MGB 1979 MGB with Weber carb
TFR
Have a question... Guy I know brings his car over for me to investigate the cause of the car losing power on the high way. It doesn't pull well while accelerating or going up hills.
Checked the compression and it runs between 120 and 128 front to rear. Normal, so I understand is 125.
So I think it is the carb not tuned well. Does anyone know what jets are supposed to be in the carb.? I will post the exact model but I think it is a 40 DFAV. It could also be the accelerator pump...
MGZT260
I would check the following outside the carb first
*vacuum - if there is a leak it will affect timing
*timing - both at idle and increasing, doe s advance both vacuum and mechanical work properly
*fuel pump pressure - while at it check, replace or bypass for test the fuel filter
*proper spark at each cylinder - a MG will run on 2, just not very well
then look at carb
*is choke partially closed
*acceleration pump
*clogged jets or passages
*leaking gasket in carb assembly
Any of above may give off performance. If car ever worked fine I would not think jets are off. If car was relocated from sea leverl to Denver or reverse and symptons started then surely attempt to adjust jets , but a simple rebuild of the carb (is anything really simple) may reveal deteriorating rubber gaskets throughout due to today's alcohol content (or MTBE) in gas that this car was not designed for.
Sebring222
Was this a persistent problem or did it just recently occur? When was the Weber installed? Confirming that timing is correct and that the distributor is in excellent condition would be first steps. Are the valves set correctly? Is the fuel pump working correctly? Is there corrosion in the fuel tank clogging the filter? I think you'll find that the problem has little or nothing to do with the carb.
T
TFR
Guys,
Hope this doesn't cause you to stop helping but I am a TR guy so I don't have much experience with a MGB. However I do know engines and all of your suggestions are valid.
Could someone let me know the proper static timing. Also how much advance is normal. Is the fuel pressure supposed to be 3.5 #?
Thanks
T
TFR
Worked on the car most of yesterday and found that the ignition timing was way too far advanced. Not able to know the value but the timing mark on the lulley was at least 1.5 inches past the timing plate above the pulley. Retarded the timing back to 10 deg static and took it for a drive. It seemed to perform as it should.
Moving on to the rest of the issues on the car. Brakes and clutch...
jpetersen5
Hello,
I have 76 MGB that was rebuilt in 2014. I purchase the car in 2018. I was told that it was in a garage for two years. When I purchased it. I have done the following:
  1. replaced a new weber dgv carb with standard jets.
  2. Replaced distributor with 45d electronic spark
  3. High performance coil
  4. New plugs and wires. Gapped correcly.
  5. New alternator.
  6. Set timing at 13 deg. Timing light.
In the beginning, the plugs would get fouled with soot but not oily. I did a compression check and it showed that it was within spec. So, I did the above changes but it did not stop the spark plugs from fouling. I was told after this that with rebuilds that the newer cams required the timing to be advanced. So, I advanced the timing to 22 deg and adjusted the carb and the fouling problem went away.
So, my question is that does this make since and by advancing the timing will this cause any long-term problem.
Also, I have also had a problem with run-on. I check the function of the run-on valve and it works when the engine is turned off. I have repiped the valve serval different ways and it does not help. The run-on has always been a problem.
Thank-you for any help.
JP
boxofparts MGB busy tach on 1979 MGB at 75 mph MG 3
wingsandwheels For Sale 1979 MGB for sale MG Classifieds 0
wingsandwheels MGB 1979 MGB coil w/ altered wiring MG 6
N MGB 1979 MGB exhaust replacement. MG 1
A MGB 1979 MGB Flasher Big Headache MG 3
R MGB Testing temp sending unit 1979 MGB MG 6
C MGB 1979 MGB Zenith Stromberg Carburetor MG 3
1979Roadster MGB 1979 MGB SITTING FOR 17 YEARS MG 12
C MGB 1979 MGB steering wheel socket? MG 1
C MGB 1979 MGB door mirrors MG 4
C MGB 1979 MGB Photos MG 6
PAUL161 MGB MGB 1979 MG 2
P MGB 1979 MGB NEWBIE fuel tank replacement MG 7
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
humanoid For Sale - Haynes Triumph TR7 (1975-1979) Owners Workshop Manual Triumph Classifieds 0
T 1979 Datsun 210 at U-Pull in West Palm Beach, FLA Spridgets 1
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
FlyingCat Wanted 1979-80 Spitfire Radiator Mount Bracket and Cradle Triumph Classifieds 0
N For Sale 1979 Triumph Spitfire Triumph Classifieds 2
Morris For Sale Fuel Injected 1979 MG Midget Spridgets Classified 0
Z MGB 1979 Timing problems after removing distributor - Help Please! MG 28
T Spitfire 1979 Triumph Spitfire 1500 Triumph 3
T Spitfire 1979 Triumph Spitfire 1500 rear wheel alignment Triumph 4
B Spitfire 1979 Spitfire Emissions Triumph 4
D 1979 Spitfire Spotted 0
R Spitfire Lbs of compression Spec for 1979 Spitfire. Triumph 3
Andrew Mace Wedge 1979 [Fed.] TR7 fuel tank questions Triumph 6
AngliaGT 1979 B Owner's Manual MG 6
startech47 1979 Midget rear hub bearing nut torque spec. Spridgets 3
M zenith float adjustment 1979 MG 1
ronzet Needed EGR valve for a 1979 MG Midget Spridgets 20
H Valve cover paint 1979 Midget Spridgets 8
startech47 1979 Midget Wheel Bearing Numbers Spridgets 0
P 2 midget problems 1979 help! Spridgets 2
B Have Available for Midget [Its from a 1979]... Spridgets 0
B 1979 Midget Wiring Diagram, Harness, etc. Spridgets 6
B Spitfire Sellng my 1979 Triumph Spitfire 1500 Triumph 1
PATR8 1979 MG for sale MG 1
B 1979 MG Midget Headrest available..just pay shipp. Spridgets 2
1979Roadster 1979 OVERDRIVE TRANNIE MG 3
B Help with 1979 Radiator Spridgets 19
B 1979 MG Midget Headrest Available! Spridgets 3
B My 1979 Midget...before and on its way to rebirth! MG 10
kyreb1862 Wedge 1979 TR7 Roadster Automatic Triumph 0
startech47 Static timing a 1979 Midget Spridgets 4
X 1979 LE console removal MG 9
S 1979 rear shock conversion kit worth it? Spridgets 10
S White disk in drivers seat 1979 Midget? Spridgets 3
C Triumph colors from PPG book 1979 Triumph 2
