Need Advice - Moving Temp Gauge Sensor 1275
DugMoney
Member
Hello guys,
I have a 59 bugeye with the original radiator. I want to move the temperature gauge sensor to the engine block. I have the original smiths temp gauge and upgraded to the 1275.
So how do I remove the sensor from the radiator so it "plugs" in the 1275 engine block?
Thanks!
Billm
Doug
For a 1275 you must get the spacer before you put the bulb into the head. The bulb will fit either way but you will break the bulb if you don't use the spacer. Spacer was common to all 1275's
Billm
You remove the bulb with a 5/8" Crowfoot, an open end wrench will probably just round off the nut
Joe Schlosser
There is a thread on temperature connections on the big Healey board.
Yes you need to find the spacer piece for the 1275 head. You use the blanking plug from the 1275 head in the radiator. They are available from the usual vendors.
As you have installed a 1275, I will assume that you have recently had the sensor bulb out recently. If not the critical thing is making sure the nut is free on the sensor bulb. If the bulb is frozen to the nut then you could damage the bulb and need a rebuild.
If the nut is frozen in the Rad people use a deep 5/8 socket with the side cut out to fit over the capillary tube, similar to the socket used to remove O2 sensors. Some people add a hose clamp on the socket to strengthen the socket.
As I said you need to make sure the bulb does not turn with the nut. I have resorted to actually taking the Radiator out and turning it to remove the bulb and nut and then soaking the assy in solvent to free it up. When reassembling add a coat of never seize between the nut and bulb.
Good Luck
tr6web TR6 Need advice removing downpipe nuts Triumph 4
W Need advice on installing new side curtain glass Spridgets 1
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
N Need brake bleeding advice Spridgets 6
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
Jer Thinning the collection, need some advice on pricing parts including a hardtop Spridgets 8
Bayless Need wheel bearing advice please Spridgets 4
davester Just got my Sprite back [in pieces] after 42 years...need advice Spridgets 8
T Need advice for installing a Winner's Circle Panhard rod on a BE Spridgets 4
M Need Advice On 948 Engine Rebuild Spridgets 7
R Need Advice On Refinishing A Bugeye Hardtop Spridgets 15
D Need Some Advice on My 1967 BJ8 Austin Healey 8
M TR5/TR250 Need some advice on TR250 Triumph 22
Jim_Gruber Need advice on how to fix this one. Spridgets 7
Jim_Gruber Issue with removing front drums and spindles on BE- Need advice Spridgets 5
R TR4/4A Need Advice as to what to do regarding Engine Compression Problems Triumph 26
J MGB Need some Exhaust flange advice MGB< but really any of our old cars MG 0
Jim_Gruber Bugsy II - Planning Welding - I need some advice Spridgets 14
B Cylinder Head - Need advice Spridgets 5
drambuie Need advice How to Install a volt gauge properly Austin Healey 16
Parker MGB MGB Chrome trim strip installation... need advice! MG 10
M Need advice on fitting rear pillar interior trim.... British Motor Corp 2
Patrick67BJ8 Painting inside of block with Glyptal-need advice Austin Healey 10
I Need some advice on bugeye conversion Spridgets 8
R TR2/3/3A TR3 Seats - Need advice Triumph 9
A need advice on fuel pump Triumph 12
britlover TR5/TR250 Looking at TR250, has issues, need advice Triumph 9
tri_carb_healey need some advice Austin Healey 8
Coyote1 Overider Restoration - need advice Triumph 1
B TR2/3/3A Need advice TR3b inner sill replacement Triumph 16
T T-Series Need Advice - MGTF Steel Wheels Need Attention MG 2
T T-Series Need advice re MGTF rack and pinion removal MG 4
T Need exhaust header advice/source for Amos Triumph 49
J need advice renewing front lower A-arm Spridgets 31
W restoring a BN2 - need advice on sheet metal Austin Healey 10
Sprocket Barake drum locked up - need advice Austin Healey 7
R engine trouble, need advice Spridgets 16
B I need some advice/suggestions.... Triumph 10
L Need advice on this 1953 XK120M - HELP Jaguar 7
R smiths guage problem- need advice Austin Healey 4
bobmga62 MGA mga hardtop... need reconditioning advice MG 7
kyreb1862 Need Some Advice MG 2
H Need advice, Should I Wrap the Exhaust Pipes? Austin Healey 7
jackq O/D problem..need advice MG 8
M Pulled the Trigger...Now I Need Advice! Spridgets 20
B T-Series Need advice on a 53 TD MG 2
T Need advice on a 1275 Spridgets 6
PATR8 Need advice on a new project [Volvo 240] Other Cars 19
