Installing Adapter Hubs for Wire Wheels on a Bugeye
J
jbfitz505
I have now completely restored my 1960 Sprite Mark 1, and am considering installing wire wheels with two-earred knock-off nuts on all four wheels.
Any input about the results, possibly negative, of doing this?
Editor_Reid
Platinum
jb, your question is more than welcome here, and I've owned at least eight Bugeyes myself, but this forum is focused on big Healeys. There is another forum within the British Car Forum titled "Spridgets," and you'll find more people with more experience with Sprites there.
By the way, the biggest negative of converting to wire wheels - apart from the cost - is that wire wheels are a pain to clean, and those simple and classic pressed steel wheels with their elegant chrome "AH" hubcaps not only look great, but they require mere moments to clean. Think about it: 240 spokes (four 60-spoke wheels) take time and meticulous attention to get clean, not to mention the hubs and outer wheels, and the cleanliness won't last. The novelty of cleaning spokes, 240 + 240 + 240 + 240, wears off quickly.
Good luck.
CARSINC
Wire wheels were originally racing wheels and are wider than the steel pizza cutters. If you are interested in converting to wires, I have a complete set up - 5 wires, hubs, disks, rear axles. All you need is the rear axle housing. PM me to discuss price and shipping.
equiprx
JB,
I don't own a Sprite, but if I did, there are only two options for my taste, Stock Steel or Panasports.
nevets
Good luck.
Good points. I actually like pressed steel wheels and hubcaps on a big Healey too...not as sporty as wires, more of a town & country look.
S Installing a Radiator Fan Austin Healey 9
G Installing New Rocker Shaft Assembly Austin Healey 3
W Need advice on installing new side curtain glass Spridgets 1
Bayless Help please installing bonnet release cable Spridgets 8
M TR6 Installing Retrosound? Triumph 4
S TR2/3/3A Installing the distributor pedestal. Triumph 3
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
A TR6 Installing differential and transmission Triumph 10
Z Installing Toe Board Panels Austin Healey 1
K TR2/3/3A Installing Brake Caliper pistons into the bore? Triumph 21
CJ Burton MGB-GT Installing Seat Covers for 1962 - 1967 MGB GT MG 0
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
B Installing cam bearings 1275, can I do it? Spridgets 1
bighealeysource Installing stainless steel brake hose on BN2 Austin Healey 5
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
steveg TR6 Installing adjustable trailing arm brackets Triumph 7
T Installing Garmin GPS in a BJ7 Austin Healey 19
F Installing AC in my 1960 Healey Austin Healey 14
S TR2/3/3A technique for installing a door Triumph 5
R TR2/3/3A Installing wiring harness in steering column Triumph 59
R TR2/3/3A Installing gas tank Triumph 6
C Installing rubber grommets in firewall? Austin Healey 6
S TR2/3/3A installing a fuse in the red tail lights Triumph 4
S TR2/3/3A installing the wiring harness Triumph 8
R Installing Sprite Luggage Rack Spridgets 9
Lukens TR2/3/3A Installing a throttle. Triumph 2
J Powertune booster for a bj8 , trouble installing Austin Healey 2
B TR2/3/3A Installing dzus fastners in bonnet Triumph 8
D Prepping Floors Before Installing Interior Restoration & Tools 6
drooartz Installing front hubs, tips? Spridgets 15
E TR4/4A Wiring the horn when installing a Moto -Lita steering wheel Triumph 4
K TR2/3/3A Installing Moss wheel spacers? Triumph 5
D BT7 tri-carb installing my crank Austin Healey 4
aero3113 Installing Front rotors to hubs Austin Healey 2
C Advice for installing a 3000 Grille??? Austin Healey 7
B MGB Installing new upper fulcrum bushings MG 5
B MGB Installing upper fulcrum bushings MG 0
S TR4/4A procedure for installing gauges etc Triumph 0
I Tips for installing intake manifold plugs in a stock Bugeye? Spridgets 6
55modified Help installing toggle dip switch on dash for lights. Austin Healey 23
TRMark TR4/4A Installing a new windscreen Triumph 9
55modified Rear anti-roll bar. Is it worth installing on a BN1? Austin Healey 22
T Installing a Lucas 16 ACR alternator on Bugeye Spridgets 10
KVH General Tech Installing the Pistons and Rings Triumph 7
T Need advice for installing a Winner's Circle Panhard rod on a BE Spridgets 4
6 General Tech Installing New Oil Pressure Gauge MG 5
6 Installing Oil Pressure Gauge Spridgets 2
T TR4/4A Installing wheel arch covers in a Tr4a Triumph 0
K TR2/3/3A Installing a Voltmeter on a TR3? Triumph 10
Tinkerman TR2/3/3A Installing small body stone guard Triumph 9
