Need advice for installing a Winner's Circle Panhard rod on a BE
twas_brillig
I bought the above a couple of years back but only got the mounting assembly bolted onto the body of our Silver project at the time, and now I can't find all the pieces nor whatever I'd received for instructions. I've phoned the shop a couple of times but have missed the chaps there. I've got the rod and the two heim joints, but the catalogue shows a couple of other pieces that I'm missing (and can't quite figure out what they are from the picture in the catalogue), plus I don't know where/how to attach it to the axle/suspension.
Photos/advice/copies of the instructions would be much appreciated; as well as some sort of magic drink to improve memory (where are those bits and pieces) and motivation.
Thanks, Doug
Nelson
I have the instruction sheet. Let me know if you still need a copy
T
twas_brillig
A copy would be much appreciated. I'm assuming that the guys were closed over Christmas/New Years/etc., but I'd sure like to have something in my hands. Thanks, Doug
Nelson
Their hours are very erratic. They are just 25 minutes from me but i always call before I head to the store
T
twas_brillig
Got the copy - thanks for forwarding Nelson, plus also the comment regards hours. Doug
W Need advice on installing new side curtain glass Spridgets 1
tr6web TR6 Need advice removing downpipe nuts Triumph 4
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
N Need brake bleeding advice Spridgets 6
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
Jer Thinning the collection, need some advice on pricing parts including a hardtop Spridgets 8
Bayless Need wheel bearing advice please Spridgets 4
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
davester Just got my Sprite back [in pieces] after 42 years...need advice Spridgets 8
M Need Advice On 948 Engine Rebuild Spridgets 7
R Need Advice On Refinishing A Bugeye Hardtop Spridgets 15
D Need Some Advice on My 1967 BJ8 Austin Healey 8
M TR5/TR250 Need some advice on TR250 Triumph 22
Jim_Gruber Need advice on how to fix this one. Spridgets 7
Jim_Gruber Issue with removing front drums and spindles on BE- Need advice Spridgets 5
R TR4/4A Need Advice as to what to do regarding Engine Compression Problems Triumph 26
J MGB Need some Exhaust flange advice MGB< but really any of our old cars MG 0
Jim_Gruber Bugsy II - Planning Welding - I need some advice Spridgets 14
B Cylinder Head - Need advice Spridgets 5
drambuie Need advice How to Install a volt gauge properly Austin Healey 16
Parker MGB MGB Chrome trim strip installation... need advice! MG 10
M Need advice on fitting rear pillar interior trim.... British Motor Corp 2
Patrick67BJ8 Painting inside of block with Glyptal-need advice Austin Healey 10
I Need some advice on bugeye conversion Spridgets 8
R TR2/3/3A TR3 Seats - Need advice Triumph 9
A need advice on fuel pump Triumph 12
britlover TR5/TR250 Looking at TR250, has issues, need advice Triumph 9
tri_carb_healey need some advice Austin Healey 8
Coyote1 Overider Restoration - need advice Triumph 1
B TR2/3/3A Need advice TR3b inner sill replacement Triumph 16
T T-Series Need Advice - MGTF Steel Wheels Need Attention MG 2
T T-Series Need advice re MGTF rack and pinion removal MG 4
T Need exhaust header advice/source for Amos Triumph 49
J need advice renewing front lower A-arm Spridgets 31
W restoring a BN2 - need advice on sheet metal Austin Healey 10
Sprocket Barake drum locked up - need advice Austin Healey 7
R engine trouble, need advice Spridgets 16
B I need some advice/suggestions.... Triumph 10
L Need advice on this 1953 XK120M - HELP Jaguar 7
R smiths guage problem- need advice Austin Healey 4
bobmga62 MGA mga hardtop... need reconditioning advice MG 7
kyreb1862 Need Some Advice MG 2
H Need advice, Should I Wrap the Exhaust Pipes? Austin Healey 7
jackq O/D problem..need advice MG 8
M Pulled the Trigger...Now I Need Advice! Spridgets 20
B T-Series Need advice on a 53 TD MG 2
T Need advice on a 1275 Spridgets 6
PATR8 Need advice on a new project [Volvo 240] Other Cars 19
