Spridgets 8
martyc MGB Help: 73 MGB w/ Weber DGV Carb - Popping Downhill? MG 9
DenverMGB Weber Carb 32/36 DGV - Choke Linkage? MG 18
Y Weber carb conversion, Midget 1500 Spridgets 21
tosoutherncars 1500 carb conversion to Weber DGV Spridgets 14
H Junkyard B with Weber carb MG 4
WidespreadPanic TR6 TR6 Weber Carb owners- a lil' help please Triumph 9
C Weber carb conversion AH 3000 Austin Healey 3
Monark192 Weber carb pic request MG 31
J Spitfire Spitfire 1500, setup for single Weber carb Triumph 2
J Setup for single Weber carb Spridgets 4
J weber DCOE 45 carb a bad idea? Triumph 5
S Weber 32/36 carb trouble! Other Cars 16
msoylemez Weber Carb Rebuilds Spridgets 5
C Newbie Tech Question- Weber Carb Spridgets 10
mylillooker Gulp valve, Weber carb Spridgets 4
E Weber Carb performance MG 23
A Weber Carb meets hood... Spridgets 3
R6MGS Weber Carb Parts...HELP! MG 4
L Weber Carb Kit on Ebay Spridgets 0
J Sprite Weber carb question and problem! Spridgets 9
