TR2/3/3A TR3A Windshield Question
TR3-Stu
A recent TR3 posting has got me wondering about my windshield. My question - I have a 1961 TR3A (TS 78330), and when I removed my windshield (held on by four screws, not dzus fasteners) there were stanchion plates under the stanchions. In the parts catalogs I've looked at (Moss and others) they seem to imply that the stanchion plates were only used up until TS60000. Did my PO make a modification to the mounting process - or took a hybrid approach?
charleyf
The stanchions for the earlier cars are different from those of the later (post TS60000 ) cars. The later stanchions do not have room for a "inner" bracket. And the earlier cars have three threaded holes for bolts to mount the inner bracket. Neither of these parts are compatible with the older or newer models. So if you have such a thing it would mean that the previous owner would had to have done some interesting modifications to get them to work.
But then the change over commission numbers have been in question on a lot of different items. My experience as been with a TR3B that had the no inner bracket and four large screws and a pre TS60000 car with the inner bracket.
Charley
CJD
On your TR3A, the stanchions were originally screwed directly into the scuttle...no plates or protection at all.
If you post a pic or two we can ID what you have going on...
T
TR3-Stu
Thanks for the response John and Charley. The TR is currently in winter storage, but when it's available again I'll take a few pics of the stanchion and plates and post them.
Stu
CJD
For such a simple part, the stanchions changed at least 5 times in production. There were a couple early type, using the dzus plate on the scuttle, so the screen could be slid on and off. Then, there were 3 types that screwed directly to the scuttle. Some are interchangable, while others are not. My TR3 came with a plate stanchion that was screwed into the scuttle...so aberrations are common, LOL.
M Wanted Windshield 1959 tr3a Triumph Classifieds 3
P TR2/3/3A TR3A Windshield Frame Curved or Flat? Triumph 7
K Wanted A set of TR3A windshield tenon plates. Triumph Classifieds 1
tr3guy TR2/3/3A Late TR3A, TR3B windshield assemply Triumph 5
D TR2/3/3A fitting windshield/frame to 1960 Tr3a & Brooklands screen removal Triumph 2
T TR2/3/3A What size and threads for corner finisher on TR3A windshield Triumph 3
T TR2/3/3A TR3A windshield glass Triumph 13
T TR2/3/3A Is stock TR3A windshield tinted or clear? Triumph 9
K TR2/3/3A TR3A Windshield Stanchion Screw Removal? Triumph 8
T TR2/3/3A TR3A upper windshield seal Triumph 12
tinman58 TR2/3/3A TR3A windshield Triumph 2
H TR2/3/3A Wanted- TR3a windshield mounting plates + other Triumph 13
Got_All_4 TR2/3/3A TR3A odd windshield studs needed Triumph 4
G TR2/3/3A TR3A Windshield wiper motor...any help? Triumph 2
CraigLandrum TR2/3/3A TR3A Windshield washer info needed Triumph 9
Tinkerman TR2/3/3A TR3A Windshield Disassembly Triumph 2
F TR2/3/3A TR3A Curved Windshield??? Triumph 6
Dan_Pasta TR2/3/3A TR3A windshield washer??? Triumph 14
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph SOLD!! Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
Hamish Racing TR2/3/3A Anglesey (Wales) TR3a track videos Triumph 3
RonC TR2/3/3A TR3A Hardtop Seals Triumph 7
T TR2/3/3A TR3A Disk Brake Question Triumph 10
