Need wheel bearing advice please
Bayless
As I posted a couple of weeks ago, we are finally starting to build the '67 Sprite.:glee: I disassembled the front hubs Friday and found probably original ball bearings that really don't feel too bad. Also I seem to recall some complaints about new replacements but I can't seem to find them anymore. My question is, are the rollers from Moss as good as they claim or should I try to restore the originals? Thanks.
Rut
If the originals clean up and pass inspection I would reuse them. The inside radius of the new bearings tends to not match the radius on the spindles very well.
Rut
Bayless
Bayless
Thanks Rut. That's what I thought I remembered from the discussion. The Moss catalog now claims they have the right radius though. Does anyone have recent experience?
Joe Schlosser
I am not sure who Moss uses for the supplier for their tapered roller bearing kit (I bought direct from Timkin), however upgrading to a taper roller bearing set IMHO is the way to go. The Angular roller bearings are OK but using the taper roller bearings with proper shimming provides a stronger hub assembly. Remember your spindle is 60 years old and can use all the help it can get.
I used taper bearings on my FP car with 8" slicks with no problem. It is a little more time to set everything up but it is worth the effort.
If you have concerns about Moss I can dig through the paperwork and get the Timkin numbers.
Bayless
Bayless
Thanks Joe. I just finally talked with my local LBC mechanic/restorer in whom I have great confidence. He said he did a Midget a couple of months ago with the Moss kip and it worked perfectly. That does seem like a much stronger solution. I think between your and his advice, that is how I will go.
ekamm Need Timken wheel bearing #'s Triumph 13
J TR6 Inverted righ rear wheel [need help] Triumph 10
doates Need Steering Wheel Removal Help Triumph 20
hondo402000 14 inch painted wire wheel any one need it Triumph 1
T longer wheel studs need help finding Triumph 11
Dan_Pasta TR2/3/3A Need TR3A wire wheel opinions Triumph 7
C T-Series Need a MGTD Steering Wheel MG 5
boeingpilot I need an education on wheel measurements... Triumph 8
RickB Need seats & steering wheel MKII Sprite/MKI Midget Spridgets 47
HAN8L1965 Steering Wheel 65-What do I need? Spridgets 14
weewillie anyone need a steering wheel Jaguar 2
R Need a smaller steering wheel Spridgets 3
N need part numbers for front hub wheel beargs Triumph 6
H Wire Wheel Conv in Albuq NM: Need a Good Tire Shop Austin Healey 4
H Wire Wheel Conv in Albuq NM; need a good tire shop Triumph 3
pa297pass TR4/4A TR4 wheel identification - need help Triumph 5
jlaird You say you need your steering wheel restored Spridgets 3
tr6web TR6 Need advice removing downpipe nuts Triumph 4
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
