Help and Advice needed for post pressure washing debacle
Jim_Gruber
Decided to pressure wash Bugsy in prep for painting soon. Proceeded to use Gunk engine degreaser in the engine compartment as well as in cockpit. Let’s just say Bugsy’s old 948 lubricated lots of things very well. Pressure washer loosened up lots of grease and grime and oil and deposited it all over my primer. And in the cockpit compartment everything every surface is covered with oil.
Help is now needed.Bugsy is sitting in the sun to dry out and advice is needed on cleaning things up prior to paint. The pressure washer seemed like such an easy way to clean things up. The post cleanup will take days. Will be trying straight Dawn detergent to fusible grease in exterior paint. Any other suggestions?
Bayless
Acrli-Clean is an excellent pre-paint metal prep and cleaner and I would definitely use it before painting. But to clean up the oil, I would start with the Dawn. Don't use it straight though as detergent depends on the water to carry away the gunk.
Jim_Gruber
Jim_Gruber
Nope lots and lots of water helped get things cleaned up. Amazing how all the grease particles I blasted off became splotches of gunk everywhere all over the car. I walked back in the house and Kate took one look at me and my clothing and said, the only place those clothes are going is in the garbage can. Those greasy clothes are not going in my washer. Back at it again in the am.
nomad
That's what laundromats are for!:rolleye:
Kurt
twas_brillig
She let you back in the house?
Jim_Gruber
Jim_Gruber
Yes and she told me drop those clothes by the door.
Came home today from my Sister's House again today, sweaty and dirty. Brain Heat Addled.
Did some more cleanup on yesterdays debacle and New Dash got primed and painted and will get a nice new layer of Red Vinyl just in time for a Birthday Party picnic in two weeks in Sarasota with Guest of Honor Gerry Coker.
I hope to get him to sign the corner of my new dash.
For those of you unaware of the name Gerry Coker, he's one of the designers of the Bugeye Sprite. Looking forward to meeting him, and hopefully hearing some interesting stories.
Lyayozoce
In the future, I can advise you to use the services of professional high-pressure car washing companies and not wash it yourself.
Lyayozoce
It is not so expensive that you cannot afford it, but the work will be done much better, using professional equipment and in the shortest possible time. For example, https://sparklewash.com/eastwisconsin/ offers similar services. This company provides a wide range of car wash and restoration services to the commercial, residential and fleet markets. They also tailor their services to suit your needs and recommend a customized plan that suits you and your budget.
PAUL161
Now that seems like a familiar statement, I thought I was the only one! :rolleyes2: :devilgrin:
LarryK
Been there done that. But, I used the local car wash and when I got home, wife had a spare set of clothes set up for me. Then she said, when done she pointed to laundry down the street. Now I just wear old clothes when doing the nasty stuff and throw them away.
L Healey 3000 restoration help and advice please... Austin Healey 18
C Any help or advice for accident repair?!? Austin Healey 15
L Need advice on this 1953 XK120M - HELP Jaguar 7
Atrus Leaf Spring help/advice Spridgets 3
T Lots to do, 74 B , need help [advice] MG 30
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
K TR6 Need help with Mimosa Yellow Paint Triumph 1
Bayless Help please installing bonnet release cable Spridgets 8
T TR2/3/3A Help - Cooling system problem Triumph 7
D TR6 Help with tr6 engine diagnosis Triumph 11
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
I Bugeye oil leak help Spridgets 4
A TR6 Carburetor help Triumph 5
Darwin GT6 Diff Help Please Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
algot1901 HELP with wheel bearings Other British Cars 1
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
T Lotus 7 - help identifying parts Lotus 5
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
