Needed EGR valve for a 1979 MG Midget
ronzet
LBC Gurus....
A fellow asked me this morning if I knew where to buy or if there was an acceptable substitute EGR valve for his 1979 MG Midget.... Just thought I would do my good deed for the day... I am an OLD Boyscout.... :smirk:
It is unavailable from the usual suspects...
Any suggestions????
Thanks
I've a couple on manifolds....did the early Datsun 240Z use the same setup?
Scott,
The only part number that I have is from the Moss catalog...
379-365...
Thanks....
if that's the one that goes on the manifold, I have one he can have for free - no idea if it works, no idea how to know if it works.
JP
JP,
Thanks for the offer. I will check with him to make sure if that is the one he needs and advise....
Ok, yell if you need one.
Might be from a TR6, might be a Spit/Midget 1500. Doubt there is much of a difference given the adjustment screw on the crown. I know it is functional. Visually, it is identical to the one on my smogged Spit 1500. I bought it as a spare and then decided to go the dual SU route instead.
Already removed from the manifold. Price is the cost of shipping.
JP
Insert your fingers in the "cage" and wiggle the rubber diaphragm up and down. If it hisses and pumps air from the nipple, it's good. If the rubber diaphragm is ripped/torn, it's a paperweight.
( erm, I was going to say... suck on the nipple and see if the diaphragm moves, but the boss might take offense to that :nonono: )
Duncan...
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]
What's the worst that can happen if the diaphragm is torn? Little tiny Midgets all over the place? [/QUOTE]
:lol: :smirk:
We could have gone all day without that one... :devilgrin:
JP and Scott,
Thanks for the offers. I spoke with the owner who indicated that it is the mushroom shaped assembly that screws on top of the manifold.
Since Scott has one that is known good, then I will get Scott and Carl (the owner) together to arrange the shipping and paying.
I do not know Midgets... I have an MGA, MGB, and an AH 100-6 so this is new territory for me....
ALZO....
Duncan.. Sooo, that is where Midgets come from.. :smirk:
Scott,
I PM'd you with the contact information foe Carl (the Midget owner)
no problem - let me know if it doesn't work out
JP,
Thanks. I appreciate it...
I will let you know...
I am impressed with you Spridget guys...
Maybe I should add a Spridget to my stable.. :smirk:
Let your friend give you his bad valve with the torn diaphragm and soon you'll have lots of Spridgets around.
excellent idea, I'm sure one or two on the board might even do a straight trade for the AH 100-6 (maybe even me :devilgrin:)
Scott,
I spoke to Carl yesterday. Your email had ended up in the 'junk' file....
He should have emailed you by now... Please let me know...
JP,
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]I'm sure one or two on the board might even do a straight trade for the AH 100-6 [/QUOTE]
What a great idea... but then I wouldn't want to take advantage of 'youse' guys..... :jester:
Patrick67BJ8 Healey Mechanic Needed - El Paso, Texas Area Austin Healey 0
H TR2/3/3A Rock guard needed Triumph 2
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
JohnGone Wanted Q: Small Boot, Small Spare Tire? And, Jack needed. MG Classifieds 2
M General MG Wire Wheel Specialist Needed in Los Angeles area MG 0
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
P MGB Zenith water choke gasket needed MG 4
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
T Wanted BJ7 parts needed Austin Healey Classifieds 0
Jim_Gruber Bugeye Seat Pans needed Spridgets 1
AUSMHLY BJ8 Second Gear Needed Austin Healey 16
E GT6 Help electrical guru needed Triumph 4
Joel Lester TR2/3/3A What size speedi-sleeve needed for pinion seal on a TR3? Triumph 6
tr6web TR6 More leg room needed Triumph 5
S Series 1/2 Wiper Motor Needed Rover / Land Rover 0
R Rust in Block? Help needed! Austin Healey 6
steveg TR6 Hood release pictures needed Triumph 22
steveg Picture needed - front turn light Austin Healey 4
steveg TR6 Spec needed for correct ride height Triumph 28
Michael Oritt 100 throttle linkage--help needed Austin Healey 3
Mickey Richaud TR4/4A TR4 Head Needed Triumph 4
D New Battery Needed for BJ8 Austin Healey 9
Michael Oritt Tenax fastener source needed Austin Healey 6
Jim_Gruber PS Steering Rack Lower Bracket Needed - Some DA over torqued and snapped it in half Spridgets 9
N Electrical Troubleshooting Advice Needed Spridgets 6
Jim_Stevens TR2/3/3A Quick measurement needed Triumph 4
Jim_Gruber Help and Advice needed for post pressure washing debacle Spridgets 10
D Wanted Needed for 1954MGT. MG Classifieds 1
Michael Oritt Speedi-sleeve p/n needed Austin Healey 7
2 Wanted SU-h6 Carb. BODY ONLY needed, badly worn. for TR3A Triumph Classifieds 5
J BJ8 Turn signal help needed. Austin Healey 6
F Water pump replacement on my BT7 advice needed please Austin Healey 18
Michael Oritt Center rod, bracket and mirror info needed Spridgets 8
BoyRacer Ideas needed for under dash radio mount, cup holders, glove box Austin Healey 39
T Radiator Shroud "Chinese Red" Match Needed Austin Healey 10
Got_All_4 General TR Is there a special tool needed for rear brake cylinders Triumph 14
R Our J-H plan - torque specs needed! Other British Cars 2
Jim_Stevens TR2/3/3A Door capping—batting needed? Triumph 9
M Modern Paint Code Needed for Honolulu Blue Restoration & Tools 1
T TR2/3/3A Why is voltage stabilizer not needed for TR3 fuel gauge? Triumph 4
S TR6 part needed Triumph 2
T C42 BJ8 generator long screw needed Austin Healey 2
Michael Oritt Healey image needed Austin Healey 13
Michael Oritt Torque values needed for 100 Austin Healey 5
Jim_Gruber 1275 Damper Pulley Needed Spridgets 16
