100 BN2 Possible Ignition Issue
timkbn2
Hi Folks. Have BN2 100/4 that is not running well. Live in Florida ex pat. It starts and runs for around 2min and then goes to heck. Loss of power, mis fires and then finally stops. Sounded like fuel so put new SU pump on and cleaned out the carbs. Still running points. Okay fired up the new pump. Sounded like a vickers machine gun, so I knew that I had fuel.. Did the same thing, missing and the died. Leave it for a few hours fires and then dies. So its has to be ignition. Anybody got any suggestions as to whether its coil, condenser or what? Any body looked at the new CSI ingition product. Thanks Tim Kingaby
roscoe
Just to be clear, the fuel pump should click fairly quickly when the ignition is turned on and then taper off fairly quickly to the point where if you do not start the engine it will either stop because pressure has built up and the float has closed the jet or at least click very slowly, like once every 3 to 5 seconds as pressure can bleed off a bit. If it keeps clicking the pump is trying but either your gas is leaking all over, like out your intake manifold, something is clogged and the pump isn't sucking fuel or the pump isn't working properly.
Bristol401
Member
The only way to know that you have good fuel flow is to take off the fuel hose where it connects to the carbs and aim it into a container. Ignition then on and see how much goes in.
T
timkbn2
Yes of course it clicks until pressure reached. So okay that fuel is being delivewred and presure reached. I have thought of coil and the next thing on the list is that along with condensor. Anybody used the pertex exciter removing the points. Later folks
glemon
I would guess coil or condenser. If you have spares swap them them out (one at a time) and see what happens.
jimmyr
Member
Like glemon mentioned above, my thought would be the rotor. These have been a source of that very problem for years, especially the cheap imports from China. The red color rotors seem to come from a more reliable source, so look into them. As with any Healey used on road trips, packing some "good" spares on road trips can get you home most of the time.
mezy
When we used to service these oldies, allways turn the dizzy cap upside down, check the carbon rod is there and moves freely under spring pressure, then look at the four / six contacts, they usually get a build up on them like plaque on your teeth, it can be flicked off quite easily with a small screwdriver
C Wanted Austin Healey BN2 100-4 Austin Healey Classifieds 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
Martinld123 Healey 100 BN2 Water Pumps Austin Healey 9
J 100 bn1/bn2 id Austin Healey 26
C Wanted 100/4 BN2 1956 Le Mans side windows Austin Healey Classifieds 0
Martinld123 Fuel Tank Cap 100 BN2 Austin Healey 7
K Wanted W.T.B. Late 100 BN1-BN2 DOOR HINGE Austin Healey Classifieds 0
Martinld123 Austin Healey 100 BN2 fuel gauge not working Austin Healey 13
aero3113 1956 100 BN2 Fender Beading Austin Healey 8
M 100-4 BN2 Front Fender with extra Groove Austin Healey 2
d_valentino 1955 BN2 Austin Healey 100 Questions Austin Healey 39
P Reverse in 100-4 BN2 Austin Healey 4
356roadster what tires for a 100 BN2? 185/HR15 or 185/70HR15 Austin Healey 26
T Looking for a AH 100-4, preferably a BN2 Austin Healey 0
T New member, looking for AH 100 BN2 Austin Healey 0
Thomas591 Stupid question on 100 BN2 Axle Austin Healey 3
1 100-4 BN1/BN2 Drivetrain wanted Austin Healey 0
S Opinions on 100 BN2 value/body repair issues Austin Healey 29
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
A 100/6 BN4 Restoration Austin Healey 7
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
A 100/6 BN4 Door Lock Austin Healey 15
R 100-4 Transmission Austin Healey 1
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
R Healey 100 Dipstick Stuck Austin Healey 12
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R Big Healey 100 Head Austin Healey 4
G For Sale 100 Year Grille Badges Other British Classifieds 3
Guido36 Webers on a Healey 100 Austin Healey 6
R For Sale 100 engine block w/head Austin Healey Classifieds 3
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
A SOLD!! 1959 100-6 Austin Healey Classifieds 0
dougie '56 100-4 Racer For Sale Austin Healey 12
longbridgehealey SOLD!! 1957 100-6 BN-4 Austin Healey Classifieds 0
longbridgehealey Letting the 100-6 Go Austin Healey 26
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
C What to do with my late father's Healey 100 Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
andrea 100-Six Photo Album Links Austin Healey 1
prb51 Wanted Wanted...hardtop for 100-6 BN 6 2 seater Austin Healey Classifieds 1
prb51 100-6 Drum Brakes Austin Healey 9
S 1958 100/6 Bumper Brackets Color Austin Healey 2
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
Michael Oritt 100 Flywheel Weight Austin Healey 16
