Weber Carb performance
Eric_C
Member
What kind of performance (gas milage) can one expect for a 1980 or so MGB that has a single downdraft Weber carb? /ubbthreads/images/graemlins/confused.gif
schutnik
I'm getting 25-30 depending on how I drive. That's with a 38DGES.
E
Eric_C
Member
Thanks for the reply! Wow! If I am calculating it correctly I am only getting around 12-15 miles, so clearly I have some adjusting to do. Any suggestions? Did you adjust your own carb?
schutnik
I did. But I just followed the weber instructions. Its still running a bit rich, so I think I'm going to adjust it again, this time using a vacuum gauge...
E
Eric_C
Member
I am so amazed at the difference, is 25-30 highway miles? If so, do you have an idea about your in-town mileage?
schutnik
In town is about the same for me. But, I don't drive in traffic much. Where I am, and where I typically drive, there's very little stop and go, so driving around town means driving about 35-40mph and stopping at the occasional stoplight or stopsign.
E
Eric_C
Member
Thanks again. There must be something way out of adjustment in my car. I will let you know if I get around to it soon.
Guinn
I am still not sure what I get with my 78B and a DGV carb but it seems to be around 22, mixed town and country but mostly country, mostly less than 10 miles per trip. Be sure your engine is tuned, tires properly inflated and lead removed from foot. The best indication of proper tune is spark plug color. Be sure you are using the proper plugs. Also check compression. Under 90 +- 10 could be a culprit.
Guinn
Guinn
ecutr6
Member
I have ridden with you!! Get your foot out of the carb, and come to a complete stop at those stop signs. By the way, I will take you up on the windscreen volunteering!! See you Monday. On the way to Yoders'.
E
Eric_C
Member
You have a point Ron, today I will try a regulated 50 miles trip to see the maximum I can get out of my car and will report back, w/o the lead foot!
E
Eric_C
Member
I just did a road test today, ran the car for 57 miles,around 60 mph, mostly in overdrive, all highway and then checked the gas useage and found I got 18.56 mpg, that seems below what your saying. Any suggestions?
Jay_Nickell
Member
I have a 1980 with OD, Weber 32/36, great compression numbers, and I get 22.5 mpg all city miles, burning 89 octane. I drive my car like someone is chasing me, and I'm not sure someone isn't, so why take a chance?
Guinn
Eric, you haven't said anything about how well the car runs, idles and accelerates. Also, does the exhaust smell rich when warm and idling? Black tail pipe? What are you using for an air filter?
If you haven't already tuned per this document, you should do so. It really is simple. You do need a fairly long slot type screw driver. Mine is about 8". If the car won't idle with the idle screw not touching the stop, screw it in the minimum that lets it idle at all.
Document: https://www.webercarburetors.com/ppw/html/tech/carburetor_set_up_and_lean_best_.htm
Guinn
E
Eric_C
Member
Jay, Thanks for your reply, from the sounds of it your cars performance it what I expected from my own, therefore I think it is time to find the problem.
E
Eric_C
Member
Thanks Guinn,
I rebuilt my carb about a year ago, use a foam filter that came with a custom filter and cover from Moss Motors. Have around 140 compression on each cylinder. It does smell gasy but all my MG's have smelt that way, perhaps that is why I haven't taken the hint. The tail pipe is black and what I have noticed is during the night driving when I step on the accelerator it looks very dusty in the rear view mirror, cannot see it during the day. Car idles evenly more or less around 800-1000rpm. Thanks for the link I am pretty sure I know what the problem is now that I have gotten the various replys.
E
Eric_C
Member
Guinn,
I replied to you message but it I did something wrong, did not show up. Wanted to say thanks as I think I will be able to solve the problem now and will definately look at the link. Eric
Guinn
Let us know how it does after you re-tune it, Eric. By the way, old mechs like my uncle Bud, a race car mechanic/driver back in the 30's and 40's, always smelled the exhaust before trying a new tune-up. Probably told him more about the engine condition than I would ever know. Might be why he only lived to be 86! /ubbthreads/images/graemlins/lol.gif
Guinn
Simon TR4a
Hi Eric, I hope you don't mind a Triumph guy jumping in on the MG board!
