I've noticed a behavior with the overdrive on my MGB and I'm not sure if it's normal. This is a 1970 MGB with a black label overdrive. During the recent rebuild the transmission was swapped with one I had from a known good parts car (my car was already an OD car, the shop just wound up using my spare).
What I've noticed is that if I use the OD in the first couple miles of a drive from cold it will click in okay -- maybe a little slowly -- but won't click back out again. After 2-3 miles it will function normally without issue. The shop originally used a heavier oil then I liked, so I did drain and refill the transmission and now it has 30w non-detergent in it.
Is this normal behavior? It's been 9 years since I drove this car regularly, and at my old house I wouldn't have used the OD for a few miles anyways. Want to make sure I don't need to go deeper into things if this is normal stuff.
