Need advice on installing new side curtain glass
willys
Got a '62 MG Midget I'm redoing. I've got the plexiglass and felt runners for them. Got the old glass out now. How in heck do you get the new stuff back in? Any videos, tutorials anywhere I can view. Thanks ahead of time!
twas_brillig
Lord, it's been decades since I did that! My recollection is pushing the plexi up against the runners hard enough to compress the material such that the edge of the plexi would clear the other side of the frame, and then the felt would push the plexi up and into the opposite frame. Doug
T Need advice for installing a Winner's Circle Panhard rod on a BE Spridgets 4
tr6web TR6 Need advice removing downpipe nuts Triumph 4
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
N Need brake bleeding advice Spridgets 6
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
Jer Thinning the collection, need some advice on pricing parts including a hardtop Spridgets 8
Bayless Need wheel bearing advice please Spridgets 4
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
davester Just got my Sprite back [in pieces] after 42 years...need advice Spridgets 8
M Need Advice On 948 Engine Rebuild Spridgets 7
R Need Advice On Refinishing A Bugeye Hardtop Spridgets 15
D Need Some Advice on My 1967 BJ8 Austin Healey 8
M TR5/TR250 Need some advice on TR250 Triumph 22
Jim_Gruber Need advice on how to fix this one. Spridgets 7
Jim_Gruber Issue with removing front drums and spindles on BE- Need advice Spridgets 5
R TR4/4A Need Advice as to what to do regarding Engine Compression Problems Triumph 26
J MGB Need some Exhaust flange advice MGB< but really any of our old cars MG 0
Jim_Gruber Bugsy II - Planning Welding - I need some advice Spridgets 14
B Cylinder Head - Need advice Spridgets 5
drambuie Need advice How to Install a volt gauge properly Austin Healey 16
Parker MGB MGB Chrome trim strip installation... need advice! MG 10
M Need advice on fitting rear pillar interior trim.... British Motor Corp 2
Patrick67BJ8 Painting inside of block with Glyptal-need advice Austin Healey 10
I Need some advice on bugeye conversion Spridgets 8
R TR2/3/3A TR3 Seats - Need advice Triumph 9
A need advice on fuel pump Triumph 12
britlover TR5/TR250 Looking at TR250, has issues, need advice Triumph 9
tri_carb_healey need some advice Austin Healey 8
Coyote1 Overider Restoration - need advice Triumph 1
B TR2/3/3A Need advice TR3b inner sill replacement Triumph 16
T T-Series Need Advice - MGTF Steel Wheels Need Attention MG 2
T T-Series Need advice re MGTF rack and pinion removal MG 4
T Need exhaust header advice/source for Amos Triumph 49
J need advice renewing front lower A-arm Spridgets 31
W restoring a BN2 - need advice on sheet metal Austin Healey 10
Sprocket Barake drum locked up - need advice Austin Healey 7
R engine trouble, need advice Spridgets 16
B I need some advice/suggestions.... Triumph 10
L Need advice on this 1953 XK120M - HELP Jaguar 7
R smiths guage problem- need advice Austin Healey 4
bobmga62 MGA mga hardtop... need reconditioning advice MG 7
kyreb1862 Need Some Advice MG 2
H Need advice, Should I Wrap the Exhaust Pipes? Austin Healey 7
jackq O/D problem..need advice MG 8
M Pulled the Trigger...Now I Need Advice! Spridgets 20
B T-Series Need advice on a 53 TD MG 2
T Need advice on a 1275 Spridgets 6
PATR8 Need advice on a new project [Volvo 240] Other Cars 19
