TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil.
JoeTR3A
A friend has a 58 TR3A. He had some warm no start issues (let us not talk ethanol and heat soak). I thought possible could be the coil getting too hot increasing resistance and lowering the high volts delivered to the plugs, and adjusted the voltage regulator shutoff down a tad 1/8 turn counter-clockwise on screw thinking at high rpm could have caused too high a running voltage (this lowering was actually reversal since prior adjusted voltage regulator shutoff up opposite, 5/8 turn clockwise, according to Lucas procedure since running voltage at 3,000 rpm was way too low so battery was not charging, so originally raised regulator to 16v at 3,000 rpm as instructed by Lucas). He still had one slight warm no start since reversed a tad, but not driven much.
Yesterday tested the 1968 HA12 45208A non-ballasted coil. It was about 180°F after short ride 2 miles, mounted on side of engine, so does not say much. If he ever has a future new no warm start problem after long ride, asked him to touch the coil to see if massively hot. Checked coil readings (took several with two cheap millimeters and adjusted for calibration) and got:
2.9-3.5Ω on the primary
8.7K-9KΩ on the secondary
The secondary seems low compared to replacement DBL105 spec at 2.8Ω prim 10.45KΩ secondary, and DBL101 at 2.9Ω prim and 10.9KΩ secondary.
So it seems his coil is coming up about an Ohm and a half short on the secondary winding against replacement specs.
1.) Looking for advice. Is the coil too far out of tolerance due to low Ohms on the secondary windings that the old coil should be replaced with the DBL105? Anyone suggest or recommend that? I have no idea if this is too far out of tolerance. Or are things good to go, and do nothing?
2.) If he does replace, is it highly suggested to be better to upgrade to a ballasted coil and ballast as opposed to stock DBL105 non-ballasted?
3.) If the coil is bad, weak, would the low secondary Ohms resistance lead to higher amperage delivered and the coil getting too hot raising resistance so the high voltage jacked up coil output falls and thus no warm start (and noting running voltage off the generator is higher than battery when starting)? Am I thinking possibilities correctly or in err?
Thanks for any replies.
Popeye
Bronze
I’ll let smarter folks chime in on the ohm readings.
However, the 3A needs a 3-ohm coil. I don’t know if there is a difference whether the 3 ohms is internal to the coil, or 1.5 internal plus 1.5 external. (Seems one more connection and component to break?).
The Lucas DBL105 is a correct coil, although there are many options. I just bought a Bosch 00-012 from mini-mania with the same specs, but supposedly(?) higher quality. And higher price…
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
R TR2/3/3A TR3A Coil/condenser problem Triumph 22
Lukens TR2/3/3A TR3A coil. Correct resistance? Triumph 6
A TR2/3/3A Correct Coil for petronix ignition tr3A Triumph 2
T TR2/3/3A On TR3A what gauge wire from fuse box to coil? Triumph 17
T TR2/3/3A TR3A front coil springs - 9-1/2" or 11"? Triumph 2
6TTR3A TR2/3/3A TR3A coil Triumph 7
angelfj1 TR2/3/3A Lucas Ignition Coil for TR3A Triumph 1
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph SOLD!! Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
T TR2/3/3A TR3A Windshield Question Triumph 4
Hamish Racing TR2/3/3A Anglesey (Wales) TR3a track videos Triumph 3
RonC TR2/3/3A TR3A Hardtop Seals Triumph 7
T TR2/3/3A TR3A Disk Brake Question Triumph 10
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
Hamish Racing TR2/3/3A TR3a British Hill Climb Shelsley Walsh Triumph 8
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T For Sale TR3A Original Radiator Triumph Classifieds 3
Hamish Racing TR2/3/3A TR3a Faster Lap Times than a Ferrari F430 ?? Triumph 1
Hamish Racing UK hill climb TR3a Racing 0
Hamish Racing TR2/3/3A TR3a UK hill climb video Triumph 4
Hamish Racing TR2/3/3A 3 sisters fun in a TR3a ! Triumph 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