There is very little that can be adjusted on Weber carbs without changing internal parts, main jet, emulsion tube,air correction jet, pump jet etc. Only when these items are correct for the application will the car run properly and get reasonable gas mileage.
You probably need to take your carb apart and note down the tiny numbers on all the parts, then compare with the recommendations for your car on a website like Teglerizer or Pierce Manifolds.
A cutaway diagram of the carb is helpful, and again, can be found on the internet.
I do not have much knowledge of your carb, as my wifes Spitfire has a 40mm DCOE, but I think the principles are similar.Perhaps someone else with a similar setup to yours can give more detail.
Simon.
Platinum
Leaves me out... All DCOE, all the time.
S Weber carb set Other British Cars 7
pbraun For Sale Weber downdraft Carb & manifold Spridgets Classified 3
P For Sale Weber carb/intake, header Spridgets Classified 2
S For Sale Triumph Weber DGV dual Carb Set Up - $325 Triumph Classifieds 0
M_Pied_Lourd TR2/3/3A Weber Carb Installation Question Triumph 13
T Single Weber Redline carb for stock Midget 1275 Spridgets 12
L Best electric fuel pump for Weber DGV carb Spridgets 10
L Electric fuel pump for Weber DGV carb Austin Healey 3
E 1977 Midget Weber carb FORUM Navigation Questions 0
E 1977 Midget Weber carb Spridgets 1
R Weber carb hang-up at high rpm MG 0
M Weber Carb trick Spridgets 1
M weber carb rebuild HELP! Spridgets 50
P Help with choking weber carb! Spridgets 2
T MGB 1979 MGB with Weber carb MG 7
M Fuel pump rating for Weber DGV Carb? Spridgets 6
M Carb Conv Kit, Weber Single Downdraft conversion Spridgets 15
B Weber Carb tunibg MG 2
pjsmetana Weber 32/36 DGEV Carb Triumph 6
DarwinT Adjusting a Weber carb Spridgets 3
DarwinT Weber carb and possible vacuum hose Spridgets 10
M Weber DGV Carb Conversion for 78 MG Midget 1500 MG 0
M Weber DGV Carb Conversion for 78 MG Midget 1500 Spridgets 26
H Alfa Weber Carb Porn Other Cars 2
58Custom Seek opinions/experiences w/ Weber 32/36 DGV carb Spridgets 4
R weber 32/36 dgv carb -- holley equivalent? Spridgets 2
PAUL161 Weber Carb Diagrams & Parts Lists. MG 0
DanNagy TR6 TR6 Weber Carb Conversion Triumph 11
R 1500 mg midget, weber dgv carb & affect on timing Spridgets 9
T Weber DG carb jetting question Spridgets 16
G Vacuum advance with Weber carb, some tuning issues Spridgets 8
martyc MGB Help: 73 MGB w/ Weber DGV Carb - Popping Downhill? MG 9
DenverMGB Weber Carb 32/36 DGV - Choke Linkage? MG 18
Y Weber carb conversion, Midget 1500 Spridgets 21
tosoutherncars 1500 carb conversion to Weber DGV Spridgets 14
H Junkyard B with Weber carb MG 4
WidespreadPanic TR6 TR6 Weber Carb owners- a lil' help please Triumph 9
C Weber carb conversion AH 3000 Austin Healey 3
Monark192 Weber carb pic request MG 31
J Spitfire Spitfire 1500, setup for single Weber carb Triumph 2
J Setup for single Weber carb Spridgets 4
J weber DCOE 45 carb a bad idea? Triumph 5
S Weber 32/36 carb trouble! Other Cars 16
msoylemez Weber Carb Rebuilds Spridgets 5
C Newbie Tech Question- Weber Carb Spridgets 10
mylillooker Gulp valve, Weber carb Spridgets 4
A Weber Carb meets hood... Spridgets 3
R6MGS Weber Carb Parts...HELP! MG 4
L Weber Carb Kit on Ebay Spridgets 0
J Sprite Weber carb question and problem! Spridgets 9
