Need advice How to Install a volt gauge properly
drambuie
Hello everyone, I would like ask, what are the proper connections when installing a volt gauge to a 67 BJ8 with positive ground. I have been searching this topic, however I was not satisfied with the advise....so, I will pose the question if anyone here cares to make a suggestion.
I would think the hot wire "white" from the ignition switch would be connected to one wire in back of the gauge, and the other wire from the gauge goes to ground. Any need for a in line fuse between gauge and white ignition wire? Naturally, I want the gauge to shut off when the cars ignition is turned off. Thanks everyone and have a Great Thanksgiving.
andrea
https://mgaguru.com/mgtech/electric/et220.htm here you can find a great technical and practical article
20110801105208-digital.jpg20110801105209-digital2.JPGmy easy and cost cut solution
Voltmeter on car is a good auxiliary info
-BUT Amperometer are more useful
drambuie
drambuie
Thank you for the article and electrical schematics Andrea.... Most helpful, I will use a smiths gauge so it matches the other smiths gauges. I was reading a article that Amp gauges draw high current and can cause fires if not wired properly under the dash. That is why many people tend to go with a volt gauge. I think 16 gauge wire should be ok for the volt gauge wiring. Michael.
andrea
wire for voltmeter are NOT critical and you can use the normal wires
for the Ammeter gauge, are very critical - all the current for lamps headlamps fan relays etc. transit through it, for measurement of absorption
Cheers
drambuie
drambuie
Thank you again Andrea, I really appreciate your advise on this subject. After installing a new Control box"regulator" I thought it would be a good idea to have a volt gauge to monitor the battery condition. Take care, Michael.
Keoke
Cheers
Addirionally if the Ampmeter fails you are out of power on the car------
steveg
I had a situation where the car ran out of electricity and stopped dead on a freeway due to my inadvertently having disconnected the field wire from the alternator. The car had run for a couple of weeks in the daytime with my having no idea the alternator wasn't charging the battery!
I installed the Moss Smiths voltmeter in parallel with the ignition switch wire to the coil. Very easy.
Now I can look and see 13.5 volts when the car's running. So I can easily tell whether my alternator's charging or not.
Am inclined to favor the voltmeter due to ease of installation and, I think, superior info. Ammeters have given way to voltmeters on modern cars.
Why not use both the ammeter and voltmeter? Easy to do and each has it own information. (and I like watching the needles move) It is interesting to watch the ammeter when you have the radio, directional signal and lights on.
Patrick67BJ8
With all that needle watching when do you find time to text when you're driving?
drambuie
drambuie
Ok....now that I have the the right connections, white ignition wire to volt meter and the other volt meter wire to ground...anyone have a good smiths volt meter "black face" they want to sell?
Keoke
You will still go dead in the water if the ampmeter fails--TH---:friendly_wink:
Patrick67BJ8
Check ebay. They popup often.
steveg
Well, I have my wife hold my beer.
Keoke, I have shielded the wire where ever the go near any other wire or firewall. Is it more likely to fail than any other Lucas system? I'm pushing 4 to 5 years on the system. If I should have a road side problem, the gauge could be by passed easily. No? I think an ammeter is the most valuable gauge (with the acceptation of maybe the pressure/temp gauge)as I have driven without a tach and with a speedo registering all over the place. We won't even discuss the accuracy of the fuel gauge.
tr6web TR6 Need advice removing downpipe nuts Triumph 4
W Need advice on installing new side curtain glass Spridgets 1
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
N Need brake bleeding advice Spridgets 6
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
Jer Thinning the collection, need some advice on pricing parts including a hardtop Spridgets 8
Bayless Need wheel bearing advice please Spridgets 4
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
davester Just got my Sprite back [in pieces] after 42 years...need advice Spridgets 8
T Need advice for installing a Winner's Circle Panhard rod on a BE Spridgets 4
M Need Advice On 948 Engine Rebuild Spridgets 7
R Need Advice On Refinishing A Bugeye Hardtop Spridgets 15
D Need Some Advice on My 1967 BJ8 Austin Healey 8
M TR5/TR250 Need some advice on TR250 Triumph 22
Jim_Gruber Need advice on how to fix this one. Spridgets 7
Jim_Gruber Issue with removing front drums and spindles on BE- Need advice Spridgets 5
R TR4/4A Need Advice as to what to do regarding Engine Compression Problems Triumph 26
J MGB Need some Exhaust flange advice MGB< but really any of our old cars MG 0
Jim_Gruber Bugsy II - Planning Welding - I need some advice Spridgets 14
B Cylinder Head - Need advice Spridgets 5
Parker MGB MGB Chrome trim strip installation... need advice! MG 10
M Need advice on fitting rear pillar interior trim.... British Motor Corp 2
Patrick67BJ8 Painting inside of block with Glyptal-need advice Austin Healey 10
I Need some advice on bugeye conversion Spridgets 8
R TR2/3/3A TR3 Seats - Need advice Triumph 9
A need advice on fuel pump Triumph 12
britlover TR5/TR250 Looking at TR250, has issues, need advice Triumph 9
tri_carb_healey need some advice Austin Healey 8
Coyote1 Overider Restoration - need advice Triumph 1
B TR2/3/3A Need advice TR3b inner sill replacement Triumph 16
T T-Series Need Advice - MGTF Steel Wheels Need Attention MG 2
T T-Series Need advice re MGTF rack and pinion removal MG 4
T Need exhaust header advice/source for Amos Triumph 49
J need advice renewing front lower A-arm Spridgets 31
W restoring a BN2 - need advice on sheet metal Austin Healey 10
Sprocket Barake drum locked up - need advice Austin Healey 7
R engine trouble, need advice Spridgets 16
B I need some advice/suggestions.... Triumph 10
L Need advice on this 1953 XK120M - HELP Jaguar 7
R smiths guage problem- need advice Austin Healey 4
bobmga62 MGA mga hardtop... need reconditioning advice MG 7
kyreb1862 Need Some Advice MG 2
H Need advice, Should I Wrap the Exhaust Pipes? Austin Healey 7
jackq O/D problem..need advice MG 8
M Pulled the Trigger...Now I Need Advice! Spridgets 20
B T-Series Need advice on a 53 TD MG 2
T Need advice on a 1275 Spridgets 6
PATR8 Need advice on a new project [Volvo 240] Other Cars 19
