TR2/3/3A Weber Carb Installation Question
M_Pied_Lourd
Hi All,
Playing around with installing some Weber DCOE 42's on my 1960 TR3A.
I have a question on what I should do about the vacuum advance line from the distributor since there is no provision for this on the webers.
Should I cap it and run without? Thoughts on timing adjustments, dizzy re-curving etc if required?
Thanks for the help in advance.
Cheers
Tush
TR3driver
Great Pumpkin - R.I.P
That's pretty much the standard approach, just leave it off. No other changes to timing are required due to the lack of vacuum advance. It's mostly a fuel economy device anyway, and is only active at part throttle.
A friend of mine found a vacuum solenoid from another car, and wired it up to a microswitch controlled by the throttle linkage, so it only passed manifold vacuum to the advance when the throttle was open. He reported that it worked well, and picked a couple of mpg (about 10% lower fuel consumption).
TomMull
IMO, if you are going to run primarily on the street, you should tap into the intake for the vacuum advance. I do like Randall's friend's solution. Tom
TR3TR6
Tush, I'm running 40's DCOE"s on my TR3a and I just sealed off the vacuum at the distributor and it has worked really good.
M_Pied_Lourd
M_Pied_Lourd
Thanks guys. I appreciate it.
Terry, will do as you have and seal off the vacuum at the distributor as you suggest and give it a try.
Cheers
Tush
M_Pied_Lourd
M_Pied_Lourd
One more quick question.
I think that I have read that I can get away with hooking up only 1 of the 2 cold start (choke) levers. Is that the case?
Cheers
Tush
TR3TR6
Tush, when I first installed the carbs, that is what I did. I just hooked up the carb closest to the firewall. If the car sat for some time, I noticed it took more cranking to get it started using the choke; so I hooked up both of them and when I use the choke it takes right off. What I did was take a piece of brake line casing from a bicycle and cut it to fit between the carbs (keeps the choke cable straight) which works quite well.
TR3TR6
Tush, here is a picture of my choke setup.
M_Pied_Lourd
M_Pied_Lourd
Excellent, thanks again Terry. If you wouldn't mind, can you take or post a picture of your carbs looking at the filters. Looks like you have the same filters that my 250 has with triple 40 DCOEs . Do you know what length of velocity stack you have installed? I found that when I took the filters off my 250, the PO didn't run with any stacks. I understand that can be a big problem with DCOEs ....
Cheers
Tush
Jim_Stevens
Hi All,
Cheers
Tush
I shifted to a mechanical advance distributor. I was amazed at the increase in power that the DCOE's brought! Very noticeable, and worth the effort. Jim
TR3TR6
Tush, the velocity stacks I use are 3" long. I made the filters that you see on the stacks. The foam I used was too dense and it caused the carbs to run rich. Without the filters, the car runs great, but you run the risk of sucking dirt or something else in which could cause you some big problems. When I don't have the stacks on, I use a pair of K&N filters. Attached is a picture.
attachment.php
M_Pied_Lourd
M_Pied_Lourd
Very nice! Thanks again Terry. Will post a pic of mine when I finally get them installed and running.
Cheers
Tush
Simon TR4a
Tush, speak to Frank Manning, who has the same carbs on his TR4. He may also be able to help with things like jet sizes, emulsion tubes and air correctors.
I think the 40 and 45 mm sizes are much more common as the 42s went out of production many years ago, but seem a good size for an engine with 86/87mm pistons. (Not sure what the capacity of your engine may be!)
See you at BCD I hope!
Simon.
M_Pied_Lourd
M_Pied_Lourd
Hey Simon, great suggestion. I will speak with Frank at BCD. I love his car. I have 87 mm Pistons in my car. Yes, the 42s are quite old...not sure if you remember Brian Mills from the OVTC. He used to run them on his TR4.
Hope to see you at BCD.
Cheers,
Tush
S Weber carb set Other British Cars 7
pbraun For Sale Weber downdraft Carb & manifold Spridgets Classified 3
P For Sale Weber carb/intake, header Spridgets Classified 2
S For Sale Triumph Weber DGV dual Carb Set Up - $325 Triumph Classifieds 0
T Single Weber Redline carb for stock Midget 1275 Spridgets 12
L Best electric fuel pump for Weber DGV carb Spridgets 10
L Electric fuel pump for Weber DGV carb Austin Healey 3
E 1977 Midget Weber carb FORUM Navigation Questions 0
E 1977 Midget Weber carb Spridgets 1
R Weber carb hang-up at high rpm MG 0
M Weber Carb trick Spridgets 1
M weber carb rebuild HELP! Spridgets 50
P Help with choking weber carb! Spridgets 2
T MGB 1979 MGB with Weber carb MG 7
M Fuel pump rating for Weber DGV Carb? Spridgets 6
M Carb Conv Kit, Weber Single Downdraft conversion Spridgets 15
B Weber Carb tunibg MG 2
pjsmetana Weber 32/36 DGEV Carb Triumph 6
DarwinT Adjusting a Weber carb Spridgets 3
DarwinT Weber carb and possible vacuum hose Spridgets 10
M Weber DGV Carb Conversion for 78 MG Midget 1500 MG 0
M Weber DGV Carb Conversion for 78 MG Midget 1500 Spridgets 26
H Alfa Weber Carb Porn Other Cars 2
58Custom Seek opinions/experiences w/ Weber 32/36 DGV carb Spridgets 4
R weber 32/36 dgv carb -- holley equivalent? Spridgets 2
PAUL161 Weber Carb Diagrams & Parts Lists. MG 0
DanNagy TR6 TR6 Weber Carb Conversion Triumph 11
R 1500 mg midget, weber dgv carb & affect on timing Spridgets 9
T Weber DG carb jetting question Spridgets 16
G Vacuum advance with Weber carb, some tuning issues Spridgets 8
martyc MGB Help: 73 MGB w/ Weber DGV Carb - Popping Downhill? MG 9
DenverMGB Weber Carb 32/36 DGV - Choke Linkage? MG 18
Y Weber carb conversion, Midget 1500 Spridgets 21
tosoutherncars 1500 carb conversion to Weber DGV Spridgets 14
H Junkyard B with Weber carb MG 4
WidespreadPanic TR6 TR6 Weber Carb owners- a lil' help please Triumph 9
C Weber carb conversion AH 3000 Austin Healey 3
Monark192 Weber carb pic request MG 31
J Spitfire Spitfire 1500, setup for single Weber carb Triumph 2
J Setup for single Weber carb Spridgets 4
J weber DCOE 45 carb a bad idea? Triumph 5
S Weber 32/36 carb trouble! Other Cars 16
msoylemez Weber Carb Rebuilds Spridgets 5
C Newbie Tech Question- Weber Carb Spridgets 10
mylillooker Gulp valve, Weber carb Spridgets 4
E Weber Carb performance MG 23
A Weber Carb meets hood... Spridgets 3
R6MGS Weber Carb Parts...HELP! MG 4
L Weber Carb Kit on Ebay Spridgets 0
J Sprite Weber carb question and problem! Spridgets 9
