Weber carb conversion AH 3000
CASCADEWILLY
Member
Hi guys, I have an opportunity to buy some triple Weber carbs for a Austin Healey 3000. What do I have to do to prepare my stock 3000 BT7 for the conversion. Can I use the stock cam and lifters ? HELP !!
Depends on the manifold configuration; the offset manifolds that raise the carbs above the steering column on LHD cars require an additional hole drilled/tapped in the cylinder head (for each of the three manifolds).
Get more details and I may be able to offer you more information.
Simon TR4a
It is quite possible to use the carbs, though I think the benefit will be limited without other modifications to take advantage of the increase in breathing capability, i.e. porting the head and a better flowing exhaust.
You will also need a different linkage, of course.
The big issue is whether they are set up for a stock Healey or a modified car. The carbs are adjustable or tuneable by changing various components to suit a wide variety of applications, and some trial and error is needed to choose the best settings.
Apart from the main chokes, (the tubes the air goes through) the following parts may need to be changed:
Main jet, air correcvtion jet, emulsion tube, pump jet, idle jet, and auxiliary vent.
Since they are twin choke carbs you will need 2 of some of these items for each of 3 carbs, so it could get costly if you have to make several changes.
Do some research before you purchase!
Simon.
AJAX50
You will not get any significant improvement with a standard car. BUT it will use more fuel, it will sound great and it will look superb under the bonnet (hood).
Are you planning to use 45's or 40's. Either way you must get them set up on a rolling road by someone who really knows what they are doing, they must have a box full of the various jets. I've got triple 45's on a much modified engine, 210 flexible bhp, but 15 mpg!!!Still would not change back to the SU's.
M Carb Conv Kit, Weber Single Downdraft conversion Spridgets 15
M Weber DGV Carb Conversion for 78 MG Midget 1500 MG 0
M Weber DGV Carb Conversion for 78 MG Midget 1500 Spridgets 26
DanNagy TR6 TR6 Weber Carb Conversion Triumph 11
Y Weber carb conversion, Midget 1500 Spridgets 21
tosoutherncars 1500 carb conversion to Weber DGV Spridgets 14
S Weber carb set Other British Cars 7
pbraun For Sale Weber downdraft Carb & manifold Spridgets Classified 3
P For Sale Weber carb/intake, header Spridgets Classified 2
S For Sale Triumph Weber DGV dual Carb Set Up - $325 Triumph Classifieds 0
M_Pied_Lourd TR2/3/3A Weber Carb Installation Question Triumph 13
T Single Weber Redline carb for stock Midget 1275 Spridgets 12
L Best electric fuel pump for Weber DGV carb Spridgets 10
L Electric fuel pump for Weber DGV carb Austin Healey 3
E 1977 Midget Weber carb FORUM Navigation Questions 0
E 1977 Midget Weber carb Spridgets 1
R Weber carb hang-up at high rpm MG 0
M Weber Carb trick Spridgets 1
M weber carb rebuild HELP! Spridgets 50
P Help with choking weber carb! Spridgets 2
T MGB 1979 MGB with Weber carb MG 7
M Fuel pump rating for Weber DGV Carb? Spridgets 6
B Weber Carb tunibg MG 2
pjsmetana Weber 32/36 DGEV Carb Triumph 6
DarwinT Adjusting a Weber carb Spridgets 3
DarwinT Weber carb and possible vacuum hose Spridgets 10
H Alfa Weber Carb Porn Other Cars 2
58Custom Seek opinions/experiences w/ Weber 32/36 DGV carb Spridgets 4
R weber 32/36 dgv carb -- holley equivalent? Spridgets 2
PAUL161 Weber Carb Diagrams & Parts Lists. MG 0
R 1500 mg midget, weber dgv carb & affect on timing Spridgets 9
T Weber DG carb jetting question Spridgets 16
G Vacuum advance with Weber carb, some tuning issues Spridgets 8
martyc MGB Help: 73 MGB w/ Weber DGV Carb - Popping Downhill? MG 9
DenverMGB Weber Carb 32/36 DGV - Choke Linkage? MG 18
H Junkyard B with Weber carb MG 4
WidespreadPanic TR6 TR6 Weber Carb owners- a lil' help please Triumph 9
Monark192 Weber carb pic request MG 31
J Spitfire Spitfire 1500, setup for single Weber carb Triumph 2
J Setup for single Weber carb Spridgets 4
J weber DCOE 45 carb a bad idea? Triumph 5
S Weber 32/36 carb trouble! Other Cars 16
msoylemez Weber Carb Rebuilds Spridgets 5
C Newbie Tech Question- Weber Carb Spridgets 10
mylillooker Gulp valve, Weber carb Spridgets 4
E Weber Carb performance MG 23
A Weber Carb meets hood... Spridgets 3
R6MGS Weber Carb Parts...HELP! MG 4
L Weber Carb Kit on Ebay Spridgets 0
J Sprite Weber carb question and problem! Spridgets 9
