I have had increasing problems with oil leaking. Pretty sure my clutch is contaminated to some extent now. I cannot tell exactly where oil is leaking from. I do know the valve cover gasket is not leaking. I am guessing I am looking at the oil pan and front and rear main seals, correct? I replaced the oil pan gaskets before, but there was still some leaking. To do this right, I figure I should just replace all possible culprits at this point. Any tips on how to replace the main seals? Any tips are appreciated.
kevin
kevin
