100 throttle linkage--help needed
Michael Oritt
In order to remove the intake and exhaust manifolds to access to repair the broken exhaust pipe for cylinders 1 and 4 I had to undo the throttle linkage. Stupidly I did not diagram how everything was oriented prior to disassembly and I am having difficulty getting the linkage back together. Specifically, I need to know how the bell crank mounts:
1. Does its acute angle (less than 180 degrees) face up or down when the bellcrank is mounted on the post?
2. Is the spacer/bushing that is attached to the bellcrank facing inboard (towards the block) or outboard when the unit is slipped over the post?
Also, to what does the long throttle-return spring hook?
TIA....
Michael Oritt
Michael Oritt
Thanks all for the illustrations and photos--once I saw the position of the bellcrank it all became clear and I was able to reassemble the throttle linkage this morning without too much difficulty. I do, however, have another challenge:
Before starting reassembly I decided to leave for last the copper drain pipes which mount to the underside of the intake manifolds. Now that I have everything bolted up I see that, because of the long inflexible drain pipes, getting the nipples started into the holes will not be an easy job.
That will be tomorrow's task....
Michael Oritt
Michael Oritt
This morning I attempted to install the drain pipes into the intake manifolds from under the car and though I could see the holes into which the nipples screwed there was no way I could make it happen.
So after having wasted an hour looking for an easy way out which did not exist I did what I should have done in the first place: I removed the intake manifolds with the carbs attached, pulled them about 4" from the engine and flipped them 90 degrees which gave me good access to the drain holes. Buttoning everything up did require some gentle bending of the copper drains as I repositioned the flanges but in the end it all went back together just fine.
Thanks all for the input.
B Longbridge 100-6 Throttle Linkage Pictures - Any Out There? Austin Healey 27
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
A 100/6 BN4 Restoration Austin Healey 8
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
A 100/6 BN4 Door Lock Austin Healey 15
R 100-4 Transmission Austin Healey 1
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
R Healey 100 Dipstick Stuck Austin Healey 12
T 100 BN2 Possible Ignition Issue Austin Healey 10
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R Big Healey 100 Head Austin Healey 4
G For Sale 100 Year Grille Badges Other British Classifieds 3
Guido36 Webers on a Healey 100 Austin Healey 6
R For Sale 100 engine block w/head Austin Healey Classifieds 3
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
A SOLD!! 1959 100-6 Austin Healey Classifieds 0
dougie '56 100-4 Racer For Sale Austin Healey 12
longbridgehealey SOLD!! 1957 100-6 BN-4 Austin Healey Classifieds 0
longbridgehealey Letting the 100-6 Go Austin Healey 26
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
C What to do with my late father's Healey 100 Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
andrea 100-Six Photo Album Links Austin Healey 1
prb51 Wanted Wanted...hardtop for 100-6 BN 6 2 seater Austin Healey Classifieds 1
prb51 100-6 Drum Brakes Austin Healey 9
S 1958 100/6 Bumper Brackets Color Austin Healey 2
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
Michael Oritt 100 Flywheel Weight Austin Healey 16
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
boxofparts 100-4 Engine Options Austin Healey 12
BoyRacer 6 cylinder flywheel on a 100 engine? Austin Healey 0
K 100-6 Interior Austin Healey 4
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
C Wanted Austin Healey BN2 100-4 Austin Healey Classifieds 2
R 100 Motor and Gearbox Available Austin Healey 2
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
C For Sale Parts, Factory Manual, Restoration Guide for 1959 100-6 Austin Healey Classifieds 4
T 100-Six Clutch Recommendations Austin Healey 5
J Owners of my 100-4 Austin Healey 1
andrea AH 100/6 1957 Longbridge Photo Albums Austin Healey 5
