100 Clutch Freeplay
349A
Hey guys,
When I received my 100 a few years ago, pretty much fresh out of restoration, the clutch was fine. I saw that the freeplay was adjusted to almost zero and adjusted it to 11/16. Now, when moving along and giving it some hard acceleration, it momentarily slips until I let off the gas and let it catch. It engages gears perfectly, I don’t feel any slipping off the line although I don’t generally take off too quickly. Everything is new, linkages are new, clutch is new etc. is 11/16” the correct freeplay adjustment?
Thanks!
I've never measured free play on either of my cars--BN2 and BJ8--but have always used "'bout an inch" rule-of-thumb (BJ8 is hydraulic so no adjustment possible). Theoretically, the only point of having any free play at all is to assure the release bearing doesn't rub too much on cover platen or, possibly, to give some adjustment to engagement point. Have you tried re-adjusting the linkage? Your clutch has likely worn some. Worst case, either/both clutch or graphite release bearing* has worn. Shade-tree check for slipping clutch is to apply all brakes when idling then put gearbox in fourth and let out clutch; if engine keeps running clutch has left the building.
* Rumor has it there were some defective release bearings going around a few years ago; owners were only getting a few thousand miles before they self-destructed.
349A
Thanks, Bob! This restoration was done by the PO (with a famous lawsuit that followed!) and the workmanship is really top notch. The parts are older, the clutch was done during a restoration prior to the second 5 year long restoration! The car had basically been restored and re-restored and the clutch and other trans parts were changed around 10-15 years ago.
I will give your test a try this weekend and see what happens.
349A
I’m now just over 1.5” of freeplay and it’s better. Still slips if I punch the gas. Quite a bit less so since increasing the freeplay. She stalls if I let the clutch out with the brakes on in 4th. Engagement hasn’t suffered with more freeplay. I may try increasing it more. Kinda confused about what’s going on. Clutch has less than 800 miles on it.
349A
I’m mostly chatting with myself here but for anyone seeking advice in the future- I adjusted freeplay to 2” at the pedal, which is how it arrived to me, and it’s perfect. No slipping, no drag, perfect. I’m unsure why the 11/16” spec doesn’t work for me but I’m happy all is well.
I wouldn't be comfortable with that much freeplay, but if you like it that's fine. I've had a couple of owners' manuals (Mustang GT) admonish me to 'always push the clutch pedal all the way in' but I've never heard the reasoning; presumably, if the release bearing isn't completely extended there may some grinding of gears, even if you can't hear it.
349A
It’s not a matter of liking the freeplay, it’s what is required to stop it from slipping. I’m not sure why it needs so much, that’s my real question. However, it seems to be driving well without slip, without grinding or dragging.
T 100-Six Clutch Recommendations Austin Healey 5
S "59" 100-6 brake/ clutch master cylinder upgrade Austin Healey 3
T 100 Clutch Return Spring Austin Healey 2
LuckyLuke 100-4 brake / clutch pedal seals not available Austin Healey 3
D 100 BN1 Clutch Austin Healey 5
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
A 100/6 BN4 Restoration Austin Healey 7
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
A 100/6 BN4 Door Lock Austin Healey 15
R 100-4 Transmission Austin Healey 1
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
R Healey 100 Dipstick Stuck Austin Healey 12
T 100 BN2 Possible Ignition Issue Austin Healey 10
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R Big Healey 100 Head Austin Healey 4
G For Sale 100 Year Grille Badges Other British Classifieds 3
Guido36 Webers on a Healey 100 Austin Healey 6
R For Sale 100 engine block w/head Austin Healey Classifieds 3
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
A SOLD!! 1959 100-6 Austin Healey Classifieds 0
dougie '56 100-4 Racer For Sale Austin Healey 12
longbridgehealey SOLD!! 1957 100-6 BN-4 Austin Healey Classifieds 0
longbridgehealey Letting the 100-6 Go Austin Healey 26
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
C What to do with my late father's Healey 100 Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
andrea 100-Six Photo Album Links Austin Healey 1
prb51 Wanted Wanted...hardtop for 100-6 BN 6 2 seater Austin Healey Classifieds 1
prb51 100-6 Drum Brakes Austin Healey 9
S 1958 100/6 Bumper Brackets Color Austin Healey 2
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
Michael Oritt 100 Flywheel Weight Austin Healey 16
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
boxofparts 100-4 Engine Options Austin Healey 12
BoyRacer 6 cylinder flywheel on a 100 engine? Austin Healey 0
K 100-6 Interior Austin Healey 4
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
C Wanted Austin Healey BN2 100-4 Austin Healey Classifieds 2
R 100 Motor and Gearbox Available Austin Healey 2
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
C For Sale Parts, Factory Manual, Restoration Guide for 1959 100-6 Austin Healey Classifieds 4
